348 - Metallic Ringing Noise at Front of Engine | FerrariChat
348 Metallic Ringing Noise at Front of Engine
Discussion in '348/355' started by Jasonberkeley, Oct 31, 2020.
  1. Jasonberkeley
    Jasonberkeley Formula 3
    Apr 23, 2017
    1,321
    NW Corner, CT
    Jason Berkeley
    Last week, after coming off track, I noticed a metallic ringing noise. Upon investigation, it sounds like its coming from under the front timing cover. Certainly the front of the motor, and not under the cam covers.
    I ran it while up in the air on jackstands hoping something obvious and easy like an alternator pulley bearing down low, but it seems higher and more centralized.
    I cant seem to upload .mov files on here, but can send the file to anyone who thinks they can help identify the noise while I wait for a service spot to open at my mechanic.
  2. Andy 355
    Andy 355 Formula Junior
    Jun 2, 2013
    434
    Any noise from the timing belt area is to be investigated immediately. I wonder if a pulley fence has come loose.
  3. jqpd99
    jqpd99 Formula 3
    1,863
    Ottawa
    DFO
  4. GTO Joe
    GTO Joe Formula Junior
    989
    Charlotte, NC
    Joseph Troutwine
    I had the main A/C front bearing making a similar sound especially when cold before engine warm up.
  5. Iltorored
    Iltorored Rookie
    May 17, 2013
    6
    Houston
    John Murphy
  6. Iltorored
    Iltorored Rookie
    May 17, 2013
    6
    Houston
    John Murphy
    I had this bolt loose and was constantly making a ringing noise. One of seversl holding the timing belt cover
  7. Jasonberkeley
    Apr 23, 2017
    1,321
    NW Corner, CT
    Jason Berkeley
    I welded them on at the last major
  8. Jasonberkeley
    Apr 23, 2017
    1,321
    NW Corner, CT
    Jason Berkeley
  9. Jasonberkeley
    Apr 23, 2017
    1,321
    NW Corner, CT
    Jason Berkeley
    No A/C compressor in my car!
  10. Jasonberkeley
    Apr 23, 2017
    1,321
    NW Corner, CT
    Jason Berkeley
  11. Jasonberkeley
    Apr 23, 2017
    1,321
    NW Corner, CT
    Jason Berkeley
    I'll make a more thorough visual inspection tonight and check that area out. Thanks.
  12. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    10,655
    CT
    John Kreskovsky
    Post the move on YouTube.
  13. Jasonberkeley
    Apr 23, 2017
    1,321
    NW Corner, CT
    Jason Berkeley
    Here it is.
    Anyone have any thoughts?
  14. bjwhite
    bjwhite F1 Rookie
    Mar 17, 2006
    4,685
    Seattle, WA
    Brian White
    Wow, that is weird. Sort of sounds like one of those medieval alarm clocks where spinning weights ring the bell. Start at 18:00. (Couldn't find on youtube with a direct link). Makes me wonder if something is flailing about off something spinning and the ringing you hear is it hitting whatever.
  15. jferrante
    jferrante Formula Junior
    Jul 9, 2016
    498
    Almost sounds like waterpump impeller
    Sent from my SM-N975U using Tapatalk
  16. Ferrarium
    Ferrarium F1 Veteran
    5,631
    Central NJ
    Eric
    Oil level fine first of all? could be exhaust/cats... It sounds like a highspeed rattle/knock like a bearing cage or chain related. Could be oil pump, reminds me of mechanical a pump sound actually. I would suspect the timing chain or very possibly the oil pump chain tensioner part 169596 there was a 360 update as the oem ones tended to rattle over time. Never heard one so not sure what it sounds like. Let's hope there is a simpler answer than those I posed.
  17. steved033
    steved033 F1 Veteran
    Apr 12, 2017
    7,710
    Atlanta, GA
    Steve D.
    I agree on bearing or chain-related if it's you've isolated to the front of the engine. It's almost like something has come out of tolerance and is rubbing....like a vintage metal desk fan on it's cage...
    sjd
  18. KevZep
    KevZep Formula Junior
    Feb 17, 2020
    563
    New Zealand
    Kevin Bennett
    Are you sure thats not one of the crank angle sensors rubbing on the pulley? Get your feeler gauges out and see if you have some clearance there...check if they are tight.
  19. Jasonberkeley
    Apr 23, 2017
    1,321
    NW Corner, CT
    Jason Berkeley
    I'll take a look at the crank sensor positioning. A good suggestion. Not sure of anything at this point!
  20. Jasonberkeley
    Apr 23, 2017
    1,321
    NW Corner, CT
    Jason Berkeley
    It's definitely front of the engine outside of the long block assembly.
  21. Jasonberkeley
    Apr 23, 2017
    1,321
    NW Corner, CT
    Jason Berkeley
    Oil level is good, and oil is good. When tracking, I keep it closer to the 'MAX' line on the dipstick in the sump tank, and check it frequently. Oil is clean and clear.
  22. Jasonberkeley
    Apr 23, 2017
    1,321
    NW Corner, CT
    Jason Berkeley
    Water pump was replaced three years ago as part of major. Ultimately, since we just had our first snow here and car was going to go in for annual service shortly anyway, it will go to the mechanic for full diagnosis and proper repair of whatever it is. If the motor has to come out, i'll just do the next major two years early since i'm already paying for the labor to pull it out. Car has more track miles then street miles since the last major, and has always run flawlessly.
    For those who regularly track their 348's, and really drive them hard on track, have you changed your intervals between majors at all?
    bjwhite likes this.
  23. 308 GTB
    308 GTB F1 World Champ
    11,183
    New Jersey
    Barry Wolinsky
    Jason,
    My F355 Challenge gets a major service every four years. It's on the track ~15 days per year at WGI, LRP, Daytona and Sebring. Oil and filter change and brake fluid before each event. Gearbox oil changed before the first event of the season.
    Barry
  24. Jasonberkeley
    Apr 23, 2017
    1,321
    NW Corner, CT
    Jason Berkeley
    Thanks Barry! Excellent reference points for your beqautiful and well maintained machine!
  25. fatbillybob
    Aug 10, 2002
    26,367
    socal
    Sounds like a bearing. Could be a number of things. I like mechanic's stethescopes. High frequency noises can really fool you especially as you get more high freq deaf as you age.
    ernie, 308 GTB, SoCal1 and 1 other person like this.
