modifying regular wheels to Diamond cut wheels - at wheel shop? | FerrariChat
Discussion in '458 Italia/488/F8' started by Tom(Atl), Aug 17, 2018.
  1. Tom(Atl)
    Tom(Atl) Formula Junior
    Oct 29, 2006
    509
    Tom
    Hi guys,
    I want to have a wheel paint shop modify regular wheels into to 'Diamond cut look' wheels - has anyone does this? Do you have any advice on what to ask for so it comes out right? From what I can tell at looking at the diamond cut wheels,
    I was thinking of requesting the following to get it to come out correct:
    1) Paint wheel Overall darker tone. Paint wheel darker
    2) Exception: Leave the top surfaces lighter silver
    Any other criteria you guys would suggest?
  2. Viperjoe
    Viperjoe F1 Rookie
    You could end up making a meaningful investment while achieving a less than satisfying result (or worse). I'd buy a new or mint condition used set and sell what's on the car now to recoup some of the cost.
    Need4Spd, Napoli and docf like this.
  3. legendd
    legendd Karting
    Jun 25, 2011
    187
    Dallas, TX
    Moshe levy
    I don't think you will like what you get if you follow those instructions.
    In my opinion, either paint the whole wheel into a darker shade (I painted mine into black matte shade and it came out beautiful in my opinion), or buy a new/used set.
  4. Cigarzman
    Cigarzman F1 Veteran
    This !
  5. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    You didn't say which car or which regular rim you are thinking of.
    Not all rim designs can be diamond cut. Diamond cutting requires the profile of the spokes to offer sufficient surface for the lathe cutter to expose metal on when the rim is spun on the lathe. The cutter also has to be able to smoothly follow the profile of the spokes so if the spokes are very thin or have abrupt profiles, it won't work. Some rims may also exhibit inconsistent (blotchy) coloration in the alloy which would be exposed when "diamond cut" and this is not related to the quality of the alloy as it can happen to even the best rims. An experienced rim refinisher will know. I spoke with an friendly expert at the factory that supplied the metal used to make my rims.
    FWIW, I diamond cut my new HRE rims because I could not find a factory finish and colour that would match my car. I bought the premium monoblock rims with the least expensive finish and then stripped, repainted, diamond cut them to my specifications. The procedure was inexpensive and worked out really well.
    Viperjoe likes this.
  6. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,314
    CT
    Paint? or Powder Coat?
  7. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,243
    Mel
    Woow … can you show us the result please Michael ?
  8. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    Tom(Atl) likes this.
  9. veilstylez
    veilstylez Formula Junior
    988
    SoCal
    I would like to know too...I want to diamond cut my factory 20s
    any shops in SoCal?
    4th gear you finish came out great
