Miscellaneous Car News | Page 877 | FerrariChat
Discussion in 'Australia' started by Aircon, Mar 23, 2009.
  1. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    Everything AV engineering are doing is from 360trev.
    He managed to reverse engineer the ecu software and do some amazing stuff. He is working in collaboration with Aldous to bring his software changes to the public.
    He initially tried to investigate the immobilisers in the 360's to be able to delete them, but after he managed to decipher the Ferrari code, he is now able to do pretty much anything he wants with the 360 ECU's. (As well as the 430, 355, etc.)
    I had my ECU's tuned by Fabspeed, but that was prior to Trev's workout.
    Silly signature to help Horse annoy KIAI
    Its328 likes this.
  2. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    I have trouble believing it makes much difference.
  3. Its328
    Its328 F1 Rookie
    May 31, 2017
    3,070
    Brisbane
    Kim
    Trev's car is pretty amazing!
    Its all good news for us then.
    Gizzi likes this.
  4. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    To be completely honest mate, I was sceptical of the ECU tune I had done. Once I re-fitted the ECU's and drove it, I was convinced I'd wasted my money. The feeling was like they had retarded the throttle input by 5% until about 4k rpm, and then added 5% input once equality had been reached. I don't believe any power increase was realised, just the 'implied' feeling of power because of the sudden rush once the 'crossover' point had been reached. I can't speak for any other tuner out there though.
  5. Aircon
    100,524
    Peter
    I simply don't believe that Ferrari detunes their cars and leaves 20-30hp on the table. I got 10-15hp more out of the 355 compared to stock, but it had motec, practically no muffler and no cats.
  6. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    The only thing I know for sure, is that Ferrari sets the rev limiter about 1k revs lower to save the engines, and secure reliability. You can bounce those engines off the rev limiter all day with no adverse effects.
  7. Its328
    Its328 F1 Rookie
    May 31, 2017
    3,070
    Brisbane
    Kim
    You would certainly have to weigh up cost v outcome.
    But surely this has all been dyno verified, otherwise AV wouldn't put their name to it.
  8. sierra055
    sierra055 Formula Junior
    361
    Melbourne, AU
    Marshall
    I've been doing Trev's ECU flashes here locally for him. If you're interested in getting it done but don't want to send ECU's to the UK, get in contact with him.
  9. Aircon
    100,524
    Peter
    Have you seen how the power curve looks? I could set the 355 to anything, but there was no point going past redline. HP had already well and truly dropped off.
  10. sierra055
    361
    Melbourne, AU
    Marshall
    FWIW, there is a bit of a power and torque bump, but it's some of the other features that people have been getting the flashes for primarily.
    Immobiliser disabling has been the main one for cars that that have cooked immobiliser ECU's, changing of exhaust valve opening rates, torque demand patch.
    If you haven't seen the thread, look for Swiss army knife in the 360 section
  11. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    It wasn't an AV tune Kim, it was a Fabspeed tune. I believe Trev's tune would be legit, but agree with Poopsie Pie in that Ferrari wouldn't leave any reliable horsepower on the table.
  12. sierra055
    361
    Melbourne, AU
    Marshall
    Trev believes that one of the limitations on the 360 was the size of the MAF's. Hence the larger ones on the CS and then the 430.
    Fitting 430 MAF's to the 360 apparently yields a decent improvement
  13. Its328
    Its328 F1 Rookie
    May 31, 2017
    3,070
    Brisbane
    Kim
    What about the extra 25HP of the CS?
    That must have been ECU and exhaust!
    Edit just saw above comment
  14. Aircon
    100,524
    Peter
    There was a lot more to that engine than just that!!
  15. Aircon
    100,524
    Peter
    lol...trev may believe it, but I don't! Regardless, as if you'd feel the difference even if by some miracle they got even 20-30hp!! Just a waste of time and money.
  16. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    At the the end of the day it won't matter to me, I'm going to buy a 328
  17. FazzerPorscheman
    FazzerPorscheman F1 World Champ
    Jul 28, 2010
    15,286
    Piz Gloria
    EnzoFerdinand
    Fixed. [emoji16]
    greg246 likes this.
  18. Aircon
    100,524
    Peter
    As if
  19. Its328
    Its328 F1 Rookie
    May 31, 2017
    3,070
    Brisbane
    Kim
    Yes you're right.................yes I know
    The Challenge Stradale builds on aerodynamic concepts employed on the 360 Modena by taking advantage of the racing set-up (stiffer and lower) and adopting specific solutions that have led to a gain of 50% in vertical load compared with the 360 Modena. The results are extremely significant: at 200 km/h the load increase is about 40 kg for a gain corresponding to the effect of a wing with 15 cm chord length and 1.8 m span. Despite such a significant increase in vertical load, after all the modifications and adjustments to set-up the car has a Cd equal to that of the 360 Modena (Cd = 0.335). Four types of intervention were adopted to improve aerodynamics on the Challenge Stradale:
    Front section: modification of the bumper, which now extends below the air intakes to increase load at the front but without disrupting airflow toward the rear.
