My A/C quit working on my F430 | Page 4 | FerrariChat
Discussion in '360/430' started by whatheheck, Apr 25, 2018.
  1. Snapshift
    Snapshift Formula Junior
    735
    Centralia IL
    Lyle D. Pahnke
    Took it to dealer and during annual found that the compressor seal was leaking and the refrigerant was leaking out slowly. It was vacuumed and recharged and I will monitor it by topping it off periodically until the new compressor comes. The clutch , compressor, relays and ecu's all worked normally when a full vacuum and recharge done. Will replace the compressor in a few weeks.
    Qavion likes this.
  2. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,302
    San Jose
    dc
    Did they also swap the drier?
  3. Qavion
    Qavion F1 World Champ
    11,534
    Ian Riddell
    Thanks for the update :)
  4. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Hi Dan,
    Glad to hear you got the A/C issue sorted out. Great job!
    I think that is the right connector with a link on Amazon.
    I recommend a good solder connection and a good water tight heat shrink.
    All the best to you always.
    Dan L.
    jag-oo-r likes this.
  5. jag-oo-r
    jag-oo-r Formula Junior
    423
    Thanks Dan! I concur about the connecting method, but it's always good to hear it from a pro like you!
    Hope you're well!
    Sent from my SM-G970U using Tapatalk
    whatheheck likes this.
  6. Snapshift
    735
    Centralia IL
    Lyle D. Pahnke
    on order wi compressor thx
  7. Snapshift
    735
    Centralia IL
    Lyle D. Pahnke
    Just had a pleasant conversation with the company Coolairparts in TX. for my new compressor and dryer with 2 yr warranty total wi shipping and free core return $660.00
    Not too bad for my a/c rebuild. FWIW Looks to be a reputable source for Ferrari a/c parts at reasonable prices
  8. Snapshift
    735
    Centralia IL
    Lyle D. Pahnke
    I might have been scammed on this. Reviews as few as there are are not too encouraging. Will follow up as soon as I know something. Maybe they have cleaned up their act since the reviews, but I am now very wary. If anyone has had any dealings with them, please let me know. i may cancel the order before it is shipped with my Credit card.
  9. jag-oo-r
    423
    Thought y'all might appreciate seeing what I found:
    This is a video of the bad connector, and how I knew it wasn't the compressor side of the connector:
    https://youtube.com/shorts/ZD-hxcw7agY?feature=share
    This is "post-repair".
    https://youtube.com/shorts/CqUIJely5yg?feature=share
    whatheheck and Qavion like this.
  10. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
  11. N17OCG
    N17OCG Rookie
    Jun 16, 2021
    1
    Oliver Gilmartin
    Exact Same problem happened to me - Refused to have Full A/C Compressor unit changed as it was just clutch faulty - Have managed to get working order by fitting shorter belt so that once i find A/C Clutch Compressor i can fit .
    Does anyone have any links to a A/C CLUTCH compressor i can buy ?
    Many Thanks
  12. Snapshift
    735
    Centralia IL
    Lyle D. Pahnke
    Based on another thread, I believe the conclusion for the longest lasting one with a better connector was from Ricambi.
  13. Snapshift
    735
    Centralia IL
    Lyle D. Pahnke
    SCAM Avoid at all costs. Got my money back thankfully.
  14. Snapshift
    735
    Centralia IL
    Lyle D. Pahnke
    I was misleading on the A/C clutch. At the beginning of this thread Dan "What the heck" discusses his saga with replacing the clutch on his 430. He eventually wound up replacing the entire clutch compressor combo new from Superformance or Eurospares in UK. There are probably 2 other sources of new A/C compressors for Ferraris that are listed on this forum one is in Florida and one in CA. I cant seem to locate the name
  15. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,302
    San Jose
    dc
    Even with Dan's experience I would relive his nightmare with attempting my own clutch replacement first. Cause this time it will be different.
    jag-oo-r and Snapshift like this.
  16. phy6
    phy6 Rookie
    Jul 22, 2021
    3
    MD
    Dan J
    Hey, I'm new here. I found this thread because the F430's cheaper sisters seems to share the same AC Compressor, or at least somewhat interchangable. On my 2012 Maserati GT MC, it's Delphi model 01441206.
    Mine had stopped working driving back from a funeral on a hot day this summer. When I went to check it on the lift the ~T20 Torx bit from the center of the AC clutch fell out into my hand -- it had sheared off. Using a socket to de-tension the serpentine belt, I could feel that the AC compressor pulley had some play to it, like a bad bearing.
    Once I gently pried off the inner clutch, there was one ~2" outer diameter C clip ring holding the pulley on. (There's an inner c clip next to the spline shaft, but that's not what you need to remove) Inside the steel pulley was this bearing:
    NSK Japan 35BD5222DUM2
    Measurements for this bearing are
    d 35
    D 52
    B 22
    C 22
    Seal 2RS
    Weight (kg): 0.121
    I think the clutch itself is ok, and the internals of the pump are probably just fine -- I can turn the compressor spline shaft with my fingers. This seems to be a failure of the compressor clutch bearing only.
