Most 458s Discussions!! | Page 5 | FerrariChat
Discussion in '458 Italia/488/F8' started by F485, Nov 27, 2017.
  1. GT2goneF
    GT2goneF F1 Rookie
    May 28, 2020
    2,861
    Southern California
    I saw that this on morning news. Dumb 22 and 20 year old. Wipeout at a curve with rollover. Kids were not injured. It will be a fun bill to pay if they didn't get insurance. Just a scratch. It will be back on the road in no time. You won't even be able to tell it was dented.
  2. F485
    F485 Karting
    Oct 23, 2017
    166
    Abu Dhabi, UAE
    Fahad F458
  3. F485
    F485 Karting
    Oct 23, 2017
    166
    Abu Dhabi, UAE
    Fahad F458
    Finally, I found the procedure to check the 458 DCT fluid leve
    Repairing my FERRARI 458 OIL LEAK and How To check the DCT Fluid Level
    normalguysupercar.com/repairing-my-ferrari-458-oil-leak-and-how-to-check-the-dct-fluid-level/
  4. F485
    F485 Karting
    Oct 23, 2017
    166
    Abu Dhabi, UAE
    Fahad F458
    While on the Bullrun GT Rally, I noticed that my Ferrari 458 was leaking oil. It turns out that I must have damaged the Transmission’s DCT Hydraulic line while installing my S-Line exhaust. That in turn was causing the car to leak DCT fluid. Josh sourced a DCT oil line for me and I replace the oil line to stop the leak. Then Josh and I top off and check the DCT fluid level. It’s a strange process to check the DCT Fluid level.
    It’s easiest with 2 people as the engine must be running and you must have the car in Reverse with your foot on the brake. The engine coolant temp needs to be between 40-50C which is only about 110-120F and the DCT fluid must be below 80C. This means you have to work fast otherwise you’ll have to let the car sit and cool down for quite a while.
    Checking the fluid is done by pulling out the DCT fluid plug on the left side of the transmission. A little bit of DCT fluid will spill out every time, but if it only splashes out and doesn’t continue to dribble out, you are low. If it streams out continuously, then you have too much. You basically overfill it then wait for it to stop draining out. It’s a strange system.
    milanojess likes this.
  5. F485
    F485 Karting
    Oct 23, 2017
    166
    Abu Dhabi, UAE
    Fahad F458
  6. Robert Collins
    Robert Collins Karting
    May 10, 2020
    70
    Robert S. Collins III
    Thanks to the OP for taking the time to do this for all of us! What an incredible resource, especially for a Ferrari and 458 rookie!!!
  7. DETAILMD
    DETAILMD Rookie
    Apr 22, 2021
    16
    billings, MT
    STEVEN KUCHURIS
  8. bball16
    bball16 F1 Rookie
    3,863
    NY LI FtL
  9. wthensler
    wthensler F1 Rookie
    3,152
    Gator Country, FL
    William
    Just had my 13’ Spider in to my mechanic for fluid changes, general check over, etc. Approaching 25,000 miles and no problems since I purchased it with around 2k on it. I drive it a lot and run it hard, especially during my Appalachian extravaganzas.
    Good news - no leaks, did a brake fluid flush and oil change and checked over the entire car. No problems except that he recommended to change out the expansion tank next time as he saw a few fissures.
    It is hot in the FL summers, so I’m sure the coolant system is stressed, plus with the spirited driving ai do.
    Just a heads up for those with 458s, you may want to have them checked.
    Ianjoub, jc1 and Tarek307 like this.
  10. wthensler
    wthensler F1 Rookie
    3,152
    Gator Country, FL
    William
    Forgot to mention, I did the plugs, air and cable in filters at 20,000 miles (car is 8-1/2 years old after all) and DCT change will be next up.
    I’m also gonna put in Novitec springs and maybe 11/15mm spacers too. I had a SS Kline put in a year ago and I am happy with the sound.
  11. RBarbieri
    RBarbieri Karting
    Feb 11, 2014
    227
    Bradenton, FL
    Rich Barbieri
    My 2014 is approaching 30,000 miles and knock on wood has been trouble free. I've had the DCT fluid changed, brake fluid flushed and all normal maintenance. I'm getting ready to change the coolant and changing the plugs is on my to do list.
    Rich
  12. Ianjoub
    Ianjoub Formula Junior
    Dec 22, 2019
    901
    Homosassa, FL USA
    Ian Joubert
    I had to change my rad overflow tank, cracked.
  13. Ianjoub
    Dec 22, 2019
    901
    Homosassa, FL USA
    Ian Joubert
    I should have changed my plugs when I did the overflow tank. There was one bolt too hard to reach from under the engine cover. I had to remove the plate under the convertible top storage area. Once I did that, the plugs were staring me in the face.
  14. djyesh
    djyesh Rookie
    Jun 21, 2021
    3
    india
    yeshwanth subash
    very informative.thanks for the effort!!
  15. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    17,996
    michigan
    john
  16. GT2goneF
    GT2goneF F1 Rookie
    May 28, 2020
    2,861
    Southern California
  17. plastique999
    plastique999 F1 Veteran
    Nov 9, 2008
    8,574
    SoCal
    Edward
  18. Stams
    Stams Formula Junior
    494
    Colorado
    Sean
  19. sunghyun7
    sunghyun7 Formula Junior
    Oct 7, 2019
    253
    looks like a girl's car. she made her own. good for her.
  20. ferrari 512 tr
    ferrari 512 tr F1 Rookie
    Nov 16, 2008
    4,178
    Australia
    Paolo
    Gents just a question,
    why don’t some 458’s have the rev lights on the steering wheel? I thought they came as standard? Or is it only the early ones produced that do not have them?
  21. rob5819
    rob5819 Formula Junior
    Dec 12, 2017
    819
    San Diego
    Rob Barry
    It's an option: CARBON FIBRE DRIVER ZONE+LEDS CIDL $7420.
    Rob
    ferrari 512 tr likes this.
  22. GT2goneF
    GT2goneF F1 Rookie
    May 28, 2020
    2,861
    Southern California
    Steering wheel option. CF with shift lights. Regular without.
    Sent from my BLA-A09 using FerrariChat.com mobile app
  23. ferrari 512 tr
    Nov 16, 2008
    4,178
    Australia
    Paolo
  24. ferrari 512 tr
    Nov 16, 2008
    4,178
    Australia
    Paolo
    CF driving zone obviously means carbon fibre
    Roberto, What does CIDL stand for
  25. rob5819
    Dec 12, 2017
    819
    San Diego
    Rob Barry
    Not really sure how they come up with the codes for the options. I'm just pulling the info off my build sheet for the 458 Spider. Other carbon fiber option descriptions / codes / prices on the 458:
    OUTER CARBON-FIBRE B-POST TRIM CERF 3553
    CARBON FIBRE REAR MOULDING GRDC 4015
    CARBON FIBRE CENTRAL BRIDGE CIRL 2518
    CARBON FIBRE DRIVER ZONE+LEDS CIDL 7420
    Similarly for the Portofino M:
    Carbon Fibre Driver Zone+Leds CIDL - 7,593
    Carbon Fibre Central Bridge CILR - 2,869
    Exterior Sill Kick In Carbon CISK - 2,025
    Carbon Fibre Cup Holder CITP - 2,531
    Carbon Fibre Dashboard Inserts DATR - 4,387
    If there is a pattern for the codes I definitely do not know it, but they seem to be mostly the same for different models.
    Rob
