McFlyAF a DeLorean Build | Page 2 | FerrariChat
Discussion in 'General Automotive Discussion' started by white out, Jul 7, 2019.
  1. white out
    white out Formula 3
    Mar 3, 2010
    1,306
    Stock motor will not live up to the suspension/brakes/tires. But the rear tire dropping 2" in height over the stock 60 series should help with the tall gearing. But as of right now I'm not concerned with power, I just want to drive it.
    Smiles likes this.
  2. David_S
    David_S F1 World Champ
    11,260
    Mountains of WNC...
    David S.
    THIS is what I'd do, in the end... ;)
  3. white out
    white out Formula 3
    Mar 3, 2010
    1,306
    Fabrication for all the brakes are now complete. So here are some shots.
    Front rotor comparison:
    on the car comparison:
    Rear rotor comparison:
    Rear brake bracket was a nightmare to make, but the machinist was able to come up with a solution.
    Completed rear suspension, brake, wheel and tire assembly
    In other news, the Viper had a u-joint strap fail on a WOT 1-2 shift and took out an axle and the rear diff. So 3 of my 4 cars are officially in the air.
    Boomhauer likes this.
  4. white out
    white out Formula 3
    Mar 3, 2010
    1,306
  5. tbakowsky
    Sep 18, 2002
    20,044
    The Cold North
    Tom
    Vipers..gotta love em..
  6. white out
    white out Formula 3
    Mar 3, 2010
    1,306
    tbakowsky likes this.
  7. tbakowsky
    Sep 18, 2002
    20,044
    The Cold North
    Tom
    They are awsome fun. I'll never forget when I first got behined the wheel of one. I could not believe they could legally sell such a weapon to the open public..unreal
  8. 355dreamer
    355dreamer F1 World Champ
    Apr 3, 2006
    10,476
    DC Metro
    L.C.
    Remember to contact me when you get sick of the DMC. :)
  9. Cotton
    Cotton Formula Junior
    Dec 11, 2008
    414
    TN
    Put me second in line!
  10. Manda racing
    Manda racing Formula 3
    Feb 25, 2015
    1,270
    Bakersfield, Ca
    Mark
    BMW.SauberF1Team likes this.
  11. xotik
    xotik Formula Junior
    Feb 23, 2009
    260
    Gulf Coast
    Chad
    I like the suspension work you did. Neat build. Waiting to see more!
  12. white out
    white out Formula 3
    Mar 3, 2010
    1,306
  13. white out
    white out Formula 3
    Mar 3, 2010
    1,306
    Took the DMC out for lunch today, it was all good. Such an easy car to drive.
    On the way home, hit a big bump and a few hundred feet later it dies. Definitely fuel related.
    Talk to my buddy who got it road worthy and explained how there was a part of the fuse box with a melted housing for a 20AMP fuse and thought that was the likely issue, he threw in a spare 20AMP fuse in case there was a future issue. I check it and bingo, fuse popped.
    New fuse in and I'm off. 4 miles down the road it popped again.
    Something moved when I hit that bump and is grounding out the fuse for the fuel pump. Time to hunt that down.
  14. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,675
    Pittsburgh, PA
    Matt F
    Very cool!
    Matt
  15. 6t7
    6t7 Karting
    Aug 19, 2012
    192
    Oz
    Brett
    Just found what you’re doing and loving it already. Interesting history re. The DMC company.
    I’ve often thought the basis of the car is pretty cool but the motor is weak and the wheels are very outdated (I realise there’s the originality factor) so it’d be interesting to see what could be done with a Delorean.
    Your build is my new Netflix binge
  16. 6t7
    6t7 Karting
    Aug 19, 2012
    192
    Oz
    Brett
    Ok, I’ve read it all now.
    Love the brakes and suspension work.
    Imagine it with a 360 powerplant.
    Bet those brakes would pull it up no problem with a twin turbo setup.
    On behalf of the F-Chat community we approve!
    Looking forward to more reading
  17. jferrante
    jferrante Formula Junior
    Jul 9, 2016
    498
  18. Ak Jim
    Ak Jim F1 Veteran
    9,754
    North Pole AK
    Any thoughts about doing an engine swap?
    https://performanceparts.ford.com/part/M-6007-23TA
    Ford Performance offers the high tech, 2018 Mustang 2.3L EcoBoost turbocharged engine as a crate engine kit. With turbocharging, direct injection and twin independent variable cam timing (Ti-VCT), this kind of performance comes standard with a dose of adrenaline. The swap possibilities are almost endless; from early street rods, kit cars, most generations of Mustang, to just about any other vehicle build. The Ford Performance Control Pack helps make for an easy plug and play installation (available separately).
    • 2.3L EcoBoost engine as used in the 2018 Mustang
    • 310HP/350 lb.-ft. Torque @ 3,000 rpm (with 93 octane fuel)
    • Designed for traditional rear drive installations
    Would be quite a step up from the original plus probably weighs quite a bit less.
  19. white out
    white out Formula 3
    Mar 3, 2010
    1,306
    It's definitely on my mind and we just happen to have a Kia V6TT race motor that is looking for a home. Good for 450whp on low boost.
  20. Ak Jim
    Ak Jim F1 Veteran
    9,754
    North Pole AK
    Wow! Over 3X the original HP, should be some serious fun.
  21. white out
    white out Formula 3
    Mar 3, 2010
    1,306
  22. white out
    white out Formula 3
    Mar 3, 2010
    1,306
  23. white out
    white out Formula 3
    Mar 3, 2010
    1,306
    Just put up a fun story on instagram @LAMBORfuckinghini
  24. white out
    white out Formula 3
    Mar 3, 2010
    1,306
    jferrante likes this.
