Maserati Ghibli (1966 - 1973) | Page 107 | FerrariChat
Discussion in 'Maserati' started by miuras, Feb 27, 2007.
  1. red27
    red27 Formula Junior
    Sep 7, 2010
    921
    London UK
    Mark Oliver
    Not wishing to derail the Khamsin thread, I think this Ghibli referred to recently is in fact Rosso Cordoba. 106R7.
    Alex Fyshe, the ex president of the UK Maserati club had 115/49/1956 for many years in the same colour and it won multiple awards. Image Unavailable, Please Login
    best to all.
    Mark
  2. Nembo1777
    Nembo1777 F1 World Champ
    Nov 4, 2006
    11,305
    opposite lock
    Marc Sonnery
  3. Mexico074
    Mexico074 Formula 3
    Aug 14, 2008
    1,279
    Harriman, TN USA
    Michael Demyanovich
    Another thought...
    Could that actually be Bleu Sera Metallizato (spelling may be incorrect), which is what is
    on my Ghibli.. In certain lights, like bright sunlight, it looks a little purple, like in the picture...
  4. red27
    Sep 7, 2010
    921
    London UK
    Mark Oliver
    So difficult to tell on a monitor. Here is a picture of 1956 from the Bonhams catalogue. I still think it looks similar. It is actually quire dark on the colour wheel swatch. Like a very ripe cherry.
  5. wbaeumer
    wbaeumer F1 Veteran
    Mar 4, 2005
    8,970
    This is in fact #1956, the car once owned by the late Alex Fyshe.
    and for those, who knew him: Alex passed away almost 2 weeks ago....
    staatsof likes this.
  6. staatsof
    95,319
    Fuggetaboutitland
    Bob
    I thought he was gone way before that. RIP. He was a character when showed up in Monterey wearing the Union Jack as a complete outfit. That was a long time ago.
  7. Nembo1777
    Nov 4, 2006
    11,305
    opposite lock
    Marc Sonnery
    RIP to a great and memorable character.
  8. wbaeumer
    wbaeumer F1 Veteran
    Mar 4, 2005
    8,970
    Well, these notorious trousers, signed by all F1-drivers incl. Fangio, Alex loved so much. These trousers were so worn out, that we all believed that they were walking alone...
    Yes, Alex was a true character. May he R.I.P.
  9. Mexico074
    Mexico074 Formula 3
    Aug 14, 2008
    1,279
    Harriman, TN USA
    Michael Demyanovich
    My Ghibli SS engine is nearing completion. I was able to see it run on the
    engine builders test stand about 2 weeks ago. Seems to be running great!
    The builder is looking for a picture or schematic of the front of the engine
    with the A/C compressor, the power steering pump, and the alternator hooked up.
    It would be great if the picture of the engine was out of the car! Perhaps someone
    can help me with this?
    We want to be absolutely sure we have things set up correctly. Since the car
    has power (hydraulic) steering, I believe there is no idler pulley associated with
    the set up for the belts. We don't recall one being there when the engine was taken
    apart. If I recall correctly, the belts can be adjusted at both the alternator and
    the power steering pump.
    Any help would be appreciated!
    Thanks...
    71Satisfaction and staatsof like this.
  10. red27
    Sep 7, 2010
    921
    London UK
    Mark Oliver
    Hi Mike. I should be able to help I think. I will post some pictures tomorrow and can supply more if they’re not what you need.
    Cheers.
    Mark
  11. red27
    Sep 7, 2010
    921
    London UK
    Mark Oliver
    lgs likes this.
  12. thecarnut
    thecarnut F1 Rookie
    3,198
    Atlanta
    The Car Nut
    Ghiblis came with different belt and bracket configurations depending on if it is an early or late engine and if it was USA or Euro specs. Mike's car is a late model USA car which has the alternator mounted backwards. This was done to permit the mounting of an air pump. Ghiblis without power steering had a idler adjuster for the water pump belts while those with power steering many times did not have the adjuster and the belts were tightened by sliding the power steering pump (which is a pain).
    This is a photo of a USA 72 SS with the air pump still in place. These days this is a rare sight as most have discarded the air pumps.
    Mike: my suggestion is have Sam mount the power steering pump (goes on the lower left), the water pump and AC, and the alternator. If he has the belts in hand and labeled, the routing will become obvious once the accessories are installed. The second photo shows the alternator mounting and you can see where the power steering bracket is attached on the bottom right of the photo..
    Ivan
    Froggie likes this.
  13. bobj123
    bobj123 Rookie
    Dec 13, 2016
    49
    I own 115/49*1550*. I'm trying to sort out the wiring. Does anyone have a wiring diagram that applies to 1970 production year US models? I bought the expanded wiring diagram from a west coast based parts source but no joy. Wire colours are different.
  14. thecarnut
    thecarnut F1 Rookie
    3,198
    Atlanta
    The Car Nut
    Using a wiring diagram on a Ghibli seldom does any good. Your best friends are a multimeter and an electronic wire tracer. Electrically these are very simple cars. Which circuit(s) do you need to sort out? I might be able to help if you provide details of what is not working.
    Ivan
  15. GBear
    GBear Rookie
    Jul 1, 2015
    15
  16. staatsof
    95,319
    Fuggetaboutitland
    Bob
    That most likely would be Claus Groth from Thousand Oaks. Not sure he's still around? He had a gorgeous Ghibli that caught fire on Mulholland I think. Total loss. He also restored a Bora meticulously and sold it a few years back to the former owner of MIE Kerry. This sounds like something he would have done.
