Maintenance cost - 360 F1 | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by Bob Zambelli, Aug 2, 2017.
  1. Bob Zambelli
    Bob Zambelli F1 Rookie
    3,624
    Manning, SC
    Robert G. Zambelli
    Met a fellow yesterday who is considering buying a used 360.
    He will have a PPI done here in the northeast, probably at Algar.
    He asked me about annual costs (routine) but having no experience with the more modern cars, I could not give a reasonable answer.
    The car, a coupe, has just under 36,000 miles.
    It has had all required maintenance done but not by a Ferrari dealer.
    Assuming the PPI is good, what can he expect to spend on yearly maintenance?
    He estimates that he will drive it around 4,000 miles/year and have ALL work done by the dealer.
    Any advice would be appreciated.
    Thanks, Bob Z.
  2. Bob in Makiki
    Bob in Makiki Formula Junior
    May 30, 2017
    455
    Honolulu
    You might get a better response in the 360/430 forum. I just bought a 2003 360 Spider and have spent a fair amount of time with the local dealership, its mechanic, and reading the comments of others. My car is in good shape (at least, so it appears) and I am budgeting between $4,000 and $5,000 a year for the general maintenance a car of this age will need. That does not include cosmetic costs -- if you detail your car regularly, have special paint or leather treatment, or replace or add 3mm covers, you can add quite a bit to that. With an F1 360 if you are hard on your clutch, you can add quite a bit to that. And, if your car is in great shape and has had a good bit of recent work, you can probably reduce that estimate!
  3. PFSEX
    PFSEX Formula Junior
    Jun 30, 2006
    843
    Las Vegas
    John Ratto
    I have a 360 coupe manual transmission with about 25K miles. I drive it about 2,000 miles per year.
    I am on 'the four year plan.'
    Prices are approximations - I am going high because other little things pop up.
    Cam belts and full service all fluids once every 4 years $5,000
    1 Additional full fluid service $1,500
    2 additional oil changes $ 800
    1 set of tires $1,200
    1 Battery $ 300
    Budget for 1 additional repair $1,000
    So, that is a generous $9,500 for 4 years and about 8,000 miles of driving
    About $2,500 per year
  4. daveyator
    daveyator Formula Junior
    Jun 10, 2014
    292
    Yucaipa, CA
    Dave B
    Mine will have cost me (in for major right now) $17000 over 3 years which comes out to $5667 per year. 6500mi over the 3 years. 360 spider.
  5. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,323
    Honolulu
    Kevin
    This is a pretty good number but only if the car is in great condition to start, definitely not less, but I prefer to use 3K for a little more peace of mind, especially if the new owner is only using the dealer and no DIY.
    I try to be as hands on as possible and constantly learning about the car which are also part of the ownership experience for me so I have saved myself a few smallish expenses and trips to the dealer.
    Disclaimer: experience based on the simplest mechanical car to roll off the assembly line (coupe/gated).
  6. Kevin Rev'n
    Nov 29, 2009
    24,323
    Honolulu
    Kevin
    You have paid forward here yes?
    Clutch? and...
    Some "other" big issue(s)? and...
    Regular maintenance.
    Mine has been yearly serviced by an authorized dealer except one year that I didn't drive much and performed my own oil change just to see what was involved and replace an oil temp sensor that was acting up.
    I have put 10K miles on mine in 4.5 years and had one big major service of 6K. It was a full belt, FULL fluid service with differential oil, new cam seals and a couple other weird things thrown in. (bad alternator cable and a broken weld repaired on a muffler bracket).
    The only way I could get to your number is if I needed a clutch, tires, perhaps a new leather dash installed and maybe a full set of brake rotors due to poor management of the pads and/or ???
    What happened to your car?
  7. Kevin Rev'n
    Nov 29, 2009
    24,323
    Honolulu
    Kevin
  8. Bob in Makiki
    May 30, 2017
    455
    Honolulu
    #9 Bob in Makiki, Aug 2, 2017
    John: Thanks for your $2,500 estimate, and I hope you are right. But your numbers are a little low for where I live (and perhaps where others live). I have just gotten prices from our local dealership. Cam belts, etc. are about $4,000. Full service is about $4,000. That would bump your total up (where I live) by $5,500 to start. You also do not include the cost of clutch or brakes, which are both items that wear in the normal course. I have not yet had the pleasure of pricing those here. So, I hope you indeed average $2,500. If I can average less than twice that, I will still be happy!
