Mondial QV won't start | FerrariChat
Discussion in 'Mondial' started by fasterinred, Apr 25, 2013.
  1. fasterinred
    fasterinred Rookie
    Apr 25, 2012
    11
    Chester, UK
    Dean Paul
    My QV stopped after being at the paint shop. The battery had been disconnected during welding and the terminals were loose. I tightened the terminals. Now it turns over but won't fire up. There is power at the coils. I pulled a plug out and turned it over, but I saw no spark at the plug. The fuel pump runs with the key in position II. Where should I look next?
  2. Steve Magnusson
    25,145
    #2 Steve Magnusson, Apr 25, 2013
    These are two different issues.
    With regard to "no spark during engine cranking" -- can we assume that you had the threaded portion of the (removed) spark plug connected to engine ground during the test? There are very few single problems that can take out both banks of the DigiPlex ignition at the same time -- no power to the coils (so you seem to have already ruled that out), the RPM flywheel sensor not working, loss of common ground at the DigiPlex ECUs, etc.. If you have truly confirmed that BOTH banks have no spark during engine cranking:
    1. measure the resistance between the two terminals of the RPM flywheel sensor when unplugged -- should be ~700 Ohms. If zero Ohms = replace RPM flywheel sensor; if resistance measures OK = go to step 2.
    2. measure the AC voltage output of the RPM flywheel sensor during starter motor cranking (with it now plugged in) -- should be something like ~2V AC (IIRC).
    With regard to "The fuel pump runs with the key in position II" -- are you saying that:
    A. you had modified the system to intentionally make this happen so you know for sure that the fuel pump is working, or
    B. The fuel pump (correctly) didn't used to run with the key in Position II (when the engine is not running), but now (suddenly) it does with the key in Position II when the engine is not running. If the behavior suddenly "changed", my guess would be that the center plunger in the fuel distributor is sticking so the plate in the airflow metering device is not returning to the rest position (which leaves the safety switch open). The test here would be to mechanically inspect the smoothness/motion/return of the airflow metering plate when the system is at zero fuel pressure (i.e., fuel pump off, and crack open the cold start injector fitting to ensure the fuel system is at zero pressure -- use a rag around the cold start injector fitting when opening to catch any fuel spray that might come out).
    Good Hunting! How long was the engine not used during the repaint? Saw in your other thread that you had a 6 year period of disuse (was that the repaint?) -- regardless, this can be very troublesome on Bosch CIS injection as any debris/varnish/crude that forms downstream of the fuel filter can get dislodged (at any random time thereafter) and muck-up the fuel distributor or WUR.
  3. fasterinred
    fasterinred Rookie
    Apr 25, 2012
    11
    Chester, UK
    Dean Paul
    I'll, try all those things and report back. Something else I noticed is, there is no power at the fuse for the 'start-valve controls'. Also, I tested for power to both ecus on terminal 8 of their plugs and that is ok.
    It is a sudden thing that the fuel pump is running with the key on. Nothing I have done. I will check the air flow flap under the air cleaner.
    The car was off the road for six years. I took it to Nick Cartwright's in the UK and had it serviced, belts, oil etc. Drove it for a year and then exported it to New Zealand. It went to the paint shop in NZ to have the under body surface rust done. Now all the troubles have started after the battery cables weren't secured by the welder.
    Could the trouble be in the fuse box? The lights won't go up now and the right head lights don't come on at all. All since the car went dead due to the loose battery terminals. Everything worked 20 minutes before that when it went through it's road worthy inspection and I drove it home.
  4. ninot
    ninot Karting
    Feb 7, 2004
    225
    Sunny Staffordshire
    Nino
    A fellow owner here had a similareproblem after paintwork on his 3.2 mondi,
    His theory was that the paint oven had made some contacts on the Fuseboard dry/brittle/warp.
    Mine was in the same oven a few weeks earlier with no problems
  5. abignami
    abignami Karting
    May 20, 2010
    76
    Milano, Italy
    Alessandro Bignami
    Are you sure that the welder had disconnected the battery and all ECU before welding? Welding without doing this it is looking for for troubles if the welding is done with an electrical welder because it can fry the ECU (at least I was told from an expert).
    Check for some paint on the ground connection too. If some paint has gone under a less than perfect connection you are going to have electrical problem.
    I hope that you can solve soon.
    Keep us updated.
    Alessandro
  6. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,844
    NoNJ/Jupiter FL
    Steve W.
    Just a random thought, but how old is the battery? If it is 6 or 7 years old, it may not be holding a sufficient charge, and the voltage may be too low for the Digiplex units. I remember reading that they need at least 11.8V or more to operate properly. I could be wrong here completely, but if the battery is old, you might want to have it tested, and if it is not up to snuff, you might want to replace it.
  7. deeprivergarage
    deeprivergarage Formula Junior
    560
    S of Fort Worth
    Jerry
    I think the SEN-8D is electrically functionally equivalent to the Ferrari 119052 - the exception that the mounting holes may be a bit smaller - but can be drilled out to the correct Ferrari diameter.
    http://competitionsystems.co.uk/uploads/mediacentre/20100526111207-sen_series.pdf
    The SEN-8D is a Magneti Marelli part number but not referred to as such in the above link.
    SEN-8D Magneti Marelli part number is typically priced less than the Ferrari 119052.
