Mobile OBD Scanner / Logger - iPhone / Android - 360 / 430
Discussion in '360/430' started by FerrariDublin, Nov 17, 2014.
  1. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    So I've played around with quite a number of mobile solutions and have now found one that I'd be happy to recommend to users as a very cheap but effective solution.
    First-up one needs a scan tool. A WiFi tool is probably best as it will allow connectivity with most devices (Apple Phone / iPad / Android Phone / Tablet, PC etc.) I used this cheap, generic ELM327 WiFi which can be purchased for $10~$20 ... OBD II 2 ELM327 WiFi Car Diagnostic Interface Scanner Tool for iPhone PC New | eBay
    In researching which App to use I was in contact with a number of developers and almost all of them do not provide support for individually selecting to which ECU one wishes to connect. In another thread Voicey had identified that EOBD Facile had the capability. Indeed they do and what's particularly nice about their solution is that they allow you to toggle between one ECU and the other while remaining connected. That said, I found that the connection between my phone and the dongle and/or the ECU was always getting disturbed which meant that while the solution was probably fine for simple code reading it would not be satisfactory for logging of data. I also found the user-interface of this App to be less than pleasing and intuitive.
    My research led me to OBD Fusion which seemed to have a nice user interface and lots of good mapping and logging options. Their developer, Matt, not only responded to my multiple queries but, having gained an understanding of the particular issues we Ferrari owners have, undertook to ensure that their next update would feature manual selection of ECU. That update was released recently and I'm pleased to say that it works and is also very easy to use and contains many valuable features.
    Here's a link to their website and from there you can navigate directly to the Apple or Google stores to download the app to your phone or other device. Cost is $9.99. https://www.obdsoftware.net/
    Unlike OBD Facile, one has to disconnect and re-connect from one ECU to the other. I've suggested that perhaps in a future version they might like to try and offer the toggle option.
    Once connected to an ECU for the first time you are offered the option to define the vehicle to which you have connected. Each ECU on our cars is like a totally different vehicle to this software so best to name your ECU11 connection something like "ECU11 Bank 1~4" and name your ECU14 connection similarly "ECU14 Bank 5~8" Thereafter the software will recognise the "vehicle" each time it is connected.
    The first time I connected to the 360 the unit "saw" only ECU10. Once I disconnected and reconnected it saw ECU10 and 14 and asked me which one I wanted. Every time since it has seen both and asked me to choose.
    What's particularly nice about this App is that beyond all the usual Trouble Codes, Clearing Codes, Tests, Dashboards etc. there's a neat real-time log on which you can define up to four PIDs to track and trace in real time as you drive. One can also log all available PIDs on a drive cycle and then export (along with GPS and mapping) to a CSV file where one can review later.
    My testing was done with a 2000 European 360 Modena and an iPhone5. I've no reason to believe that it would work any differently on a 430 or with an Android phone. I've also used it to log my Merc daily and it was faultless on both and never dropped the connection.
    I have no affiliation to either the hardware or software providers liked above. Credit where it's due though, OBD Fusion listened to my query, took the time to understand it and then went and did something about it and came back and told me when it was done. For that alone they deserve a wee "plug" here.
    This is no replacement for an SD2 but for a total investment of $20 +/- and a little time learning how to use the tool, you really can’t go wrong.
    Best!
  2. IDriveM5
    IDriveM5 F1 Rookie
    Jul 2, 2012
    2,675
    Central Ohio
    Raj
    Thanks Greg, glad to see you're pleased with your setup. Here's a link to the same process I tried (It seems that the OBD Facile App was more costly than your OBD Fusion App):
    http://www.ferrarichat.com/forum/360-430/465455-ios-obd-scanner-reader-solution.html
    It's pretty cool the level of functionality we can get from a cheap scanner tool and a relatively inexpensive app. It puts my old "wired" OBD Scanner Tool to complete shame.
