Hi everybody. Any ideas why is my Mondial T RPM so low? Please see foto.Thanks! Image Unavailable, Please Login
Remove the gauge from the car and have it calibrated by a Speedo shop. Contact @paulchua and he will tell you what he did to solve this exact problem.
Hi Donatas, very easy to remove... the instructions: Around the tach there is a black, square, plastic frame. To remove, I used a scraper made of plastic so as not to damage the frame. It is just held in place by 4 plastic knobs which are a press fit into 4 corresponding holes. Just gently pry against the side of the frame and it should pop out. This exposes 4 self tapping screws . one at each corner of the tach. Remove these and the tach comes out. Before removing any wires, I recommend writing the color of the wire at each connection on the white plastic of the tach. send to Palo Alto speedometer first call Hartmut tell him do same thing you did for Paul Chua. cheers
He's got a bump shock actuator, or something else related to the suspension system. If he had started the car 3 times and not move it, the light comes on.