    DRG
    Jerry
  8. fasterinred
    fasterinred Rookie
    Apr 25, 2012
    11
    Chester, UK
    Dean Paul
    Thanks for all the ideas.
    I have found that there is no power at terminal 30 at the 'fuel start relay'(t), the 'glass lifter motor' relay(h), the 'low beam mot contr' relay(U) and the 'head lights mot contact' relay(m). When I say this, I don't mean the relay coil power, but the power across the relay on contacts 30 to 87.
    This is strange. Naturally the head lights and windows don't go up and down and the car won't start. Oh! and the electric doors don't work any more. I would blame the paint oven, or the welder. But it started and ran fine for a while, until the battery terminal, which hadn't been tightened, came loose. I have checked the fuse board, but have yet to find a problem.
    There is power from the key switch to both ECU's and both coils, but no spark at the plugs.
    I have been unable to get the plug open to test the RPM sensor. I have checked the ECU earths, and found no problem. The air valve flap is closing all the way, but the fuel pump still runs with the key on position II.
    It is an UK new car. My workshop manual differs from the cover on fuse board as to which relays do what. I'm going with the cover as the one to trust.
  9. fasterinred
    fasterinred Rookie
    Apr 25, 2012
    11
    Chester, UK
    Dean Paul
    I did clean both battery terminals and the earth strap at the isolator and body. I also charged the battery over night. I have 12.8 volts at the fuse block, not great but ok.
  10. fasterinred
    fasterinred Rookie
    Apr 25, 2012
    11
    Chester, UK
    Dean Paul
    Thank you Steve Magnusson. The problem turned out to be a bad connection at the RPM sensor plug in the loom. I learnt a lot
  11. Steve Magnusson
    25,145
    #11 Steve Magnusson, Apr 29, 2013
    No problem Dean -- glad that you got it sorted with minimal grief. No matter how "exotic" the beast, if the starter motor spins the engine, but it won't fire up, we always start at the same place: "gotta be no spark or no fuel -- so rule spark in or out first" ;)
    What about the other issue? -- is the fuel pump still (wrongly) running with the key in Pos II and the engine not running?
    ronfrohock likes this.
  12. sportdevices
    sportdevices Rookie
    Sep 17, 2011
    26
    Alistair PArker
    hi guys hope this thread is still active, my 84 QV just let me down for the 1st time in 10 years! no spark on either bank and no fuel pressure but i can hear the fuel pump, im going to check the crank sensor first and the earth to the ecu's. just slightly confused as to how I have both faults at the same time? suggestions? i will keep you informed,
  13. sportdevices
    sportdevices Rookie
    Sep 17, 2011
    26
    Alistair PArker
    crank sensors check ok at 700 Ohm trieda couple of additional earths and that didn't help, just called the auto electrician.....
  14. theunissenguido
    theunissenguido Formula 3
    Jan 21, 2004
    2,372
    Argent/Brasil
    Guido
    I would look at the coils first...bad/burned contacts of the distributor wires that are going to the coils.
    guido
  15. Steve Magnusson
    25,145
    very unusual...how are you measuring/determining this?
    One thing that could cause both systems to fail simultaneously is a bad ignition switch (although the fuel pump would also not be running). When the key is moved to Pos III (start), it should still also be putting +12V onto the items of Pos II (run) -- which include the ignition and the fuel pump operation items. Measure the voltage on the yellow (IIRC) wires going to terminal 15 of the coils during starter motor cranking -- should be +12V (or maybe +10V since the high current draw of the starter during cranking will cause the battery voltage to droop some). If that's OK, but still no spark on both banks = suspicion has to fall on the flywheel RPM sensor. Even though you measure its resistance is OK, the real operational test is measuring the AC voltage between the two terminal while plugged in = should be ~2 VAC during starter motor cranking.
  16. sportdevices
    sportdevices Rookie
    Sep 17, 2011
    26
    Alistair PArker
    ok we have 12v across the iirc reducing to 10v on cranking, we have no output from the crank sensors while cranking, we do have output from crank sensors if we remove them and pass them by a metal trigger, the flywheel is still on and the crank is not broken so it must be the dowl in the flywheel that triggers the sensors, look like the clutch and flywheel and bell-housing needs to be removed, could be worse it could have been the crank that had snapped
  17. Steve Magnusson
    25,145
    #17 Steve Magnusson, Jul 15, 2019
    Can't easily agree with this deduction. There are two dowels, so. if one fell out = you'd have spark on two cylinders in each bank. If both fell out, that would kill both banks, but I'm skeptical (as the pins have no relationship to the RPM sensor output). You can fairly easily remove one of the TDC sensors and confirm/deny the presence of the pins (2 pins 180 deg apart), before resorting to more serious disassembly. The RPM sensor (which senses the ring gear teeth) should still work (i.e., have a 2 VAC output when plugged in and cranking) even if the pins were gone. If you want to functionally test the output of the two TDC sensors, they should have an output of something like 0.1~0.2 VAC when plugged in during starter motor cranking.
  18. sportdevices
    sportdevices Rookie
    Sep 17, 2011
    26
    Alistair PArker
    ok i will take your advice, it is much appreciated! and look further, i will keep you informed, the sensor that was reading zero ohms had marks on the tip that look like a foreign body had hit it, i agree to loose 1 dowel would be very unusual to loose 2...,?