    P.S. Kevin lives where I live, but is obviously smarter than me and keeps his costs lower! That proves it can be done.
  9. Bob in Makiki
    May 30, 2017
    455
    Honolulu
    It occurs to me that some context might also be helpful. If I had bought a new Porsche for about the same price as my 360, in the first year I would have had zero maintenance costs, but the depreciation would have been about $16,000. (At this point I think the depreciation on the 360 bottomed out two or three years ago.) That makes my maintenance bill for the 360 more palatable to me.
  10. Kevin Rev'n
    Nov 29, 2009
    24,323
    Honolulu
    Kevin
    #11 Kevin Rev'n, Aug 2, 2017
    Bob, the Cam Belt service is the "full service" at our awesome dealership (Thanks to our master tech Aron) and that number is right. So every 3-5 years (depending on your plan) you will see this. Then your annual service is about half of that for a gated car, little less actually. This is also a "full service" all fluids. It's a little extra to have them do the differential fluid and you will want to do this every other year. I don't know about the F-1 equipped cars though or convertibles. There is more to stay on top of for sure. So far each year "something weird" end up needing a look at just because of the age of our cars.
    Non scheduled maintenance items I have encountered and tackled myself are:
    Ball Joints, one was bad but I replaced both sides. Our roads suck so you will see this too one fine day. I DIY'ed this to the tune of about 1000 in parts but I dont think the labor from our shop would have been excessive. It's straight forward work if you are used to using tools!
    Oil Pressure sensor went south. Cheap and easy to do but I used the excuse to buy an awesome hill engineering oil filter removal tool so there was ~300 bucks and an hour of my time.
    Oil temp sensor was acting up (lots of movement in the readout) I had wanted to do an oil chance ever since I got the car and when I saw that the sender is accessed with oil drained I went for it. Sensor and Oil/Filter ~200. I think a straight oil change from the dealer is around 400 so that is within reason to me.
    Headliner failed! This one I lived with for a while but finally decided to tackle it myself and was much easier than I thought and the results are awesome. Now I have a sweet alcantera one. ~75 bucks in parts.
    Loose engine access cover insulation. I saw that the foil was coming off so I R/R the engine access hatch and re-glued it on. Dealership said they would have done it for me for nothing since I had taken it in for service a month or so earlier! :)
    I adjusted the heat shield on my aftermarket air intake that was a little tricky for me. It was rubbing on my aftermarket exhaust. The dealer probably could have banged it out in a couple of hours but it was the first thing I did when I got the car so I was slow and methodical.
    I have K&N specialty air filters that are part of my aftermarket intake. I clean and oil these every year myself. It would be a hassle to take it to the dealership for this. The worst part is waiting for the clean filter to dry before applying a fresh spray of oil.
    EDIT:
    Couple of batteries....
    My front boot accessory straps failed so I bought some new ones in leather and installed them. More to this than I thought going in as you have to remove all the carpet parts in the boot and drill out a bunch of rivets, etc. The screws are different sizes and installation glue from the carpet got gummed up in the threads making the job not that fun but the results are good!
  11. Bob in Makiki
    May 30, 2017
    455
    Honolulu
    Yep, cam belt service is about $4,000, and that includes some other things like new seals.
    But the full annual service (not including the belts) is also about $4,000. That includes everything (like AC recharge and filter). That's just the estimate I have in hand. Next week I can tell you exactly what was included in that, and it may include things that I won't normally need every year or every other year. I told Aron I wanted a clean start, so I think he is doing everything he thinks might be necessary. I am assuming I will need that every other year, but maybe I will be lucky and find the costs are reduced in the future. (Or maybe it is the difference in an F1 and a gated transmission). I suppose I will find out over time. But even if the annual service does run that high, it won't bother me much. What I would prefer to avoid is the unexpected $10,000 random repair bill, and it sounds like the 360 usually (not always) is not subject to those surprises.
    I'm impressed with all you have done! And as you wrote previously, constantly learning about the car is part of the ownership experience.
    Which is one reason I appreciate FerrariChat!
