mine scud lacks power soo much when coolstart | FerrariChat
Discussion in '360/430' started by joeyzhou, Oct 16, 2017.
  1. joeyzhou
    joeyzhou Rookie
    Jul 30, 2016
    1
    china
    Three things : 1the throttle is not sensitive during the cold start , rpm won't go right up when full throttle.
    2: The scud is lack of power soo much , first gear full throttle, the rev goes up soo slowly, by the time to change second gear , FT86 by my side has pulled full car length ahead of scud
    3: the car has its full power when the water temp reaches 80+
    Is my scud normal? It can't be this powerless during the cold start right?
  2. zstyle
    zstyle Formula Junior
    Jun 28, 2007
    532
    Fountain Hills
    Jon
    I don't believe this is normal.
    You may want to bring to a dealer or independent with a SD3 to reset the ecu parameters. If the ECU does not know the correct parameters (ie for a given ambient temperature, the timing, airflow, fuel etc should be a desired value) you will notice severe performance problems.
    I doubt the fuel system is your issue since you have full power at a given temperature.
  3. redcaruser
    redcaruser Formula 3
    2,419
    switzerland
    daniel
    No power during the cold start procedure is normal, therefore my recommendation: Don't drive the Scud while the engine is in its cold start program!
    We talk about a highly developed and demanding sports engine. Always wait until the engine reach a round and stable idle! If you do it anyway it may be that the engine does not come out of this program for a longer time and the car drives like with a broken engine (no power, not a normal throttle response etc.). Then the only reasonable solution is: stop the car, turn off the engine, wait a few seconds, start the engine from new and wait for at least 30/45 seconds until the car falls into a round and stable idle.
  4. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,641
    England
    Mark
    The ECU is likely protecting the car from your abuse. Do not drive the car hard until the oil is up to temp.
    ideloera likes this.
  5. RWP137
    RWP137 Formula 3
    Apr 29, 2013
    1,588
    AZ
    Rick
    Why would you want to rev or command full throttle with a cold engine? Don’t do that...
  6. mkzhang
    mkzhang Formula Junior
    Oct 5, 2009
    535
    Philadelphia
    Stop beating the crap out of the car
  7. MaranelloDave
    MaranelloDave Formula 3
    Apr 27, 2010
    2,203
    LA
    Dave
    Make sure the battery is fully charged when you start the car. I had my scud in for annual service at the dealer and forgot to tell them that I'm using a lightweight battery that should be on a trickle charger. When I started the car when I picked it up, there was very little throttle response. Once I drove the car around the block and got some charge in the battery, it worked fine. Could just be a coincidence, but I suspect it was a matter of misfiring because of little or no spark in some of the cylinders.
    joeyzhou likes this.
  8. f355spider
    f355spider F1 World Champ
    17,939
    Just wow.... :(
    Afonsolaw likes this.
  9. mello
    mello F1 Veteran
    5,042
    CA Bay Area
    Steve
    Based on your lack of knowledge of the Scud, please sell it and get yourself a Nissan GTR. You'll be MUCH happier and Ferrari will thank you for it.
    Afonsolaw and mkzhang like this.
  10. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    :yikes:
    Keep doing this and your engine will die a painful and very expensive death....
    It could be normal (as Mark says to prevent abuse) but I’m not sure many will have tested it!
    Revs below 3-4K until the oil temp is on the gauge.
