My 83 QV Resto | Page 2 | FerrariChat
My 83 QV Resto
Discussion in 'Mondial' started by wilkrod, Oct 12, 2020.
  1. dave80gtsi
    dave80gtsi Formula 3
    1,813
    Ohio
    Dave Meredith
    Why not try to find a 328 crank?
    It's the 'Poor Man's Stroker' crank, and all that it would cost you would be the crank itself since you are ordering new pistons anyway.
  2. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    15,978
    Menlo Park, CA
    Paul Chua
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,827
    Isle of man- uk
    Nice calendar on the back wall
  4. wilkrod
    wilkrod Karting
    May 9, 2012
    178
    Ocala, Fl
    Finished measuring all the cylinder liners today, all within spec for I.D., and ovality, whew! Will need to order an aluminum oxide hone from Goodson. Back to scraping gaskets, boy does that suck, can't wait for reassembly!
    Testa
    Jeff
  5. SamuliS
    SamuliS Formula Junior
    Aug 23, 2008
    336
    Finland, Helsinki
    Samuli S
    Nice build. What ECU will you be using?
  6. wilkrod
    wilkrod Karting
    May 9, 2012
    178
    Ocala, Fl
    ECU is MegaSquirt is MS3/EX, see original post, ECU, and Jenvey ITB's.
    I am having an issue finding hi comp pistons/liners, may just stuff the originals in with new rings.
    Jeff
    SamuliS likes this.
  7. wilkrod
    wilkrod Karting
    May 9, 2012
    178
    Ocala, Fl
    So Holidays almost over, so here is an update.
    Ordered JE pistons, 10:1, no delivery date yet. New steel liners from Superperformance, should be here next week. Complete engine/head gasket kit, next week delivery. Destra head cleaning is complete prior to delivery to machine shop for a .003 skim. Valve guides well within spec, no issues will leave in place. Valves also in spec, will be soda blasting next week. When head is done will lap valves. Need to check springs also. Sinestra head is still being cleaned, I freaking hate scraping gaskets!!!! Block had it's first cleaning the other day, can't figure out how to get the cam drive inner bearings out. Thats it for now.
    Testa
    Jeff
    stekkefun4, moysiuan and Big Swole like this.
  8. Big Swole
    Big Swole Karting
    Jun 20, 2020
    220
    Metro Atlanta Area
    David
    Subscribed!!
  9. wilkrod
    wilkrod Karting
    May 9, 2012
    178
    Ocala, Fl
    Big Swole likes this.
  10. wilkrod
    wilkrod Karting
    May 9, 2012
    178
    Ocala, Fl
  11. wilkrod
    wilkrod Karting
    May 9, 2012
    178
    Ocala, Fl
    davem and Jeka like this.
  12. 350HPMondial
    350HPMondial F1 Veteran
    5,187
    Edwardo
    omg,, it’s a coupe. ,,
    bravo,,!
    coupes are a better drive,, and better then a Ferrari 308 model.
    keep going.
    and, JE pistons are bullet proof.
    I( ask me how I know. )
    and,, liners ,, ???
    well they deform under torque.
    ( a F1 motor problem. )
    so,, bore and ,, gone under torque.
    I have a torque plate. You can borrow.
    and,, etc,, etc,,
    nice car Ferrari brother.
    Ed
    aka....
    350HPMondial.
    ,, Yes,, and get Scotty’s Cog belt pulley system ,, for the can drive.
  13. 350HPMondial
    5,187
    Edwardo
    I love that year. CIS is simple.
    ( like mine,,, whew)
    or ,, add a port injection system. yep,, if sleeves are needed,,,?
    call LA Sleeve.
  14. wilkrod
    wilkrod Karting
    May 9, 2012
    178
    Ocala, Fl
    Thanks Edwardo,
    You have a great thread going also!!
    I am going with ITB F.I.
    Bought new steel liners 81.5mm from Superformance, JE pistons are 10:1 for 81.5 mm bore if I ever get them!
    How do I get Scottys cog system?
    Regards
    Jeff
  15. 350HPMondial
    5,187
    Edwardo
    Scotty sold that COG system to Forza , up in Washington. (
    Good luck,, keep going.
