Misfiring after wash - soaked engine bay? | FerrariChat
Discussion in '348/355' started by dantm, Dec 13, 2015.
  1. dantm
    dantm Formula 3
    Nov 1, 2003
    1,103
    YYZ, BOS, SFO
    Dan B.
    I usually wash my car after a drive so the engine bay is hot; I try not to soak it in there with the hose, and avoid as much as possible getting water into the bay; whatever water is in there I try to dry out with the microfiber cloths...
    Well, today, I had the car sit outside in ~45 deg. weather until it cooled down and washed the car after a few hours. The engine bay was definitely cold.
    I was also a little more careless? with water, and it turned out there was water that seeped into the engine bay.
    After that the car was misfiring pretty badly, shutting down unless I was giving it gas, and even then running sluggish. No engine lights on, which I found surprising. Eventually after a few mins I got steam coming out from the engine bay and I assumed that the water was drying off...eventually it ran better.
    Is this normal and are these cars that sensitive to water in the engine bay? What about rain?
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    Not normal, it should not run like that. Check the spark plug cover gasket
  3. WATSON
    23,451
    WI
    Spark plug wires old?
  4. f355spider
    f355spider F1 World Champ
    18,025
    +1, there is a gasket as well as a foam block at the rear, where the plug wires come out. Ensure the gaskets and foam blocks are not missing, and all screws are tight.
    BTW, once you get a miss and fouled plugs, it is hard to get rid of, short of replacing the bad plug(s). My advice would be to remove all the plugs, and replace the one or ones that look bad, or have rust. Then seal everything up good. I only had issues one time with my 355 and it was because the foam blocks were missing, so I got water in the two rear most plug holes on each bank. Replaced plugs, and installed foam blocks, no more issues, even if driving in the occasional rain shower (I do live in Seattle) ;)
  5. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,611
    The Brickyard
    The Bad Guy
    Remove ALL the connectors and blow them out with compressed air, then hit them with a shot of WD40.
    Pay special attention to the connects on the coil packs, ignition control modules, MAFS, and crank sensors. But dry out EVERY connector with compress air regardless. Oh and be sure to dry out the damn cat TCUs (temperature control units).
  6. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    ^^^This.
  7. F355Bob
    F355Bob Formula 3
    Mine would misfire when engine got wet. Turned out to be bad cat ecu. They are notorious for being sensitive to water .
  8. dantm
    dantm Formula 3
    Nov 1, 2003
    1,103
    YYZ, BOS, SFO
    Dan B.
    Interesting. I have CAT ECUs but I don't have CATs so I have a resistor fooling the input probe to the ECU to make sure I don't get the dash light...
    Will check the other things, including the spark plugs which makes sense. BUT, if in general this should not be an issue why would one need to go through all the connectors? Or is the idea to go through the connectors if the spark plug clean/replace does not do anything?
  9. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    I power wash the engine bays of all my cars including the 355 and 348 and have NEVER had a problem, done it hundreds of times on all the cars. Guess I'm lucky. :)
  10. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Too much washing, not enough driving. I almost never wash a Ferrari with water. They get wiped down regularly with Quik Detailer or Speed Shine. There's no reason to get water in the engine bay unless you need it there.
  11. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Why do people spray water into the engine bay?
    I just do not understand it.
    Asking for trouble.
    Plus every bolt, connector, bracket, nut and washer goes rusty.
    I never wash my engine lid nor spray the wheels.
    I wipe gently with a damp cloth to remove gently dirt.
    My engine bay and suspension have zero rust.
    I never drive in the rain btw.
  12. dantm
    dantm Formula 3
    Nov 1, 2003
    1,103
    YYZ, BOS, SFO
    Dan B.
    :) Actually it was the only wash the car got this entire year...just before 'winterizing' here in the Northeast where we've had very mild weather.
    Typically when washing the car I will try to have a plastic wrap on top of the engine; I think I found a think shower curtain covering the engine works best. Of course with a *cold* engine.
    However, that should not mean the car is that fragile that any water in the engine bay would render it almost inoperable. It doesn't give me confidence to take it out in cloudy weather or far away from home where I can be caught in a storm if that is the case.
  13. BigTex
    79,320
    Houston, Texas
    Bubba
    This.....
    Any water into the engine lid is a BAD idea.....
  14. dantm
    dantm Formula 3
    Nov 1, 2003
    1,103
    YYZ, BOS, SFO
    Dan B.
    It's a car, it should behave like a car and if they made the engine bay with ventilation on top it should allow rain and such to get in there without affecting the behavior of the car.
    I have a tip about the wheels - when I clean them, and I do so maybe once a year due to the brake dust that gets in there, I will use a leaf blower to blast the wheel dry along with the rotor, hub, etc. You have to use some judgment for the power that you use but I found that it leaves everything clean and dry.
  15. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,141
    CT
    John Kreskovsky
    My approach as well. Since I bought my car 3 years ago it's been wet washed once. Quick detailer and micro fiber towels after each outing.
  16. plugzit
    plugzit F1 Veteran
    7,744
    Redondo Beach, CA
    Bruce Bogart
    The car is built to drive in the wet as well as the dry. If washing it with water makes the engine run badly, you NEED to know before you are on the road and catch a sudden downpour. Otherwise, you're not driving enough. So, I wash the car with water always. Then, if the motor responds negatively, I find out WHY and can do something about it at home.
  17. Oengus
    Oengus F1 World Champ
    exactly
  18. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Asking for trouble
    Just about all the motronic 2 and 3 pin sensor rubber boots would have deteriorated....take a look at the ones on the injectors.
    Water in here spells long term damage to tin connectors, etc.
  19. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Driving a 355 in the wet is a big no no for me
  20. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,674
    Lake Villa IL
    After putting so much time into paint correction, I wash my car with water/2 buckets.
    I do it cold and dry the car and engine compartment with an electric leaf blower.
  21. itsablurr
    itsablurr Formula 3
    1,016
    Carlisle, MA
    Matt
    Usually only clean engine bays by hand with paper shop towels and cleaner/conditioner sprays, regularly for upkeep.
    If an engine bay needs a deeper wash, care should be taken to cover all electronic connectors, covers, or other sensitive areas with foil before applying degreasing cleaner and any water for spray rinsing directly in the bay.
  22. plugzit
    plugzit F1 Veteran
    7,744
    Redondo Beach, CA
    Bruce Bogart
    If electrical connectors NEED to be covered/protected, then you are just kicking an existing problem down the road...til it fails. Identify and repair any faulty connections. Perhaps that's why so many cars have electrical problems...regular maintenance of connector boots and seals has not been identified until complete failure occurs. "Too Much Care" syndrome.
  23. itsablurr
    itsablurr Formula 3
    1,016
    Carlisle, MA
    Matt
    #23 itsablurr, Dec 14, 2015
    If boots or seals appear to be degraded then of course they should be repaired to prevent any connection faults as a result of that degradation. However, I view the connectors as being designed for a nominal level of water resistance, to the degree exposed in the ordinary, normal operating conditions of wet weather driving. A hose thoroughly dousing water throughout the nooks and crannies of an engine bay, as I view it, would be an extraordinary exposure, outside of normal, where an otherwise "good" electrical fitting or component may be at additional risk. I just prefer not to tempt fate in that instance, and take some degree of care and precaution as a result.
  24. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    It only happens to mine when I take it to the automatic car washes! :)
    If you are missing the little rubber block for the plug wires, you better be seated when you check the price of a replacement.
  25. dantm
    dantm Formula 3
    Nov 1, 2003
    1,103
    YYZ, BOS, SFO
    Dan B.
