Mondial 3.2 Spark Plug Removal - what size socket? | FerrariChat
Discussion in 'Mondial' started by Lenvo65, Jul 16, 2007.
  1. Lenvo65
    Lenvo65 Formula Junior
    Apr 3, 2005
    293
    Bergen Cty NJ
    I want to check the condition of my plugs and when I fitted a socket to the two plugs in with my tool kit they were 13/16ths. However when I go to take a plug out it does not seem to fit. When I look in the cavity in the head it appears to narrow down tightly around the plug at the bottom where the plug is and so I am thinking I need a thin wall socket, or that I need a metric one.
    Any input is appreciated, now that I fixed my ignition problem (bad ignition module) I think I may have one bad plug as I still have a miss.
  2. Steve Magnusson
    26,507
    Sometimes the hex drive size is different on different brand/type spark plugs (even if they fit the same engine). Most likely your 3.2 plugs are an 18mm hex drive size (NGK "D..."), and, like you noted, you need a smallish OD too, although we never sorted this out exactly -- the stock F 18 mm spark plug socket is only 23 mm OD; 24mm OD would probably work; 25 mm OD would be questionable IMO, but may squeak by depending on your particular parts.
  3. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,054
    Dumpster Fire #31
    SMG
    I found the sparkplug sockets sold at kragen for the import cars to work great. the Japanese autos have the same small wells for the plugs and require a long thin shaft - Okay that sounded like some porn script :O
