360 - Manual Transmission Rebuild/Replace | FerrariChat
360 Manual Transmission Rebuild/Replace
Discussion in '360/430' started by Ballvice, Sep 1, 2020.
  1. Ballvice
    Ballvice Karting
    Oct 19, 2019
    121
    Georgia
    Frank Ball
    Sigh -it happens ... ;)
    I have a 99 Gated 360 --- I have developed a whine in 5th and 6th gear - pretty pronounced - not getting better....
    regardless of the "cause" - this is probably going to require 1 of 2 things... A rebuild - or a replace...
    so two questions for the group...
    1 - Rebuild - has anyone PERSONALLY had their 360 gear box rebuilt - and do you have someone you would recommend? Humbly - I am looking for someone with ACTUAL experience please - no offense - but I don't want a "I know a guy..." too much can go wrong --- if you're tracking ;)
    2 - Replace - is there an internal difference between the manual gated and the F1? Would an F1 drop into a gated 360? Supposedly it is a "manual" hydralic so is it the "same" gearbox?
    Thank to all in advance -
  2. 24000rpm
    24000rpm F1 Rookie
    1. well I didn't actually rebuild a 360 gearbox but I did open up the whole thing and check for synchros and gears, just for curiosity. Took me 2 weeks, about 3 hours a day, including removing the gearbox itself, all by myself, except when physically separating the gearbox from the engine, I got a little help from a buddy. I personally think they are quite straight forward to replace be it a bad synchro or a worn gear, etc.
    2. according to parts diagrams, no , there's no difference, even there are, they are interchangeable.
    UrbanHero, Kevin Rev'n and imahorse like this.
  3. Ballvice
    Ballvice Karting
    Oct 19, 2019
    121
    Georgia
    Frank Ball
    THIS!!!!!! ;)
    PERFECTO ;) - a couple of questions...
    How long ago was this?
    PS - This is what I suspected - how hard was it to source the parts?
    Rough idea the parts costs?
    I 100% suspect a failing bearing with the whine - but if I am going to pull it out - may as well be prepared to refresh it all.
    The one person I trust locally to do it is slammed getting ready for the Run-offs - so I'm on the fence.
    Low milage F1 is about 8-9K so Im on the fence - would prefer to rebuild vs - replace -
    TY SO MUCH for the awesome reply
  4. 24000rpm
    24000rpm F1 Rookie
    like Dec.2019.
    parts? scuderiacarparts.com, ricambiamerica.com , or even ebay for used parts. If you have enough experience to eye-ball the part's wear and tear, a good used parts is not much different from a new one. Except bearings of course. You can't tell a bearing's health by just looking at it. LOL.
    I am in China so I can't help you with that.
    my personal practice is that, if the part isn't worn, don't replace it, especially gearbox parts. Some gears in my 40k kilometer car is just as new ones.
    If you are hiring somebody else to do it, labor could be more than parts, I believe.
  5. Ballvice
    Ballvice Karting
    Oct 19, 2019
    121
    Georgia
    Frank Ball
    yeah - it's over my pay grade to tear open a gear box - so it will be done by someone else -
    I guess the moral of the story is you really don't know until you crack it open -
  6. toussi1
    toussi1 Karting
    Jun 10, 2007
    160
    How many miles and was the gear oil changed every few years?
  7. Ballvice
    Ballvice Karting
    Oct 19, 2019
    121
    Georgia
    Frank Ball
    I bought the car in January. So I have not had it that long. The service records were not complete
  8. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,822
    Memphis, TN
    Maybe a stupid question: Have you checked for an oil sheen in your coolant tank? The symptoms you describe could be a failed heat exchanger. When coolant gets into your transmission, bad things happen.
    sparetireless, 2NA and imahorse like this.
  9. Some Guy in the sky
    Some Guy in the sky Formula Junior
    Sep 19, 2018
    355
    I actually have an early 99 that needed a trans rebuild in 2017 (gated). The parts that ended up being replaced were the 1/2 synchro, the 3/4 synchro a roller bearing part number 184020 and some bushings. The Boston Sportscar Company did the work. This was before I bought the car So I don't really have any other details other than that. All that I can say is that is shifts very well now.
  10. Ballvice
    Ballvice Karting
    Oct 19, 2019
    121
    Georgia
    Frank Ball
    I haven't drained the fluid yet - but it's the top priority ---
    1 - Metal present?
    2- Fluid color
    3 - Fluid volume (I am hoping they got it right when they changed ALL of the fluids in the car)
    Great advice - I will update everyone this week
  11. 24000rpm
    24000rpm F1 Rookie
    can you drain the gearbox fluid yourself? you only need to remove the rear belly pan to access the hole.
    take a picture of the drained fluid and the drain plug itself so that we can determine if there's coolant in your gearbox
  12. imahorse
    imahorse F1 Rookie
    4,267
    WI
    Dustin
    When your drain the fluid, if you are comfortable pulling the rear bumper (not too difficult. Aldous has a great step by step) I'd recommend checking the screen filter on the side of the gearbox.
  13. sparetireless
    sparetireless Formula 3
    Nov 2, 2003
    1,582
    Change the motor mounts first if they are not new, will clean up many noises
  14. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner Rossa Subscribed
    Jan 19, 2004
    7,782
    San Jose, California
    Frank, you have a PM.
