My 812 Order is in | Page 6 | FerrariChat
My 812 Order is in
Discussion in 'F12/812' started by wrs, Jan 2, 2020.
  1. SirPouyan
    SirPouyan Karting
    180
    SirPouyan
    White is cool but on the 812 GTS the roof assembly lines are very wide and will stick out, black on white.
    This is one reason I am doing mine in Rosso Corsa. I was seriously considering Pearly White before someone on this board pointed out this issue.
    wrs and Gianfranco341 like this.
  2. FerrAli
    FerrAli Rookie
    Jan 25, 2020
    23
    Germany
    Hi,
    my 812 is arrived to the dealer, but we pickup in 4 Weeks.
    Doug23, stavura, Thecadster and 3 others like this.
  3. Gianfranco341
    Gianfranco341 Karting
    Sep 12, 2017
    248
    Gianfranco
    Very interesting if your has GPF because mine is very closed to your serial number : last 3 digits 827. I think mine is still in Maranello even if they have already announced its completion but since 14th of March factory and Italian dealer are on lock down
    Caeruleus11 likes this.
  4. FerrAli
    FerrAli Rookie
    Jan 25, 2020
    23
    Germany
    #129 FerrAli, Apr 15, 2020
    Hi,
    my last digits is ..816, but I don’t now if my 812 has GPF or not.
  5. LMH
    LMH Karting
    May 5, 2019
    205
    Spain
    Ask the dealer for the MODIS codes. Your dealer knows them even before arrival. Mine:
    F152DB 2P V12 EURO6D GPF EU AD
  6. Gianfranco341
    Sep 12, 2017
    248
    Gianfranco
    I asked at least 4 times , no answer .
  7. wrs
    wrs F1 World Champ
    13,985
    Lakeway, Texas
    William
    Probably doesn't want to disssapoint you with the GPF.
    Thecadster and Gianfranco341 like this.
  8. Gianfranco341
    Sep 12, 2017
    248
    Gianfranco
    I think too
  9. FerrAli
    FerrAli Rookie
    Jan 25, 2020
    23
    Germany
    Hi,
    so I get the Information.
    Vehicle Group:
    812 Superfast MY20 ADAS EU6D
    What is the difference between with GPF and without GPF
    Doug23 likes this.
  10. Gianfranco341
    Sep 12, 2017
    248
    Gianfranco
    So also mine will have it . Big differences :
    1) at idle sound is nothing compared to a ne without GPF
    2) raising rpm sound is coming but not like the one without
    3) they had to tune the engine at higher power because GPF is eating some power . Rumors saying you will loose anyway few hp . As a mechanical engineer I don’t like the idea to have an obstruction to the exhaust stressing more the engine with higher temperature and tuning up and having not such amazing sound
    456-boy and LMH like this.
  11. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,549
    Bournemouth, UK
    Really doubt that. The V-Box will give the answers though.
  12. Gianfranco341
    Sep 12, 2017
    248
    Gianfranco
    This is what I’ve heard . The fact GPF is an obstruction in the exhaust is clear as the raising of temperature as a loss of power . May be with a proper tuning they went back to 800 HP but rumors are saying you loose anyway 7-8 hp and it will be really difficult to check such small amount on 800 hp engine
    LMH likes this.
  13. wrs
    wrs F1 World Champ
    13,985
    Lakeway, Texas
    William
    Here are some non-GPF numbers from Vbox this weekend.
    Thecadster likes this.
  14. Doug23
    Doug23 Karting
    Jun 23, 2017
    194
    Italy
    What kind of code is "F152DB" ? Engine codes should start with F140 , while chassis code is F152BCE (as shown by @FerrAli )
  15. TWCC
    TWCC Karting
    Apr 27, 2020
    56
    812 doesn't have 800 hp anyways...more like 750...POG put it on a dyno (go to 8min50sec for the results)
  16. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,549
    Bournemouth, UK
    This is not a bench dyno, it's a rolling road, and they are notoriously unreliable.
  17. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,601
    Austin TX
    If your 812 has less than 2000 miles on the odometer you are not at full power yet...the first let-out occurs just after 500 miles, it is significant and than another around 1200 and, less confident on this, but understand after 2K miles you have access to full power...
    LMH likes this.
  18. wrs
    wrs F1 World Champ
    13,985
    Lakeway, Texas
    William
    OK, this sounds like what they used to say about the M5 and I always thought it was questionable. Is this just a break in mechanism that is true across engines or something the factory has programmed in? The claim was that at 1200 miles on the M5 there was a marked improvement in performance and power and it was by design, in the software.
  19. TWCC
    TWCC Karting
    Apr 27, 2020
    56
    ok thanks for the input...i am not expert, however there are two other dyno instances on youtube (vehicle virgins and dragtimes) where the implied drive train loss is 17-20% which is significant and indicates that actual hp is below stated in the high single digit %....also POG in his video says that he dyno'd his 458 S and it was also c. 10% below stated power
    has anybody done a reliable dyno test on the 812?
  20. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,601
    Austin TX
    It's part of the factory engine controller programming, it does not matter the engine, it is how they can control break-in
    wrs likes this.
  21. wrs
    wrs F1 World Champ
    13,985
    Lakeway, Texas
    William
    OK well I will definitely be going back out there to do more testing, maybe this weekend. I did some more practice with the CT OFF yesterday and PS. I was able to get that combination to work. I was not sure of the stopping distance or what speeds the car would achieve and so I moved back from my normal starting point. That point that I took is more uphill at the start than say 100 feet further up the road. That can make a big difference in the 60ft time so I bet I can get a better ET just moving forward on my start. As to the issue of power being greater with more miles, that will show up in the trap speed.
    I had looked on line and there is a claim that the 812 can do 10.4 @ 141mph in the quarter but I bet I can't achieve that out on my test road. However, if I could get 10.5 @ 137 it would be as good as my 725hp tuned 991tts was at the drag strip with race gas. Out on that road it did a 10.4 @ 131. The F cars are faster but it's quicker. Here is the chart of the 991tts. You can see I didn't have as much uphill at the start. It also pulls 1.5g whereas the 812 only did 1g. That's important also and as someone else mentioned that is likely due to the AWD.
  22. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,549
    Bournemouth, UK
    Depending on settings, two identical rolling roads can produce vastly different results. They are useful for comparative purposes only (i.e. the difference between two cars, or before and after a tune). Only a properly set bench dyno, the kind that only engine makers have, can produce accurate readings, as it measures the engine's performance independently of the transmission. This is a bench dyno:
  23. TWCC
    TWCC Karting
    Apr 27, 2020
    56
    tnx for this....i think what i am saying is that there is consistently high implied drive train loss across three 812 tests and one 458 S...which indicates either one of two things...either F are incredibly inefficient brining power to the wheels or actual engine power is below advertised
  24. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,549
    Bournemouth, UK
    Or neither. You cannot really tell by a rolling road.