    Aerodynamic study of the car's underside and rear section: with the result of an increase in height at the rear and introduction of longitudinal fins to balance the load. The decision was also taken to modify the rear nolder to achieve greater efficiency by adopting a shape more appropriate to the function.
    Drag and modification of the sills: the new shape streamlines the rear wheels more completely and contributes significantly to improving the car's efficiency and balance. The combined result of these interventions is that compared with the 360 Modena, drag has remained unchanged, so leading to a significant increase in efficiency.
    In addition to the interventions outlined so far, the focus on the Challenge Stradale's aerodynamics and styling has been enhanced by a painstaking review of all technical details of the project: 360 GT-style aerodynamic, carbon mirrors, new 19" wheels with a Challenge-type design.
    Careful project development has led to a Challenge Stradale car weight that is fully 110 kg less than the 360 Modena, achieved by concentrating on three complementary spheres: materials, construction technology and project optimisation. The basic material used to build the Challenge Stradale is aluminium, as was already the case for the 360 Modena and Spider. Aluminium has a specific weight one third of that of steel. This initial approach already made it extremely competitive (compared with the 360 Modena). Starting from this base new developments were introduced specifically for the Challenge Stradale. Titanium, already used for the piston rods, was also adopted for parts of the suspension. Carbon technology, derived directly from Formula 1 and used extensively on Ferrari limited-run road cars, was employed for the first time on an 8-cylinder car. For the Challenge Stradale it has been used for both structural parts (door panels, racing seat shells, filter-box covers) and for interior and exterior trim features. A particularly advanced construction technology was adopted for the car's floorpan. This involves impregnating the resin with multi-axial carbon fibres in a vacuum in order to obtain the necessary rigidity, but which simultaneously leads to a 50% reduction in the weight of the floorpan itself. A key factor in the search for the best weight-performance ratio for the Challenge Stradale was adopting a braking system comprising carbon-ceramic (CCM) discs developed for Formula 1 (combined with aluminium brake carriers as standard equipment) that mean a 16% reduction in the weight compared with conventional brake discs; given that the weight eliminated affects unsuspended masses, its contribution to the car's performance can be assumed to be even more significant. Reducing a car's weight also means a reduction in its inertia. The main effect of this on the Challenge Stradale, together with the peak power increase provided by the V8 engine, is a considerable increase in performance, particularly as regards pick-up and acceleration. The car accelerates from 0 to 100 km/h in 4.1 seconds and covers 400 metres from a standing start in 12.1 seconds.
    The Challenge Stradale is equipped with the previous 360 Modena 90° V8 engine mounted centrally behind the cabin in a longitudinal configuration as a single block together with the gearbox and differential. Peak power output of the V8 engine has been raised to 425 bhp at 8,500 rpm to give an exceptional power rating that exceeds 118.5 bhp/litre, which makes it the most powerful aspirated V8 ever built by Ferrari also thanks to the ram-effect induction which, at maximum speed, increases power by 2%. The extremely high peak torque remains unchanged at 38 kgm at 4,750 rpm. On the mechanical front, couplings for rotating parts in the Challenge Stradale's V8 have been carefully selected and this has led to a significant improvement in performance. Modifications to the engine can be grouped in the following areas:
    Optimisation of the compression ratio by means of additional work on components involved in it (heads, pistons)
    Optimisation of the engine's fluid dynamics, by means of the following interventions:
    use of an intake manifold with inserted stacks and burnished ducts, in addition to burnishing the intake ducts and head exhaust;
    optimisation of the section and head of the intake manifold coupling;
    use of a specific intake timing;
    use of a new low-load loss, airflow meter;
    new low counter-pressure exhaust silencer.
    Optimisation of mechanical performance was achieved by means of the following interventions:
    selection of low-friction cylinder blocks;
    new positioning of valve-springs.
    The entire development of the Challenge Stradale was based around F1-type electro-hydraulic transmission that controls the clutch and gearbox by means of blades integral with the steering column - a trademark of Ferrari cars and a solution developed specifically for racing. The increase in precision guaranteed by the new control strategy applied specifically to this car, and also by a faster processing speed, has reduced gear-change time throughout the entire range of use, with a minimum of 150 milliseconds when using the super-performance option. The available gear-change configurations are consistent with the car's top-level sporting profile and so only include manual gear-change operated by the driver using F1-type paddles (there is no automatic gearbox option). The reverse gear is engaged by means of a button on the tunnel. There are two gear-change configurations (Sport and Race): each of these configurations corresponds to an integrated car-control logic as regards damper set-up and traction control (ASR). In 'RACE' mode and with the ASR disengaged there's also a 'launch control' strategy as used in Formula 1, a feature specially designed to give drivers a high-performance start in good grip conditions.
