Michelin Pilot Recommended Tire Pressure? | FerrariChat
Discussion in '360/430' started by ForzaYYZ, Aug 29, 2022.
  1. ForzaYYZ
    ForzaYYZ Karting
    Sep 4, 2016
    67
    Toronto, Canada
    Sebastian
    Hi gang. Need advice for recommended tire pressures for leisurely drives, I don't track my 360 Modena. I have Michelin Pilot Sport 4s tires on HRE 19" rims.
    Front: 255/30-ZR19
    Rear: 305/30-ZR19
    Michelin states max pressure, but I don't have a clue what the optimal recommended pressure should be.
    Thanks!
  2. patina
    patina Formula Junior
    Jul 9, 2005
    502
    Lake Norman, NC
    36 front and rear should be a good starting point.
    LorenzoR likes this.
  3. tazandjan
    39,007
    That is pretty high. I would have started with more like 32 psi front and rear.
  4. PKIM
    PKIM Karting
    Jan 1, 2004
    199
    Redlands
    Paul
    I run 33psi
  5. Snapshift
    Snapshift Formula Junior
    897
    Centralia IL
    Lyle D. Pahnke
    I run Nitrogen at 31 psi cold. builds up to 34 warm. Anything higher rides like steel wheel on rough pavement. 430 Stock sizes.
  6. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,579
    San Jose
    dc
    Open the driver door and inflate to the specs on the plate.
    Running lower psi risks rim damage but up to the driver.
    Shorn355 likes this.
  7. Bob in Makiki
    Bob in Makiki Formula Junior
    May 30, 2017
    455
    Honolulu
    #7 Bob in Makiki, Aug 30, 2022
    I run 32 front 35 rear cold. If I’m not mistaken, the manual for the 430 states that if your car came with Pirelli's, the recommended pressures are 32F/32R, if Bridgestones 33F/36R, if Michelins 32F/35R, and if Goodyear run-flats 36F/36R. I’m running Michelins on 430 factory wheels, so I run 32F/35R.
  8. jadatis
    jadatis Rookie
    Nov 26, 2009
    17
    #8 jadatis, Aug 30, 2022
    Googled your tires to be next
    Front: XL loadindex 91/ 1356lbs maxload AT 42psi
    Rear XL loadindex 102/ 1874lbs maxload AT 42 psi.
    This is for up to 160kmph/99mph, for higher speed you need more pressure.
    Can make you a pressure/loadcapacity list for both tires for 99mph and using 90% of the loadcapacity belonging to the pressure.
    This gives highest reserve with still acceptable comfort and gripp. Can also make for other max speeds, and reserves.
    Then you "only" have to determine the load in axles acurately, and search that back in the list.
    Succes with that, the most tricky part in it all.
  9. 02360spider
    02360spider Formula 3
    May 27, 2015
    1,748
    Dartmouth
    Richard oliveira
    How wide are your wheels? Also do you have a pic of how the tire looks on the wheels?
    Sent from my SM-G996U1 using Tapatalk
  10. jadatis
    jadatis Rookie
    Nov 26, 2009
    17
    Also about rimmwidth for tirewidth and aspect ratio, I did research
    ETRTO " allows" on 305/30 rimwidth of between 10inch and 11.5 inch, measure rimm( is ideal) 11 inch
    The 255/30, between 8.5inch and 9.5 inch, measure rimm 9 inch.
    Now see what topicstarter has
  11. tazandjan
    39,007
    Sj- There are no specs for MPS4S tires on the tire data stickers. Ferrari's tire pressure recommendations are all empirical based on testing for each tire type.
    Bundy and Bob in Makiki like this.
  12. toussi1
    toussi1 Karting
    Jun 10, 2007
    160
    I'm shocked you can fit 255 in front, I assume fenders rolled. 32 should be good.
  13. jadatis
    jadatis Rookie
    Nov 26, 2009
    17
    #13 jadatis, Aug 30, 2022
    Here the pressure/ axleload list
    For max speed 160kmph/99mph, wich you wont go over for even a minute.
    Then 90 % used of the loadcapacity, belonging to the pressure, so dont go adding reserve yourselfes.
    Carmakers often use GAWR and maximum technical carspeed to calculate the pressure for, but no reserve added.
    But nowadays more often yust reference-pressure of standard load 35 or 36psi, and XL/reinforced /Extraload 41 or 42psi, wich is then mostly much higher then needed to prefent overheating.