    It seems to be a common fault, with this bearing model number being used in Dodge trucks to Hondas to Kia cars. (Probably Delphi compressors)
    Quote from a Dodge forum in 2011:
    I have a 2002 Duramax with a Delphi air conditioner compressor. After 220,000 miles the compressor clutch bearing began to make noise on frosty mornings. It seems no aftermarket parts supplier carries a clutch kit for this Delphi compressor. Even GM only sells the whole compressor, not the bearing or clutch kit. After removing the pully I found the part number on the NSK bearing was, 35BD5222DUM2. The Motion Industries supplier in Missoula Montana was kind enough to contact NSK and found out the part number on the bearing had been changed in the system and it was available for $39.00 freight included. The bearing arrived about 10 days later and fit the pully so I was on my way for much less than a new compressor. The NSK part number on the invoice that came with the new bearing is 35BD5222T1XDDUM-01 C. That is followed by *MA6L5 and the Motion Industries part number on the invoice is 04246189. I looked at NSK's web site and tried to find the bearing number in their search engine without success. If you need the bearing I suggest you go to a Motion Industries or other industrial bearing supplier with the NSK 35BD... number and order one.​
    Sure enough NSK boxed bearings "35BD5222T1XDDUM" are on eBay for $10 to $30.
    They are also on Amazon listed as "NSK 35BD5222 AC Compressor Clutch Bearing" for about $17.
    My guess is that the bearing is not made to withstand the forces these engines + tensioners can place on them. When the pulley can wobble, the clutch load is probably placed on that little button head Torx bolt, which is why it fatigued off.
    I'm going to weld a small nut to the end of the sheared Torx bolt (it sheared flush and looks too small to drill), and back it out with some TLC. It's probably an M6 thread, so I'll just swap in a high grade metric hex bolt of the right length.
    The bearing is staked in place on the back of the pulley, but I think those will give way to a shop press pushing the old bearing out.
    I'm not confident in any of the chinese knockoff delphi units (advertised for F430 and various Maseratis) which go for about $350 -- I'd need to see some long term reviews.
    Hope this helps someone in the future.
    - A different Dan
  17. phy6
    phy6 Rookie
    Jul 22, 2021
    3
    MD
    Dan J
    One more update, while the AC clutch bearing itself might have a little play, it seems the aluminum "snout" on the AC compressor may be worn. I'm going to order a new AC compressor.
    In the meantime I'll wait for and press in the new bearing, then use some JB weld to take up the few thousandths (about paper thickness) of play between the new bearing and the snout. I found this other post doing the same thing:
    https://forum.ih8mud.com/threads/a-c-clutch-bearing-replacemet-cheap.294467/
    Qavion likes this.
  18. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Have a look at Loctite Bearing fit, designed for the job
    phy6 likes this.
  19. phy6
    phy6 Rookie
    Jul 22, 2021
    3
    MD
    Dan J
  20. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    You have different names to those in uk. You need a retainer
  21. RS RS
    RS RS Rookie
    Aug 14, 2019
    37
    usa
    I am running into the same A/C not working issue. Before I dig into all the steps outlined in this thread, I did the below step using the Launch software. However, in my case when I toggle the a/c switch on the dash, the status does not change. It seems like the circuits are not getting the message to turn the compressor on. Does that indicate anything that I should specifically look for?
    Thanks!
  22. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,669
    Central NJ
    Dominick
    toggle the relay thru the launch and see what happens
  23. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,641
    England
    Mark
    A/C will not work if there is low refrigerant: there's a pressure switch incorporated into the system which acts as a safety cut-off.
    flash32 likes this.
  24. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,302
    San Jose
    dc
    Smartest first attempt fix is to disconnect the battery and wait. Reconnect and see if having no AC active.
  25. Snapshift
    735
    Centralia IL
    Lyle D. Pahnke
    Based on my experience with the F430 A/C, if the system is empty of refrigerant, the safety switches (pressure sensitive) will NOT allow the compressor to run under any circumstances, thus saving it from destruction with no lubricating oil.
    Attempting to charge it with a DIY kit does NOT have enough pressure to put in enough refrigerant to get the safety switches to close and run the compressor. You need to have the system professionally evacuated with a vacuum pump then pressure filled with the required weight of refrigerant specified for your system.
    The static resting pressure of the system at idle on both sides Hi and Lo, is around 90psi and the DIY kits generate around 30-35psi, so that's why you are unable to get the proper charge to run the compressor.
    There are a few ways to jump the switches, (Lots of trouble to find and access ) but this is the safest and simplest way to handle this problem in my experiences.