  12. Kevin Rev'n
    Nov 29, 2009
    24,323
    Honolulu
    Kevin
    It probably includes some catch-up items then. I am thinking cam shaft seals and differential fluid at a minimum. You have to remove the rear bumper to do the later. Add in something else that is unique to your F-1 car and I see where you are coming from.
    Ha! Me too! I would not own a Ferrari were it not for this place.
  13. andrew911
    andrew911 F1 Rookie
    2,893
    Northern NJ
    Any old ferrari can have a 5-figure bill in addition to the items listed above.
    I had close to a $10K bill from a failed 360 header, which necessitated changing the cats in addition to the header.
    430's can have header issues as well, or F1 issues
    355s can have valve guide (though most have been fixed by now) or header issues (or F1 if an F1 car)
    etc etc...
    The guy you know should go into this with eyes wide open...helps to make the ownership experience better overall- these ain't Hondas!
  14. 400iGuy
    400iGuy Formula 3
    1,066
    Central Florida
    Al
    Are you happy with the quality of the replacement straps? Would you mind telling where you got them? Mine are in sad shape.
  15. Skippr1999
    Skippr1999 F1 Rookie
    4,475
    There is a very large delta between dealer, independent, and self service. I own a 360 Challenge Stradale. I have the belts done professionally and the annual fluid changes done myself. The information is on this site if you choose to learn. Otherwise you will pay. Sometimes a lot. For example: you can buy Ferrari Cats for 10k, or choose an aftermarket version for far less. It's really up to you what you spend on these cars. There are ways to make the experience more economical, but you must learn. If you have no knowledge of the car and show up with your credit card at the dealership, they will help you use it.
    VAF84 likes this.
  16. Kevin Rev'n
    Nov 29, 2009
    24,323
    Honolulu
    Kevin
    I got them from the first eBay link in this thread.
    http://www.ferrarichat.com/forum/360-430-sponsored-yellow-compass-group/527236-found-evidence-belt-failure.html
    I saw that the guy "Stevecobra" doesn't have any listed right now but he was great to work with. We did a lot of discussion offline via email so reaching out to him at this hotmail might be the quickest way to move on it. They were very close to perfect and such an improvement over the stock cardboard ones that it's not worth mentioning.
    "steve moore" [email protected]
  17. flat_plane_eddie
    flat_plane_eddie F1 Rookie
    Owner Regional Sponsor Silver Subscribed
    Mar 30, 2013
    3,165
    NE FL
    Eddie
    Sorry but 10k for a header and cats is pretty damn high. I'm guessing you went with stock ones? Had you gone aftermarket you would have gotten better quality (imo) and a significantly cheaper price.
  18. 400iGuy
    400iGuy Formula 3
    1,066
    Central Florida
    Al
    Thanks. I'll contact him.
  19. Skippr1999
    4,475
    This is exactly my point from above. If people would just learn about their cars and research what options are out there, the horror stories of huge bills would be far fewer.
  20. Skippr1999
    4,475
    Another example:
    You can pay 20k for a new F1 actuator, or you can do research to find out that they can be rebuilt for $3,500. The choice is yours.
  21. Ron328
    Ron328 F1 Rookie
    2,625
    Willamette Valley, Oregon
    Ron
    #22 Ron328, Aug 3, 2017
    What I've spent to date:
    1st year of ownership- $2096 (replaced tires, put new 12v battery, replaced leather strap securing tool kit, new flashlight)
    2nd - $1937 (new 12v battery again...the Optima died, replaced all fluids)
    3rd- $816 (oil change, f1 fluid change)
    I am due for a major service the end of the year. Am contemplating on replacing the F1 pump (before it fails). Admittedly, am not a DIYer. All services done at dealer.
  22. AceMaster
    Feb 6, 2009
    34,749
    Ontario, Canada
    About $1600/year, that sounds reasonable.
  23. Kevin Rev'n
    Nov 29, 2009
    24,323
    Honolulu
    Kevin
    Too low!
    He hasn't figured in a major (with full belt service) that is ~4K.
    Done every 3-5 years. FYI
    Go thru a few of these cycles and you are going to need tires/brakes
    Couple more and you need a clutch
    You can get in and out of a car and miss some of this stuff. This is the main reason a car with a big number of previous owners requires more DD.
  24. Ron328
    Ron328 F1 Rookie
    2,625
    Ron
    Agree that my numbers will be skewed up after factoring the aforementioned.
