Mondial T oil top up | FerrariChat
Discussion in 'Mondial' started by Black/black612, Apr 5, 2020.
  1. Black/black612
    Black/black612 Karting
    Apr 9, 2014
    73
    London
    Sebastian
  2. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Two questions;
    1. Was the cap on tight enough (good sealing)?
    2. Is the car driven for only short trips?
    Reason, during cool-down it might be sucking in condensation.
  3. John Hasty
    John Hasty Rookie
    Jul 16, 2019
    37
    John H. Hasty
  4. John Hasty
    John Hasty Rookie
    Jul 16, 2019
    37
    John H. Hasty
    Any loss of water ? Running ok, any head gasket problem?
  5. Black/black612
    Apr 9, 2014
    73
    London
    Sebastian
    1- yes I think the cap was tight but will check tomorrow
    2- correct mainly short trips
    And the car was cooling down
  6. Black/black612
    Apr 9, 2014
    73
    London
    Sebastian
    Water level is perfect - so no
  7. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    That's a common problem with consistently short drives, especially in cooler/wetter areas.
    Check for gooage in the coolant tank as well.
    But my guess is that you're okay. Just take the car out for a nice longer drive when you can.
    ronfrohock likes this.
  8. Black/black612
    Apr 9, 2014
    73
    London
    Sebastian
    Thank you for taking the time for all your answers. Seb
  9. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    Yes, you need to do 1 of 2 things: 1) stop driving short trips and just let the car sit. 2) take it out for a long long drive.
  10. Albert Penello
    Albert Penello Karting
    Jul 21, 2019
    165
    Woodinviille, WA
    Albert J Penello, Jr.
    This is exactly a symptom of the oil getting hygroscopic and collecting water. Not the same as the water coming from a leaking gasket. What does your dipstick show?
    Clean it out, change the oil and filter, and run the car to get it nice and hot.
  11. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    15,983
    Menlo Park, CA
    Paul Chua
    Sorry for my ignorance friends, but what is that yellow slimy substance?
  12. Albert Penello
    Jul 21, 2019
    165
    Woodinviille, WA
    It's condensation in the crankcase, mixed with oil vapors. It happens when cars sit for a long time or don't properly get up to temperature to burn off water in the system.
    A byproduct of combustion in water. That water condenses in your exhaust system, crankcase, etc. It's normally not a huge problem because the temps burn it all off. But if a car sits for a while, you can get stuff like this in your oil system. It's not great but it's not the end of the world.
    Clean up what you can with a rag. Go for a long drive and get the car up to temp, change your oil, and repeat :)
    Don't let the car sit for long periods or let it sit in moist environments.
    paulchua likes this.
  13. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Mixing engine oil with water vapor equals yellow goop after it cools.
  14. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    15,983
    Menlo Park, CA
    Paul Chua
    Thank you kind sirs, I did not know this, I appreciate the education.
    Best to you both!
    Albert Penello likes this.
  15. yelcab
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    It looks like foamy cappuccino. That may be good for your breakfast but not for your car.
  16. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    15,983
    Menlo Park, CA
    Paul Chua
    Damn, I just poured some coffee into my tank this morning. I figured the caffiene would give it extra octane!!!
