Last things to refurbish on the Mondi before I call it done. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
From Ebay. It's called: "27pc Universal Press and Pull Sleeve Kit Bush Bearing Removal Insertion Tool Set"
I found a seller on Ebay that was selling these without the outer shells since we don't need them. So they were cheaper than the complete $25 Energy Suspension bushing
If anyone wants to stay with the original rubber style bushings I got a great deal from MASERATI MIE in Auburn WA.
I don’t think so. One man job, no spring compressor or spring danger involved unless replacing shocks.
Front bushings are done. Now on to the rears. Upper A arms were easy... Image Unavailable, Please Login
The rears however were a different story. Most people posted that they had to disassemble almost the entire rear suspension to remove the lower A arms. Brake calipers, rotors, brake lines, hand brake cables had to come off. Image Unavailable, Please Login
I didn't want to do that so figured out a way to get the lower A arm off without disassembling everything.... Image Unavailable, Please Login Image Unavailable, Please Login