  3. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Yes, the Facile App is slightly more expensive but the differential is of no significance when it comes to getting the right app for the job.
    I didn't download/pay for the full Facile app because I found that the phone+dongle+ECU would not stay connected for any realistic length of time (on two vehicles I tested). I knew my Phone, ECU and Dongle were all working fine as I had no such problems with other software I had tested so Facile seemed to be where the problem lay.
    Additionally, I do find the user interface of the Fusion App to be quite superior to that offered by Facile. It's really easy to customise or create a "dashboard" and have it display exactly what you want, where you want it and in analogue or digital format. Similarly the graphing is easier to use, more definable and allows for greater number of PIDs to be selected.
    What sold me though is the logging and CSV output file (probably available on Facile also). It contains a wealth of data which can be used for diagnostic purposes. Obviously one can only log if one can stay connected and for me that made the choice easy.
  4. IDriveM5
    IDriveM5 F1 Rookie
    Jul 2, 2012
    2,675
    Central Ohio
    Raj
    That's interesting. I have the OBD Facile app loaded on my iPad and my iPhone, and I have no problems with connecting for as long as I like. I'll sometimes have a passenger load up the connection for some real-time stuff. It takes a while to connect (like 30 seconds total) but once I'm in, I'm in for good. It does the job well for me, I'm happy. :)
  5. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    #7 FerrariDublin, Nov 20, 2014
  6. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    #8 FerrariDublin, Nov 20, 2014
  7. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    #9 FerrariDublin, Nov 20, 2014
  8. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    #10 FerrariDublin, Nov 20, 2014
  9. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    #11 FerrariDublin, Nov 20, 2014
  10. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Very nice. Thanks for sharing info and graphics about OBD Fusion.
    Will the program detect the 2 ECU's and allow you to select which ECU you want to read?
    Dan
  11. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Yes, on connection it asks you which one you want, 11 for 1~4 or 14 for 5~8 bank. When you connect for the first time you tell it about your vehicle (and in our case which ecu is which). Thereafter any logs recorded are filed under the appropriate vehicle/ecu so if/when you go back to locate stored information to export you know from which vehicle/ecu the log was recorded.
  12. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thank you!
    Dan
  13. jackgt
    jackgt Formula Junior
    Jan 27, 2015
    574
    california
    Jack
    FerrariDublin---
    Can you see both bank O2 sensors at the same time? THAT would be very helpful
  14. 360Tom
    360Tom Formula 3
    May 9, 2013
    1,396
    Burbank, CA
    Tom
    Dash Command does both banks at the same time.
  15. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    No, it's one bank at a time with Fusion. This is actually a good thing, see below.
    Yes, some software will automatically toggle from the data on one ECU to the other. The problem though is that you have no way of knowing what exactly you are looking at. For example, the Long Term Fuel Trim (LTFT) reports from both ECUs with the same identifier. Consequently, if one were viewing it live, one might see it fluctuate from say -5 to +5 but you wouldn't have a clue which side was which.
    It would indeed be excellent to be able to log both sides at the one time but only if the data streams had different identifiers.
    I'm not at all sure if even "SD" equipment can monitor both ECUs at the same time and also differentiate between the two properly.
  16. 24000rpm
    24000rpm F1 Rookie
    where to buy obd fusion for android? I can't find one for 5 minutes on internet
  17. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Enter "Obd Fuision for android" into the Google machine and I thik you'll finf your answer :)
  18. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Actually the android version might be touch scan. Looks the same graphic interface but different name. I've no experience of it though so suggest you read up a little first. Looks the same but.
  19. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thanks for the updates Greg.
    I tried to read fault code this weekend and I finally gave up on iPad & Android Apps with WiFi or ELM27 bluetooth adapters......
    I've tried OBD Facile, Torque Pro, Fusion and I simply cannot get them to work properly.
    Issues:
    The WiFi will drop the connection on its own.