    Good find!
  17. bobj123
    bobj123 Rookie
    Dec 13, 2016
    49
    A previous owner really did a number on the steering column switches and associated wiring. Only the turn signal indicator arm functioned. Rather than buying the proper replacement switches, the owner installed four aftermarket switched in the middle of the dashboard between the two air vents. He also re-routed the wiring to make all this work. I've found an Alfa Romeo steering column switch that has three arms: wiper/wash, turn signal and lights. I think I can adapt the Alfa column switches to work. Of course the wiring colour codes are different than my original (mostly) broken steering column switch. I've yet to find what happened to the two wires that supply the windshield washer bottle. There doesn't seem to be a wire diagram that matches my original wiring colours. Here is a picture of what my dashboard should look like Image Unavailable, Please Login
  18. thecarnut
    thecarnut F1 Rookie
    3,198
    Atlanta
    The Car Nut
    Have you pulled the stalk switch cluster from the steering wheel? Does it still have the red and white connectors on the switch and on the Ghibli's wiring harness? It would really help if you post photos of your steering column and console so we can better see what has been done.
    This is a wiring diagram of the Vitaloni stalk switch. ANY Maserati wiring diagram should only be used as a guide and not necessarily represents the original wiring of your car.
    https://thecarnut.com/wp-content/uploads/2021/05/GhibliVitaloniStalk.pdf
    While many Vitaloni switches look similar to that of the Ghibli you may find that the shaft diameter on the Alfa switch is different. Best to find a switch that is known to work on a Ghibli. MIE at one point was selling a reproduction.
    Ivan
  19. emsiegel13
    emsiegel13 Formula Junior
    536
    Grayslake, Illinis
    Elliot M. Siegel
    There is a company in California which does an outstanding job of repairing the Vitaloni stalk switches. They have done some for me and they are rebuild to better than new condition with the repairs updating the weak spots that cause many of the failures in the Vitaloni switches. The company is O.D.D. Parts and they have a website that you can access. I recommend them highly.
  20. bobj123
    bobj123 Rookie
    Dec 13, 2016
    49
    I have removed the steering wheel and the original steering column switch cluster (what little is left of it). The original switch cluster was badly damaged. Only the turn signals worked. The windshield wiper/washer stalk was destroyed along with the headlight module. The original wiring clusters had the red and white multipin connectors. I obtained my new Vitaloni column switch from Cyprus. It looks like it will fit with some modifications. I plan to transfer the original wires to the NOS Vitaloni switch. I have identified what 90% of the wires do. Fortunately, almost all of my electrical functions work correctly when power is applied to their respective conductors. I have not found what pair of wires go to the windshield washer bottle. I bought a NOS bottle from Lucas Classic. I'll post some pictures of the original Vitaloni switch and the NOS Alfa Romeo switch I'm hoping to modify. I'll also include a picture of the wires that I have labelled. My biggest problem is the DPO wired short cuts with lamp wire and four aftermarket rocker switches to take on the functions performed by the steering column switches. If my modification to the NOS Vitaloni don't work, I'll follow up on the sources you both mentioned. I was aware somebody was doing a reproduction switch but was not aware of who was doing it. Many thanks for the company's name. today, I started the process of doing an epoxy repair of the massive hole that was cut in the fiberglass (DPO!) to mount the four aftermarket rocker switches. Stay tuned for the pictures. FYI - my original Vitaloni switch did not have an exact match for all the conductors shown in the Vitaloni wiring diagram. About 85% were identical.
  21. thecarnut
    thecarnut F1 Rookie
    3,198
    Atlanta
    The Car Nut
    Try using an electronic wire tracer:
    https://www.ebay.com/itm/175466404246?hash=item28da9cd996:g:IWYAAOSwYQNgXcBS&amdata=enc%3AAQAHAAAAoKO%2F7b8Srm3dlgV1z12jy7trvGCtRKtOFBcVnsfljdG4WX31QI%2BecWPToSlrCoaeo1PbWcNFfA6zem0dAVUUb2A0U%2FjP3QHBE%2FNYJiCngnEbJlyPKDZ0INw864A2iwiHbgFT02cv5GDlQVtBFqEOMy61kMbb5j2tG4YLvbd7RiY5Vw9Q9VTCXh7wSCscHzfdzcW6MlhL52oq38%2FifViS3Iw%3D%7Ctkp%3ABk9SR4KM84GHYQ
    If I recall, the windshield washer has one wire that is always hot and the other goes to the switch cluster where it is grounded to make the washer motor run. In other words, you are looking for a single wire not a pair.
    Ivan
  22. bobj123
    bobj123 Rookie
    Dec 13, 2016
    49
    I'm back on wiring tomorrow. I'll check for the single ground. There is a large white that enters a wiring cluster shared by a smaller diameter white and a red wire right behind the instruments (roughly center). More detective work to follow tomorrow. I'll try to get pictures tomorrow. I'm giving my multimeter a good work out on continuity and voltage modes. If my Alfa switch is not adaptable, I'll call the folks in California.
  23. bobj123
    bobj123 Rookie
    Dec 13, 2016
    49
    I bought the tracer on ebay. looks like a useful tool. Thanks for the link.
  24. bobj123
    bobj123 Rookie
    Dec 13, 2016
    49
    Jim Simpson at ODD Parts was a huge help. More wiring nightmares discovered today.
    71Satisfaction likes this.