    The Challenge Stradale has been derived from the 360 Modena and maintains the same basic approach and architecture. However significant changes have been made to the suspension system and set-up. The titanium front and rear springs are stiffer than on the 360 Modena (around +20%), whereas the rear bar has a larger diameter. These interventions have increased resistance to roll and dip and in general terms have made reaction to direction changes more rapid, giving the driver a more direct feel of the car. Damper settings have been reviewed and defined specifically for this model. The car's centre of gravity has been lowered by 15 mm. The tyres are Pirelli P Zero Corsa type - this new Pirelli super-low tyre adopted specifically for the Challenge Stradale measures 225/35 at the front and 285/35 at the rear and is fitted on 19" Challenge-style wheels secured by titanium bolts. The choice of these tyres exclusively for the Challenge Stradale confirms the effectiveness of cooperation between two of motoring's historic brands, not only in the case of the Ferrari Challenge-Pirelli Trophy but also in the FIA GT Championship. A long series of tests carried out together with Pirelli has identified a tyre compound and tread design that maximises torque transfer to the road surface and produces very high lateral acceleration (1.3 g) while maintaining superb balance between the two axles. The innovative characteristics of this tyre, which made its world debut at the Geneva Show together with the Challenge Stradale, means grip can be adjusted to suit the thermal conditions under which the tyre must perform.
    The braking system on the Challenge Stradale comprises carbon-ceramic (CCM, Carbon Composite Material) discs: the result of highly advanced studies conducted by Ferrari in conjunction with Brembo, the supplier of this system. Dimensions of the brake discs are as follows: front: 380 mm diameter x 34 mm thickness, and a differentiated-diameter, 6-piston calliper; rear: 350 mm diameter x 34 m thickness; and a differentiated-diameter, 4-piston calliper The carbon-ceramic system installed on the Challenge Stradale, together with the aluminium brake carriers, makes for astounding performance and braking distance. In terms of weight, the reduction achieved for the Challenge Stradale is 16% when compared with conventional brake discs. Overall deceleration rates for the Challenge Stradale are 15% better than for the 360 Modena.
    Essentiality - in the most specific meaning of the term - is the dominant characteristic of the Challenge Stradale's interior, right from the elimination of unnecessary features like carpeting and mats, to a racing-style interpretation for every single feature. The rev counter located right in the centre of the instruments becomes the driver's main point of reference, emphasised by the yellow graphics and red indicator that ensure optimum contrast and legibility. The entire panel is enclosed within a carbon-fibre element that also houses secondary instruments and other telltales. The new steering wheel, with a squashed crown in the upper section fitted with a sight just like on the racing version, has F1 gear-change paddles, the right one having been lengthened to facilitate changing up when pulling out of corners. The car is fitted with carbon fibre-structure racing seats upholstered with a high-grip textile. Door panels are made entirely of carbon fibre, as is the central tunnel, which has been designed to house all the car's main controls - ignition button, reverse gear button, dynamic vehicle settings (race, launch control, ASR excluder) within easy reach of the driver. The car can be fitted with either 3-point attachment or 4-point racing attachment seat belts and an aluminium roll-bar that's 40% lighter than a conventional type, developed specifically for the Challenge Stradale.
  20. Its328
    Its328 F1 Rookie
    May 31, 2017
    3,070
    Brisbane
    Kim
    I'm always tempted!
    I won't buy anything newer than the 360, if I can afford them!!
  21. Horse
    Horse Three Time F1 World Champ
    Dec 1, 2005
    35,416
    Brisvegas
    Jon
    FFS
    TLDR
    Silly signature here to annoy KIAI
    Gizzi likes this.
  22. Aircon
    100,524
    Peter
    Then why'd you ask?
  23. Horse
    Dec 1, 2005
    35,416
    Brisvegas
    Jon
    So I’m going to have to wait a lot longer than usual for you on the GG now?
    Gizzi likes this.
  24. Its328
    Its328 F1 Rookie
    May 31, 2017
    3,070
    Brisbane
    Kim
    I was pre-empting your reply "I'm always right" which you are 95.87% of the time
  25. Its328
    Its328 F1 Rookie
    May 31, 2017
    3,070
    Brisbane
    Kim
    It is a bit lengthy :D
