360 - Modena Speakers replacement | FerrariChat
360 Modena Speakers replacement
Discussion in '360/430' started by MD355, Sep 7, 2023.
  1. MD355
    MD355 Formula Junior
    Mar 8, 2004
    802
    Athens, Greece
    MD
    Greetings,
    I want to replace the door speakers of my 2002 Ferrari 360 Modena.
    I have the standard stereo system with the Becker-Ferrari , CD changer in the trunk and two door speakers with twitters at the top.
    I want to confirm with you that the correct part is : 188607 (it says Valid for cars with Radio amplifier)
    Alternative there is also a part : 65865100 (Not valid for cars with Radio amplifier) so my guess is that this part is for cars that have the big subwoofer between the driver-passenger seats and the external amplifier..
    Am I right? For standard audio system is this 188607 the correct speaker ?
    And now comes availability... Where is the best location to find them ?
    Thanks !!
    Makis
  2. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner Rossa Subscribed
    Jan 19, 2004
    7,781
    San Jose, California
    Actually, you have it backwards. The "radio amplifier" system is the two small speakers between the seats and the 60 Watt booster hanging underneath the dash.
    Regarding replacement door speakers, I looked on fleaBay and found one in the U.S., one in Canada, two without grills in the U.S. and a couple overseas. All used. Good luck finding NOS.
    You may want to consider this system from Scuderia Audio: https://scuderiaaudio.com/product/360-focal-6-5-plug-play-system/
    Kevin Rev'n and E60 M5 like this.
  3. MD355
    Mar 8, 2004
    802
    Athens, Greece
    MD
    Thank you for your reply !!
    So you are saying that for the Standard Sound System (Becker/Ferrari Stereo without subwoofer between seats) in the 360 Modena I need the 65865100 (Not valid for cars with Radio amplifier) ?
    Can someone confirm this is the case, so I don't make a mistake in the order ? Thanks !
  4. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,152
    Wash DC area
    Robert
    Mike is a highly respected forum sponsor for years and has many satisfied customers.
    If he is telling you something audio, believe it 100%
  5. MD355
    Mar 8, 2004
    802
    Athens, Greece
    MD
    Got it !! You are right..
    So my car is 65865100 (Not valid for cars with Radio amplifier) , since it does not have Radio Amplifier...
    Thanks again for clarifying !!
  6. aventari
    aventari Karting
    Dec 9, 2010
    121
    San Diego
    LorenzoR, MD355 and one4torque like this.
  7. MD355
    Mar 8, 2004
    802
    Athens, Greece
    MD
    I tried to find the Ferrari OEM speakers from :
    Scuderia Car Parts
    Eurospares
    Ferrari Dealer
    and everyone told me this part has been discontinued...
    So I have to find a solution like yours.
    They recommended Hertz or Pioneer speakers.
    Focal also look amazing. Besides soldering the connection, did you have to do any other modifications ?
    Feel free to post links for speakers that are compatible / fit the 65865100 Ferrari part...
    Thanks !!!
  8. SoftwareDrone
    Jan 19, 2004
    7,781
  9. SoftwareDrone
    Jan 19, 2004
    7,781
    The piece of metal sitting right above the cutoff wheel, where did that come from?
  10. SoftwareDrone
    Jan 19, 2004
    7,781
    To the OP: If you want a nice speaker set in your Modena without cutting a sliver of metal out of each door and without needing to mount the speaker way off center and without needing to cut the original speaker connector off of either the original speaker or the original wiring, may I suggest that you take a look at this kit: https://scuderiaaudio.com/product/360-audison-6-5-plug-play-system/
    If you want even better sound and don't mind cutting into the metal in your doors, look at this kit: https://scuderiaaudio.com/product/360-focal-6-5-hyper-directional-component-system/
  11. LorenzoR
    LorenzoR F1 Rookie
    Which focals did you buy as I'm looking to upgrade my door speakers as well
    aventari likes this.
  12. SRLC716
    SRLC716 Formula Junior
    Sep 15, 2019
    292
    Buffalo
    Sam
    I have replaced all speakers with Mike’s setup from Scuderia Audio. The sound quality, clarity and bass (upgraded with the super bass sub and enclosure) is absolutely incredible and everything looks 100% stock.
    He’s one of the best vendors I’ve dealt with, and I recommend him and his solutions!
    Need4Spd, gt1995 and SoftwareDrone like this.
  13. aventari
    aventari Karting
    Dec 9, 2010
    121
    San Diego
    Sorry for late reply, I used the Focal Access 165 CA1 6.5-Inch Coaxial Speaker
    They sound great, but like @SoftwareDrone said I had to trim the door metal frame a bit to make it fit as the magnet and basket are large.
    I would also recommend Scuderia Audio if you don't want to cut metal or solder, and don't mind paying a bit more.
    I got a stereo adapter from him and he was super cool and easy to deal with.
