Motronic 2.5 vs. 2.7 | FerrariChat
Discussion in '348/355' started by Mike_D, Aug 10, 2010.
  1. Mike_D
    Mike_D Rookie
    Dec 3, 2009
    25
    Hey guys, I am looking at an extemely low milage 348 TS that is advertised as a '91, but I noticed that it has a sensor on the driver side bank on top of the intake manifold. I am not sure, but I believe that indicates it is a motronic 2.5 system, however in researching the 348 it looks like they moved to motronic 2.7 after mid 1990....am I right? Is this a red flag? Does anyone have any comments / feedback regarding the Motronic 2.5 vs. 2.7 on the 348? Is it advisable to avoid the 2.5? Are there any known problems with it?
    Thanks,
  2. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    That does sound odd - 2.5 was on the 89 to mid-90, easily identified by the single throttle position sensor as opposed to the 2.7 which has two. Maybe the motor was replaced with an older unit at some point? The 2.7 has the advantage of allowing you to pull error codes in addition to improved software and mappings.
  3. roadracer311
    roadracer311 Formula 3
    May 6, 2009
    2,398
    San Francisco
    Paul
    Oh, I've been meaning to ask. How does one pull error codes from a 2.7? I've got a 1995 F355 and my business partner has a 1995 348. I've got an OBDII code reader, but am guessing that it's not going to do anything for me on an OBD I car.
  4. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    Courtesy of Ernie and No Doubt:
    http://www.my348.com/348.html#ECUcodes
  5. Jeff Pintler
    Jeff Pintler Formula Junior
    Jul 20, 2005
    537
    Richland
    Jeff Pintler
    There isn't anything worst about the 2.5 vs. the 2.7 and pulling codes on the 2.7 is just as likely to give incorrect diagnosis. If you are really curious, you could get copies of the schematics and compare the differences. For example, the thermocouple module on the 2.5 just lights warnig bulbs on the instrument panel vs, the 2.7 also has a wire connected to the Motronic ecu probably to limit engine revs if the cats are overheating. Best advice: buy the car that you like and fix what breaks. FWIW
    Jeff Pintler
    89 348tb (2.5), 86tr, 99 360 3 pedal
  6. Ricky_rkt
    Ricky_rkt Rookie
    Mar 30, 2021
    42
    Madrid, Spain
    Hi guys,
    I was talking to my mechanic in regards of what I read in this discussion to tell the difference between a 2.5 or 2.7. I told him about the throtle position sensor (my 348ts has two). Is there any other way to see easily if it is a 2.7?. Do you have any pictures of a 2.5 vs 2.7 to compare?. Thanks!.
  7. m.stojanovic
    m.stojanovic F1 Rookie
    2,752
    Malaysia - KL
    Miroljub Stojanovic
    In addition to seeing two TPS-s, you can re-confirm that it is a 2.7 by looking at the ECU number:
    2.5: Bosch 0 261 200 190
    2.7: Bosch 0 261 200 457 (TB/TS) or 0 261 200 489 (Spider & Challenge) or 0 261 203 327 (superseded the 489)
    There might have been other Bosch numbers for the 2.7 for certain markets/countries but, as far as I know, there was only one number, the "190", for the 2.5.
  8. Ricky_rkt
    Ricky_rkt Rookie
    Mar 30, 2021
    42
    Madrid, Spain
    Thanks a lot!, Forgive me if my next question is stupid. It is a dignostic tool to get the number or is it visible from the outside?. My mechanic has a Leonardo and if I am nor wrong it is OBD2. Any OBD2 to OBD1 converter would work?. The 348 has OBD1, correct?
  9. m.stojanovic
    2,752
    Malaysia - KL
    Miroljub Stojanovic
    You just open one of the covers of the ECU compartment and you will see the Bosch number on the ECU on a yellow sticker. The 348 has "vintage" ECU-s, no OBD.
