Motor Oil Grade for Dino. | FerrariChat
Discussion in '206/246' started by UroTrash, May 23, 2008.
What do you put in your Dino?
  1. Single Weight mineral, please post a spec
  2. Thinner than 10-W40 mineral
  3. 10-W40 mineral
  4. 20-W50 mineral
  5. Thicker than 20-W50 mineral
  6. Synthetic or blend, any weight
  7. Other, please post a spec
Multiple votes are allowed.
Results are only viewable after voting.
  1. UroTrash
    Jan 20, 2004
    40,197
    Purgatory
    Clifford Gunboat
    #1 UroTrash, May 23, 2008
    I search and I can find no clear opinion of grade of oil to use in a Dino.
    Please vote in the poll.
  2. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    I use 0-60 Helix. 15-50 Q also seems to work well. I have used 40W Rotella in the past.
  3. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    Castrol GTX 20-50 (My vote is in.)
  4. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    MOTUL 300V Le Mans 20W60
  5. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    I just checked the manual. "Shell Super 100" for normal use and Shell 10W-30 for very cold (below 5F!) weather. Of course, Shell was a sponsor, so that's why they're recommended. I'm guessing that Super 100 was a 20W-50, but it doesn't say so in the book.
  6. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,427
    wisconsin/chicago
    bo
    What about the whole ZDDP issue? My understanding is that the 20-50 high mileage oils are still okay, such as Castrol or Valvoline high-mileage.... Unless you want to go Brad-Penn, etc...
  7. dm_n_stuff
    there are several threads on the additive question. Yes, it is also my understanding that the high mileage, and motorcycle use oils both have higher levels.
    As to which oil to use? 20W-50 all the way.
    Uro - it is what is in there now, it is what has been in there since the day I bought it. I've used Royal Purple and Castrol. I did not make the switch to high mileage oil when the talk of additives started. I considered going to Brad-Penn last change, but did not.
    OH, and DON'T USE SYNTHETIC. Your car will leak like a guy with a bad prostate if you do.
    DM
  8. marco246
    marco246 Formula Junior
    Mar 25, 2004
    288
    Hawaii
    Mark
    A few years ago when I was in the market for a Dino I checked with a Shell oil engineer who told me Shell Super 100 was 10W-40. He also recommended (of course) a Shell product--Rotella T Synthetic 5W-40--for use in the car IF the engine had already been rebuilt and the original seals replaced.
    Regarding the ZDDP issue, the Shell Rotella mentioned above is a heavy duty engine oil meant for mixed fleet (diesel and gas) use and has plenty of zinc and phosphorus. I'm now using this oil in my 328. No need to go to a 20W-50 unless other reasons drive such a decision.
  9. MRONY
    MRONY Formula Junior
    Mar 17, 2007
    707
    New York City
    Mike O.
    I ordered a case of the Swepco oil. The Ferrari mechanic here (out East) had never seen it. Seems the West coast guys swear by it, and it's all that was ever used in my car. Folks at Southwest Petrol couldn't have been nicer about shipping it to me.
  10. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Just for giggles, Google "Exxon Elite", its a 20W50 aviation oil that lays claim to being the only third generation av oil out there. Its a semi-synthetic and highly reputed but I haven't tried it yet in my Dino. Go to the wear charts and check out the comparisons, very impressive. It could replace the 15W50 AeroShell I have in it now.
  11. Slim
    Slim Formula 3
    Oct 11, 2001
    1,735
    Pacifica, CA, USA
    richard
    Not only did I use Castrol GTX 20w50 in the Dino (246) engine and in all my Fiat engines, but I've used it in most of my gearboxes as well: both ZF and Fiat transmissions (fyi, a 50w motor oil is like a 90w gear oil). Probably 150,000 miles of driving old Italians over the last ten years or so with no problems.
    Sometimes I'll use Kendall motor oil in the engine instead when I happen to have it handy. But the Castrol I can buy anywhere so it gets used 90% of the time.
  12. greg246
    greg246 Two Time F1 World Champ
    Jun 2, 2004
    26,587
    Not my experience. I run a synthetic 10w50w and absolutely no leaks. Suggest you get your prostate looked at :)
  13. UroTrash
    Jan 20, 2004
    40,197
    Purgatory
    Clifford Gunboat
    I've used castrol all my life with the exception of Mobil 1 in certain engines, so Castrol GTX 20-W50 it is. Thanks gents!
    BTW, with the Baldwin B253 filter !
  14. GIOTTO
    GIOTTO F1 Rookie
    Dec 30, 2006
    3,886
    France
    I use Motul 300V since 1982...
  15. Julio Batista
    Julio Batista Formula 3
    Dec 22, 2005
    2,397
    Motul 300V LeMans in all my cars.
  16. abstamaria
    abstamaria F1 Rookie
    Feb 11, 2006
    2,668
    Andres
    I voted. I have had good experience with Redline gear oils, and am shifting to their synthetic motor oil shortly.
    Andy
  17. MRONY
    Mar 17, 2007
    707
    New York City
    Mike O.
    I forgot to add the weight. It seems to work wonders.
  18. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    With all due respect, this thread is the blind leading the blind. Go to www.bobistheoilguy.com and do some reading.
    While oils like GTX used to be fine for Dinos, manufacturers have been forced to decrease zinc and phosphate levels in oils sold for current gas engines. Cars with non-roller bearing cam followers like ours need more zinc -- which is what the oils approved for both gas and diesel engines provide.
    Regarding weight-- it depends on how you drive the car. If you track the car or drive somewhere where you see high oil temps a lot, the 20-50 probably makes sense. Back when these cars were new owners would likely run on the autostrada for a few hours at 130mph and they needed the high viscosity for that use. (But I have also read that the Shell 100 was more like 10-40 than 20-50.)
    The high-mileage 20-50s are VERY high viscosity (over 18 as I recall) and you will get poor lubrication upon startup. (10-40 is in the 14's, 20-50 about 16, if I recall correctly.)
    The best choice of any old car is one of the gas-diesel approved ones like Rotella, Delo, or Delvac.
    I used to use Castrol GTX 20-50 under the mistaken belief that that was what I should use, then I switched to Mobil 1 red top 15-50 because it had good low-temp viscosity numbers until Mobil reformulated it to the junk "EP" gold top, then I switched to Rotella T synthetic 5-40.
    I did not note any significant change in oil leakage when I switched to synthetics-- these engines tend to "weep" oil anyway.
    Whatever you do, do NOT use an oil marked "energy conserving" in your old car.
    Jim
  19. Slim
    Slim Formula 3
    Oct 11, 2001
    1,735
    Pacifica, CA, USA
    richard
    #19 Slim, May 27, 2008
    I won't comment on bob the oil guy, but you do make a good point about the zinc. It's easy enough to use one of the commonly available additives (lucas or 4-cyl stp for example) if there are any owners out there driving the cars enough to be worried about premature cam wear. I don't have the Dino anymore but I do put about 20k miles a year on a lesser Italian with the same cam and shim setup every year and personally I'm not that worried about lack of zinc.
  20. JCR
    JCR F1 World Champ
    10,762
    H-Town, Tejas
    ZDDP is what has been traditionally used to deliver phosphorus to the valvetrain. What the API reduced was the limits on phosphorus, not zinc.
  21. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
  22. UroTrash
    Jan 20, 2004
    40,197
    Purgatory
    Clifford Gunboat
    #22 UroTrash, May 28, 2008
    Sounds like a good motorcycle oil would work well, because of the additive package.
    Or maybe Rotella..... I'm confused now.
