Mannatino failure light came on | FerrariChat
Discussion in '612/599' started by gam4, Jan 18, 2021.
  1. gam4
    gam4 Formula Junior
    569
    The mannattino light came on my 599. It comes on after about 10-15 minutes of driving then shuts off when I turn car off. Has anyone had this light come on before and identified the issue? TU
  2. brogenville
    brogenville Formula 3
    2,020
    Robin
    What’s the battery health like?
    Stock answer, but poor battery condition can cause wired faults like these.
    Stock answer no. 2 is to scan the various modules for any stored fault codes.
  3. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,376
    Weston, MA
    Paul
    Bingo above, and I might add .......
    Stock answer no. 3 is sometimes with a little luck it just goes away by itself. :)
  4. gam4
    gam4 Formula Junior
    569
  5. Justin Hughes
    Justin Hughes Karting
    156
    Oxfordshire - UK
    Hughesie
    Mine was caused by a wet ECU in the drivers door weirdly !
  6. brogenville
    2,020
    Robin
    Ahhhh... that actually make a bit of sense.... the door ecu's and the steering wheel node are both on the B-CAN. If the water was interrupting communication on the B-CAN, then this could show up as any kind of network fault on the B-CAN. Manetino error is likely whats shown in the dash, as that would be the highest priority system on that network.
    HK Mondial and 599_GTO like this.
