Mondial Oil Cooler Fan fixed | FerrariChat
Discussion in 'Mondial' started by AndruL, Oct 22, 2018.
  1. AndruL
    AndruL Karting
    Apr 4, 2018
    234
    AndruL
  2. AndruL
    AndruL Karting
    Apr 4, 2018
    234
    AndruL
    paulchua likes this.
  3. AndruL
    AndruL Karting
    Apr 4, 2018
    234
    AndruL
    Next, checked fan motor by applying 12VDC directly from an external power supply. Fan worked...
  4. AndruL
    AndruL Karting
    Apr 4, 2018
    234
    AndruL
    Then I pulled the relay, checked all signals to the relay connector terminals, 12V from Battery, GND, 12V from ignition coil to energize relay... all checked out.
  5. AndruL
    AndruL Karting
    Apr 4, 2018
    234
    AndruL
    Benched checked the relay. It closes when the coil is energized by 12V, however, could not carry the current to run the fan. Bad, dirty contacts.
  6. AndruL
    AndruL Karting
    Apr 4, 2018
    234
    AndruL
    MvT and moysiuan like this.
  7. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Very cool. Logical troubleshooting and a low cost fix. Gotta love that!
  8. porphy
    porphy Formula 3
    1,209
    LouisvilleKY/Switzld
    Randall Gatz
  9. AUDIO RESEARCH
    AUDIO RESEARCH Formula Junior
    Feb 11, 2009
    394
    PHILIPPINES
    LUIGI RAYMUND LIRA
    Is the plastic replacement a Bosch Brand as well . If it’s Bosch , what’s the Bosch part no. It’s usually stamped on the top .
    Thanks in advance ,
    Luigi
  10. spicedriver
    spicedriver F1 Rookie
    Feb 1, 2011
    3,859
    You could probably pry the original relay apart and file the contacts.
  11. AndruL
    AndruL Karting
    Apr 4, 2018
    234
    AndruL
    No it wasn't.
  12. AndruL
    AndruL Karting
    Apr 4, 2018
    234
    AndruL
    Probably but why?
    JayG likes this.
  13. spicedriver
    Feb 1, 2011
    3,859
    To keep it original ?
  14. AndruL
    AndruL Karting
    Apr 4, 2018
    234
    AndruL
    I see... but not me.
    JayG likes this.
  15. Mark C Harvey
    Mark C Harvey Formula Junior
    287
    West Hartford, Connecticut
    Mark C Harvey
    Just going through this process as my oil fan stopped. I’m getting 12V from ignition coil, but not from any of the other connections. Looking for suggestions on how to trace the 12V wire that goes to battery. It looks like two blue wires that just disappear into a loom of wires into the wheel well area…
  16. Alden
    Alden F1 Rookie
    3,620
    Central Florida
    I may sound like a broken record, but get a color wiring diagram from member Afterburner. Example pic.
    Alden
  17. Mark C Harvey
    287
    Mark C Harvey
    Not at all - much appreciated. I actually just downloaded a wiring diagram. It’s black and white but no matter I’m color blind as a bat. Apparently the 12V power comes from a junction behind the left side of the instrument panel, and shares wiring with the wipers. I did notice the wiper fuse was blown, not sure if that’s related. I’ll have a look tomorrow.
  18. Alden
    Alden F1 Rookie
    3,620
    Central Florida
    Sorry about your disability, those black and white drawings are almost impossible to trace and sometimes the resolution isn't that good! Good luck!
    Alden