    The Bluetooth version App sometimes will not read both ECU's.
    There is not enough definition on the fault code being thrown, etc so I gave up on them.
    FYI I just bought the OBD code reader below. Its a direct plug in to the OBD2 port so there is no drop in connection or worrying about WiFi or Bluetooth connections.
    I am hoping it will work like a charm, read both ECU's and provide enough definition on the fault codes. If not, I bought it at Amazon so it should be easy return.
    I will post updates here if I have better luck with this OBD fault code reader.
    Amazon.com: Joyluxy Goldiger OBD MATE OM580 CAN Diagnostic Scan Tool for OBD II OBD 2 EOBD Vehicles: Automotive
    Dan
  20. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    #22 FerrariDublin, Mar 24, 2015
    That looks a nice, easy to use tool, and as you say, it will remove the additional complexity of the wireless interface between the phone and OBD dongle.
    I wonder though if your problem is that the car has never had it's extra earth added to the OBD? See the attachment below - OBD2 Update.
    It's well worth getting one of the phone solutions working for that ability to be able to diagnose when away from home or to be able to log a drive cycle.
  21. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Excellent info. I was not aware of that service bulletin from Ferrari.
    Thanks for sharing Greg! I will check that ground connection this weekend.
    Dan
  22. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    #24 whatheheck, Mar 29, 2015
    Thanks to Greg / FerrariDublin for starting this thread.
    I have tried to read fault code using iPad & Android Apps with WiFi & ELM27 bluetooth adapters. I've tried OBD Facile, Torque Pro, Fusion and I simply cannot get them to work properly. (perhaps this is operator error)
    Issues:
    The WiFi adapter will drop the connection on its own.
    If the Wi-Fi is connected to the OBD adapter then your iPad cannot hook up to the internet.
    There is also not enough definition on the fault code being thrown, etc so I gave up on all of them.
    FYI, I just bought the OBD code reader below. OBD MATE OM580.
    I have tried it and I am happy with it.
    Again, the major benefits with direct hook up is no problematic wireless connection drop outs.
    It comes with USB cable for future software / firmware upgrades.
    It also comes with a nice storage pouch.
    Here's what I learned so far (at least with my car)
    - It will only work / read fault codes when the engine is running.
    - Plug it in the first time and it will read two ECU's at first. One engine ECU and TCU / Transmission ECU. To get to read all three ECU's, turn off engine. Remove the code reader, wait about a minute then plug in again, turn the engine back on and it will now read all 3 ECU's. See photos below.
    I believe ECU1 = $11 (right side of the engine); ECU2 = $14 left side of the engine; ECU3 = $19 which is the transmission ECU. Note that I am unable to get any reading on TCU. Per our experts here (Aldous Voice) the OBD readers are not advanced enough to read TCU data. Thanks to Aldous Voice by the way. I learned a lot from his posts and his website.
    Note 1: It currently does not have definition for Ferrari specific fault codes, only generic fault codes so you will need the Ferrari fault code sheet.
    Note 2: As like anything in life, there are better or worse equipment out there. I am not here to argue or debate nor seeking anyone's approval. Just sharing knowledge and info.
    Summary:
    I am very happy with this code reader and most likely its a keeper that I will use for all my cars. See photos below including fault codes that I pulled from my car that I will try and resolve soon. Most likely my CEL issue is / are bad Oxygen sensors so I have ordered all 4 oxygen sensors already and will install them soon. Hopefully that fixes my CEL problem.
    Hope this info helps some of you.
    All the best always.
    Dan
    Dan
  23. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Hey Dan, thanks for posting up the info.
    The $11 and $14 look good in terms of the two available ECUs and yes 11 = 1 and 14 = 2 in my experience.
    I'm concerned about your gadget's ability to read properly though. Neither P0030 or P1135 are listed on the 360 error code sheet that I have.
    Did you check to see if your car has the extra earth added to Pin 4?
