Lusso w PTU replaced | FerrariChat
Discussion in 'FF/Lusso' started by ak4713, Oct 4, 2023.
Tags:
  1. ak4713
    ak4713 Rookie
    Sep 28, 2023
    19
    Central NJ
    TL;DR
    Do you think PTU failure is inevitable and, if yes, would you happily consider a Lusso with 30K miles and PTU replacement already done (by an F dealer)? TIA
    Long version:
    Hello! New member and lurker here. Been a long-time Ferrari lover but never got to even think that one was possible. Finally, I am at a point where I am shopping for the f-car and Lusso is on the list. For additional context, we have other cars (SUVs and a stick 993 droptop for the weekend), so utility isn't the top priority. I would like the Lusso V12 as it seems to be the most approachable Ferrari with creature comforts and that glorious V12. The Portofino is another option as the wife would like a convertible (she doesn't drive the 993). I could stretch for the 488 Spider to get most of our needs met (sans the V12). I don't intend to track the car - mostly long drives in good weather.
    All that context noted, I would appreciate your thoughts on the below:
    1) Assuming PTU failure is a high probability event for the Lusso, would you be relieved if it has already been taken care of at a Ferrari shop? I understand that for Ferrari Approved cars it will still be covered.
    2) I have driven the Lusso and the Portofino but not the 488 Spider. Before I put it under consideration, I would welcome thoughts on drivability vs the Portofino as the wife isn't looking for something too complex.
    Thanks in advance, and I must admit the search is exciting!
  2. papou
    papou Formula 3
    1,712
    plantation Fla
    daniel ross
    Taking into consideration your Wife the Portofino all day..
    timjen88 and ak4713 like this.
  3. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,173
    Denmark
    Max
    From what we can see on Ferrarichat, the PTU on the Lusso is allegedly improved from the FF. So probably is already less. It doesnt mean that it is zero though, as you can see... But I would be totally fine with a car with a replaced unit, as long as it was done by a reputable shop. It would be even better if it was an improved version as proposed by GTE Engineering for example.
    But yeah regarding your choice of car, I am sure you will be thrilled with the Lusso, and the wife will love it as well. So useable and tame at low RPM but you can have the beast you want just by pushing above 5000 RPM. And so comfortable inside.
    ak4713 likes this.
  4. ttforcefed
    ttforcefed F1 World Champ
    19,216
    lusso has the same exact issue across all the cars...not sure where you got the improvement info
  5. sexybeast
    sexybeast Formula Junior
    Apr 7, 2008
    265
    I choose the Lusso because it supports the wife's and my habit of golfing and road trips. 2 sets of clubs, 2 pieces of carry on luggage, 2 duffle bags, case of water, case of wine, couple bottles of tequila, warm coats on top, a couple of the wife's hats, golf shoes and trader joes goodies and all being pushed by a v12.
  6. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,744
    Weston, MA
    Paul
    What, no kitchen sink? :D
    andyrichter, sexybeast and ak4713 like this.
  7. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,173
    Denmark
    Max
    It seems (might be wrong though) that the Lusso has a slightly lower PTU failure probability than the FF. It might just be that fewer of them have failed because they are more recent. But this was also the comment from the workshop manager at my dealership (Bordeaux, France) who said they had seen many FFs with failed PTU, but no Lusso so far.
    It is also acknowledged that the PTU is slightly different in between the models. There is improved cooling on the Lusso, allegedly enabling more torque to be sent to the front wheels. The ECU also has an improved logic to control the PTU (also noted by the various reviews, including Chris Harris'). The new ECU could very well reduce the peak pressure sent on the hydraulic actuators in order to reduce the chances of blowing the retainer rings.
  8. ttforcefed
    19,216
    The 2 local metro nyc dealers both noticed lussos going in for ptu way earlier than ffs for ptu replacements.
  9. s14roller
    s14roller Karting
    May 3, 2008
    73
    It’s interesting if it’s a design flaw why it seems some cars get impacted and some haven’t been.
    On the Lusso while getting the V12 is ideal, does this mean getting the V8 may be a safer proposition or the V12 still worth the PTU risk?
  10. papou
    papou Formula 3
    1,712
    plantation Fla
    daniel ross
    V12 Ferrari legend in any form,
    KZEVO, 350MH83 and AClark like this.
  11. AClark
    AClark Formula Junior
    315
    Apples & Oranges
    If possible, take an extended test, drive in both, then go to lunch, then ask yourself which one do you want to go drive again?
    I don’t think you could go wrong either way, and while I enjoy the GTC4 Lusso T, I find myself driving the Portofino more often.
    Good luck with your search,
    A
    ak4713 likes this.
  12. robstand
    robstand Karting
    180
    Seattle, WA
    Robert S.
    I chose the GTC4Lusso T because of lower maintenance costs, lower warranty costs, and lower fuel costs. I also liked the spec and price of the one I found.
    ak4713 likes this.
  13. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,173
    Denmark
    Max
    The V8 is a nice car and drives very well, but less emotion. The linearity and power delivery as you pass 5000rpm with the V12 is where the magic is. The V8 will be forgotten. The V12 will remain seen as a masterpiece.
    21ATS, papou, ANOpax and 1 other person like this.
  14. 21ATS
    21ATS Formula Junior
    Dec 10, 2016
    988
    Kent, UK
    Alan
    You're so right about the engine beyond 5000 rpm, it sings in a way no other car I've driven does. It is intoxicating. (FF owner)
  15. robstand
    robstand Karting
    180
    Seattle, WA
    Robert S.
    I won't forget my V8. ;) I look forward to having a V12 F-car, perhaps in a couple of years.
  16. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    What about condoms?
    sexybeast likes this.
  17. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    That's wrong info, PTU on Lusso, FF, and even purosangue absolutely same, they didn't fix anything. That's depends of style of driving, if drivers is shifting often.
  18. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    My answer - not, there are alot of Germany cars on V8 much much better.
  19. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    Depends of PTU, if that stock PTU, changed by of dealer - not not not. If that's modified PTU by SS TECH, that's much better than any stock Gtc4lusso
  20. Caeruleus11
    Caeruleus11 F1 World Champ
    11,416
    IMHO the replacement by itself shouldn't be a huge issue- so long as it was done correctly.
    Lusso vs Portofino
    Both are very good for driving around with your wife
    Lusso has the V12- you are right that it's a good way to get into the V12 experience- I think this is a big factor
    Lusso has better ride quality
    Lusso also has wheels/ tires that are easier to damage - especially on the roads in the NorthEast- the fronts are fairly vulnerable
    Porto a little easier to park and live with because its a little bit smaller
    Porto is sexier looking/ do you need the backseats?
    My take away is the V12 is worth experiencing at least once in your life. Just keep your eyes open for pothole.
    ak4713 likes this.
  21. xkactetx
    xkactetx Rookie
    28
    Michael Baruch
    I just bought a 2016 FF and I choose a higher mileage car that only 6 months ago had the PTU's replaced by Ferrari, I have warranty for another 18 months unlimited miles. I searched for a good 4 months and decided to get the higher mileage car with a recent replacement I saved on the car and have a piece of mind for the first 18 months of ownership. As someone stated the same units are now used on the Ferrari Purosangue. The dealer who worked on the car said I have the 7th version and I think eventually they will go again and if I still own the car will get the Peak Performance replacements they seem to address all the weak points.
    ak4713 likes this.
  22. Nospinzone
    Jul 1, 2013
    7,744
    Weston, MA
    Paul
    I think that was a wise decision.
    And congrats and I wish you good luck with your new car!
    But, keep in mind it didn't happen unless you post some pics. :)