    Front
    255/30ZR19 91Y
    Axleload/ psi
    927 lbs / 14 psi
    983 lbs. / 15 psi
    1038 lbs/ 16 psi
    1093 lbs/ 17 psi
    1149 lbs/ 18 psi
    1204 lbs/ 19 psi
    1259 lbs/ 20 psi
    1313 lbs/ 21 psi
    1368 lbs/ 22 psi/minimum adviced
    1423 lbs/ 23 psi
    1477 lbs/ 24 psi
    1531 lbs/ 25 psi
    1585 lbs/ 26 psi
    1639 lbs/ 27 psi
    1693 lbs/ 28 psi
    1747 lbs/ 29 psi
    1801 lbs/ 30 psi
    1855 lbs/ 31 psi
    1908 lbs/ 32 psi
    1962 lbs/ 33 psi
    2015 lbs/ 34 psi
    2069 lbs/ 35 psi
    2122 lbs/ 36 psi
    2175 lbs/ 37 psi
    2228 lbs/ 38 psi
    2281 lbs/ 39 psi
    2334 lbs/ 40 psi
    2387 lbs/ 41 psi
    2440 lbs/ 42 psi/referencepressure
    2493 lbs/ 43 psi
    2546 lbs/ 44 psi/ sometimes max cold
    2599 lbs/ 45 psi
    2651 lbs/ 46 psi
    2704 lbs/ 47 psi
    2756 lbs/ 48 psi
    2809 lbs/ 49 psi
    2861 lbs/ 50 psi
    2914 lbs/ 51 psi/often max cold
    2966 lbs/ 52 psi
    3018 lbs/ 53 psi
    3070 lbs/ 54 psi
    3122 lbs/ 55 psi
    3175 lbs/ 56 psi
    3227 lbs/ 57 psi
    3279 lbs/ 58 psi
    3331 lbs/ 59 psi
    3383 lbs/ 60 psi/ sometimes max cold
    Rear 305/30ZR19 102Y
    Axleload/psi
    1281 lbs/ 14 psi
    1358 lbs/ 15 psi
    1435 lbs/ 16 psi
    1511 lbs/ 17 psi
    1588 lbs/ 18 psi
    1664 lbs/ 19 psi
    1740 lbs/ 20 psi
    1815 lbs/ 21 psi
    1891 lbs/ 22 psi/ minimum adviced
    1966 lbs/ 23 psi
    2041 lbs/ 24 psi
    2116 lbs/ 25 psi
    2191 lbs/ 26 psi
    2266 lbs/ 27 psi
    2341 lbs/ 28 psi
    2415 lbs/ 29 psi
    2489 lbs/ 30 psi
    2564 lbs/ 31 psi
    2638 lbs/ 32 psi
    2712 lbs/ 33 psi
    2785 lbs/ 34 psi
    2859 lbs/ 35 psi
    2933 lbs/ 36 psi
    3006 lbs/ 37 psi
    3080 lbs/ 38 psi
    3153 lbs/ 39 psi
    3226 lbs/ 40 psi
    3300 lbs/ 41 psi
    3373 lbs/ 42 psi/referencepressure
    3446 lbs/ 43 psi
    3519 lbs/ 44 psi/ sometimes maxcold
    3591 lbs/ 45 psi
    3664 lbs/ 46 psi
    3737 lbs/ 47 psi
    3809 lbs/ 48 psi
    3882 lbs/ 49 psi
    3954 lbs/ 50 psi
    4027 lbs/ 51 psi/ often maxcold
    4099 lbs/ 52 psi
    4171 lbs/ 53 psi
    4243 lbs/ 54 psi
    4315 lbs/ 55 psi
    4387 lbs/ 56 psi
    4459 lbs/ 57 psi
    4531 lbs/ 58 psi
    4603 lbs/ 59 psi
    4675 lbs/ 60 psi/ sometimes maxcold
  14. JM280z
    JM280z Formula Junior
    Aug 22, 2020
    852
    Jake
    255 up front? Do you have rubbing?
  15. Mel Spillman
    Mel Spillman Formula Junior
    704
    Sugar Land, Tx
    I have Novitec NF2 wheels on my 360. 245/35/19 front 29psi, 345/30/19 rear 26 psi. This has worked well for 5 years. Thanks Jadatis for all that info.
  16. ForzaYYZ
    ForzaYYZ Karting
    Sep 4, 2016
    67
    Toronto, Canada
    Sebastian
    Thanks for the advice. The sticker inside the passenger door is no help as that is for original spec wheels and tires.
    I do not have any fender running. I will start at 32 and take it from there.
    JADATIS - you are amazing.
  17. jadatis
    jadatis Rookie
    Nov 26, 2009
    17
    Can make lists for those sises too if you like. Most likely also XL. most ZR low aspect ratio tires are XL.
    This larger sise expected higher maxload, so lower pressure justified.
  18. craze
    craze Formula 3
    1,157
    Melbourne
    Michael
    Ive swapped from pirelli corsa to pilot sport cup 2 connect and on both running 32psi, which is what is says on door card
    Id imagine if michelin dont recommend a pressure then the door card is good advice
  19. jadatis
    jadatis Rookie
    Nov 26, 2009
    17
    If you keep same sises as OEM from orher brand, maxload and referencepressure is the same, so recomended pressure on car can be held.
