Main Battery Switch in a 360 Spider | FerrariChat
Discussion in '360/430' started by enzo thecat, Jan 30, 2009.
  1. enzo thecat
    enzo thecat F1 Veteran
    5,721
    Midwest
    Enzo Thecat
    #1 enzo thecat, Jan 30, 2009
    Are there any ramifications in shutting off the master battery switch on my 360 Spider? Will doing so deprogram any computers etc? What about the radio…Will I have to enter any kind of security code when power is turned back on? Obviously the clock will have to be rest.
    Key Fab, Security System, F1 system...ANYTHING????
    Will there be ANY CHANGES (except the clock) that will occur from shutting off the main battery switch that is located in the trunk?
    Thank you for your help!
    e
  2. Rifledriver
    36,754
    #2 Rifledriver, Jan 30, 2009
    You will erase the radio code. You will also erase the adaptive memory of the engine management system and that should be avoided whenever possible. Cars that have batteries shut off regularly have a higher incidence of check engine lights. Modern cars really do not like being powered down and it should have a battery tender installed and used rather than being shut off. The Ferrari technical department is not in favor of the cars having battery switches but production does it anyway. They consider that switch to be for my use and not yours.
    In the shop we do not even turn the battery off when we pull motors, I dislike doing it that much.
  3. RichardCH
    RichardCH F1 Rookie
    4,661
    Radio code and clock; I regularly shut my CS and 430 Spider down in the winter on and off as have super light batteries, no problems thus far
  4. Rifledriver
    36,754
    I smoked for 25 years. No problems thus far.
    And besides electronically the US car is a different car and no comparisons can be made.
  5. RichardCH
    RichardCH F1 Rookie
    4,661
    Yep in Europe they are 6V
  6. masar
    masar Formula 3
    Aug 19, 2007
    1,367
    Czech republic
    Petr
    Good point. Sorry for off topic but i wanted to tell you many times - your avatar of N.Nolte is awesome :)
    6 V ??!!
  7. RayJohns
    RayJohns F1 Veteran
    7,806
    West Coast
    Ray
    You'll need the radio code. I shut mine off if I'm not going to drive it for a while. Brian is right about losing whatever memory it has developed as far as the engine goes. My car always runs a little differently after I shut it off and power it back on. In a few cases, I had to do it to clear some sort of stuck valve or something (I suspect the secondary exhaust valve, but I could be wrong).
    When you power the car back on for the first time, turn the key until the car goes on and wait about 60 seconds. I believe (Brian can correct me if I'm wrong here) that the car has to go through some sort of sequence or something with some valves. If you listen carefully, you can hear some clicks and stuff happening right after you turn it on.
    I also try to go through a complete "warm up" for the motor right after I turn the car back on, so that the ECU can record the entire warm up process (again, some speculation here). In other words, turn the car on, wait about 60 seconds. Then start the car, let it idle for about 1 minute, then drive it under 4K RPM's and bring it completely up to temp.
    Just my 2 cents on the subject.
    I agree a battery tender is probably the way to go, since it would allow you to avoid having to completely clear the memory map for the motor.
    Ray
  8. duskybird
    duskybird F1 World Champ
    12,530
    29 Electoral Votes
    Bill B.
    And positive earth!
  9. enzo thecat
    5,721
    Midwest
    Enzo Thecat
    Ahhhh. The person that I was most hoping would answer my thread was the first response. THANK YOU RIFLEDRIVER! I will NOT be turning off the battery. I want to install the Becker ipod kit and I'll just have to be very careful I don’t make any shorts.
    I'm so glad you are active on FChat. Your contributions are invaluable!
    e
