Mercedes coolant? | FerrariChat
Mercedes coolant?
Discussion in '348/355' started by Shootfighter65, Apr 18, 2015.
  1. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,372
    Charleston SC
    Randy..alluneedtokno
    I'm close to a bmw and Mercedes dealer today want to pick up some coolant for a flush. Parts department says they have blue and the new one that's clear/pink. Wich should I buy?
  2. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    It's not the answer to your question but my research told me Zerex G-05 is the same formula as the Mercedes coolant except only $12.99/gallon at NAPA.
  3. S-T48
    S-T48 Formula Junior
    575
    Stevenson Ranch, CA
    I would go with what's been tried, blue.
  4. f360nh
    f360nh Karting
    Apr 12, 2014
    210
    NH
    John Q.
    Use the BMW coolant or the Zerex G-05...
  5. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    My BMW dealer wanted an outrageous amount for their coolant so I went with G-05. NAPA was the best price I found.
  6. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    #6 Shootfighter65, Apr 18, 2015
    Napa it is guys. Thanks I did research first but started a new thread because I couldn't find anything about the latest merc antifreeze. The parts guy said I've been here 14 years and never heard of gold.
  7. Rice-Racer
    Rice-Racer Formula Junior
    Jan 10, 2015
    252
    Zerex G 05, is same as Mercedes, use it in my Mercedes, dealer says it's fine to use as well. Just stay away from Dexcool.
  8. GTSNJ
    GTSNJ Formula Junior
    Jan 18, 2015
    478
  9. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Personal communication with shops that know more than most and who I trust:
    Algar: Shell premixed , undiluted
    Well known shop in CO: BMW
    The shell is $65 a gallon from what I can see.
    I'm sticking with BMW as I said at the top.
  10. joshtownsend
    joshtownsend Formula Junior
    Jul 12, 2007
    421
    H-town...TEXAS
    haha and why is that?? is Ferrari aluminum different from GM ?? is one bearing in the water pump have a bad break up with Dexcool and now none of them will have anything to do with it?
  11. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Dexcool doesn't mix with other coolants. It's the sole reason this whole coolant compatibility thing gets confusing.
  12. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,141
    CT
    John Kreskovsky
    Shell and G-05 are good for use in cars with cylinder liners. And of course Ferrari dealers would recommend Shell. Shell is a Ferrari F1 sponsor.
  13. GTSNJ
    Jan 18, 2015
    478
    U can use Walmart coolant and your 355 won't notice the difference. Yet one would suddenly blame it on making the 20 year old radiators leak. Hahahahaha
  14. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Wet liner cavitation is an issue in heavy duty Diesel engines with compression numbers of 300-400 psi and liner wall flexing. They are also present in engines designed for liner replacement that may have "sloppier fit"
    Out cars barely get over 200 psi and the liner wall tolerances are such that cylinder wall flexing causing cavitation in the wet liner is a not an issue.
    The presence of nitrites in the coolant is not relevant to coolant choice.
    From those who know.
  15. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    The big question is how will using Wal-Mart coolant affect the future value of a car. Will a car that has receipts from the Ferrari dealer for the correct coolant be worth more ?please provide your vin number so we can add your car to the list of devalued , improperly maintained cars .
  16. johnk...
    Jun 11, 2004
    11,141
    CT
    John Kreskovsky
    Bob, then why does Ferrari recommend Shell? All but their Ultra antifreeze contain nitrites, and all are claimed to provide liner protection. Oh, wait. Shell is an Ferrari F1 sponsor. Did I mention that before? Bigger point. You may or may not need liner protection, but it won't hurt to have it.
  17. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    That wet liner stuff had no basis in out cars. It's az standard that some manufactures have adopted for their products. It is not necessary in these cars. It was adopted for high output Diesel engines.
    If it had it great , but liner wall
    Cavitation is really pushing it.
  18. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    please expand you have caught my interest
  19. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,611
    The Brickyard
    The Bad Guy
  20. GTSNJ
    Jan 18, 2015
    478
    #20 GTSNJ, Apr 28, 2015
    MERCEDES BENZ, MADE IN GERMANY. YOU KNOW THE GERMANS MAKE GOOD STUFF.
    In all seriousness, I have taken apart 10 year old benz motors that never had their coolant changed on all alloy/aluminum blocks/heads m112's , m103's (cast iron block), and there is never a trace of corrosion in those when the benz coolant is used. Start mixing different ones into the car, and then you get some nice sediment and corrosion.
    Also, the water you mix with the coolant is honestly equally important. Don't use your hose, invest in quality disilled water. This prevents the corrosion and deposits from minerals naturally in water.
    I never tried the shell coolant...maybe ill give it a go next time.
  21. ernie
    Nov 19, 2001
    22,611
    The Brickyard
    The Bad Guy
    .89¢ for a gallon at WalMart.
  22. tazandjan
    39,007
    #22 tazandjan, Apr 29, 2015
    Mercedes used Zerex G-05 for several years but have now switched to a non-nitrite coolant that is essentially Zerex G-48. Non-nitrite coolant tends to last longer than ones with nitrites, but Mercedes, BMW and Porsche engines do not have wet liners, so nitrites are not a concern. Hence their "permanent" coolant that follow-on owners will pay for down the line. The wet liners on Ferraris do require nitrites, Bob, and liner erosion from cavitation is a proven problem on Ferraris.
    Here is the data and you can make up your own mind, but I would not be using a coolant not designed for wet liners. Zerex G-05 is an outstanding coolant and is in my Ferrari.
  23. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    #23 drbob101, Apr 29, 2015
    Thanks for that Terry.
    I was told on good authority that cavitation was not an issue on our cars (355s). I do not have hard evidence either way to support or contradict that. I searched and didn't see any mention or documentation of cavitation damage to cylinder liners in 355s. It was an interesting topic to research though.
    I'm sure that all of the coolants mentioned will do the job and if changed and checked regularly will work well. I know Brian has gone to recommending yearly coolant changes as well.
  24. AceMaster
    Feb 6, 2009
    34,749
    Ontario, Canada
    Terry, thank you for this.
  25. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,990
    Northeast U.S.
    Jim
    Good information guys. Thanks.