    ( ha ha ,,,, it’s a “ hobby”,, supposed to make your blood pressure go down. )
    lol
    Eduardo
  16. GordonC
    GordonC F1 Rookie
    4,119
    Calgary, AB, Canada
    Gordon
  17. wilkrod
    wilkrod Karting
    May 9, 2012
    178
    Ocala, Fl
    Cleaning exhaust valves!!
    It sucks, doing them on the lathe with paper, and polish.
    Contacted Forza for a quote on their timing system, and the JE pistons have shipped, yeah!
    Testa
    Jeff
  18. wilkrod
    wilkrod Karting
    May 9, 2012
    178
    Ocala, Fl
    Valves cleaned up, finally! I use a 12 step process with my lathe. 80 grit, thru 2000, followed by metal polish, takes about 1/2 hour per valve, 32 valves, do the math! Those two on the left fail for TIR, spec is .040 mm, they are about.080 mm, got slightly bent somewhere along the line. Next is lapping the valves to the seats, or maybe a beer or two. Oh, and JE pistons are in, man they are beautiful!
    moysiuan likes this.
  19. wilkrod
    wilkrod Karting
    May 9, 2012
    178
    Ocala, Fl
    Making progress, first re-assembly of this project! Sinestra head has all valves installed, whew, lots of work to get to this point. Destra head is next, then start re-assembly of short block. I think it's all down hill from here.
    Testa
    Jeff
    Jeka likes this.
  20. wilkrod
    wilkrod Karting
    May 9, 2012
    178
    Ocala, Fl
    Look what I fished out of the Destra head water jacket!!!!
    I could hear something rattling around in there as I was getting ready to lap the valves. Took two days to find it and fish it out. By the looks of it, has been in there for sometime, oh well. The Borescope is your friend.
    On to valve laping
    Testa
    Jeff
  21. wilkrod
    wilkrod Karting
    May 9, 2012
    178
    Ocala, Fl
  22. wilkrod
    wilkrod Karting
    May 9, 2012
    178
    Ocala, Fl
    So, Mr. Destra, and Mr. Sinestra cylinder heads are rebuilt. Starting to assemble the valve train for Mr. Sinestra. Spent the day UltraSonic cleaning the shims, buckets, and cam caps. I may be slow, but I am through. Five bucks says I have this thing running by my Birthday. Any takers?
    Testa
    Jef
  23. wilkrod
    wilkrod Karting
    May 9, 2012
    178
    Ocala, Fl
    So, Mr. Sinestras valve train is all installed! Small to do list once the head is installed on the block. Mr. Destra is next. Just want to share how much time this **** takes, probably 4-5 hrs./day, 5/6 days a week to get to this point. Don't attempt this if you have a day job, it will never get done. This car sat for about 5 years while I was working, never got **** done to it.
    Testa
    Jeff
    Nicolas21 likes this.
  24. wilkrod
    wilkrod Karting
    May 9, 2012
    178
    Ocala, Fl
    Well, it would seem I made TWO mistakes recently! While cleaning up my bench after installing the valves in Mr. Sinestra, and Mr.Destra I found a valve stem seal, and a valve stem seal compression spring. Hmmm, not good, so I inspected both heads with a borescope to verify all seals were present, and they were. Good, I didn't forget to put one, just didn't count all the seals before I started. Now for the difficult part, had to verify each seal had it's compression spring. After many tedious hours with the borescope, I thought I found a seal without a spring. So popped out the suspect spring assembly, and sure enough, no spring. I must have installed the seal without the spring, stupid. Lesson learned, lest beer, more attention to detail.
    Testa
    Jeff
    afterburner and Nicolas21 like this.
  25. wilkrod
    wilkrod Karting
    May 9, 2012
    178
    Ocala, Fl
    So, heads are done, moving on to the block. Have new pistons, and cylinder liners, which need to be fit to the block. So made a fixture on the lathe to support the liners so I can turn them down to hand fit to the block. Liners are held in the lathe chuck, and supported on the other end by a live center, can take them down in increments of .0005" fingers crossed, and no beer until finished.
    Testa
    Jeff
    GordonC likes this.
