360 - measured a used 360 flywheel taper | FerrariChat
360 measured a used 360 flywheel taper
Discussion in '360/430' started by 24000rpm, Jan 17, 2020.
  1. 24000rpm
    24000rpm F1 Rookie
    #1 24000rpm, Jan 17, 2020
    tifosi101 and imahorse like this.
  2. Rifledriver
    33,989
    Austin TX
    It will vary a lot depending on how hot it gets and how much it gets hot. I have seen a lot more than that and in fewer miles. .
    24000rpm likes this.
  3. becausephilchow
    becausephilchow Formula Junior
    Aug 26, 2016
    543
    Hong Kong
    Interesting. I'll be going with the Hill Engineering Flywheel when I do my clutch in the next month or so.
  4. Rifledriver
    33,989
    Austin TX
    I have never needed to replace one. I know a lot of shops who had so much trouble getting them surfaced correctly they replace them. I bought a few of those so I had some spares sitting on the shelf surfaced and ready to install.
    f355spider likes this.
  5. 24000rpm
    24000rpm F1 Rookie
  6. duck.co.za
    duck.co.za Formula Junior
    Jan 9, 2007
    981
    Cape Town South Afri
    Dave
    Tell me I'm wrong , but that surface has been machined in a lathe . Should it not have been ground ?
  7. Rifledriver
    33,989
    Austin TX
    I agree. Lathes do not cut hot spotted surfaces well at all. I'd never install that.
  8. 24000rpm
    24000rpm F1 Rookie
    i am not sure what it is. I have a picture though, let me find it
  9. 24000rpm
    24000rpm F1 Rookie
    thank you for the advice.
  10. RedTaxi
    RedTaxi F1 Rookie
    3,253
    New Zealand
    Glen
    A good clutch place will have the proper grinding machine.
  11. 24000rpm
    24000rpm F1 Rookie
  12. duck.co.za
    Jan 9, 2007
    981
    Dave
    Did the stone turn/rotate ? You then get a circular cut while the flywheel is also turning .
  13. duck.co.za
    Jan 9, 2007
    981
    Dave
  14. 24000rpm
    24000rpm F1 Rookie
    i see, no the stone doesn't turn, the flywheel turns
  15. RedTaxi
    RedTaxi F1 Rookie
    3,253
    New Zealand
    Glen
    Um, the cup wheel stone is meant to spin, fast.
