Lucas 10W-50 Motor Oil in a Boxer Engine | FerrariChat
Discussion in 'Boxers/TR/M' started by 2dinos, Apr 1, 2025.
  1. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    2,954
    I'm considering using a 10W-50 motor oil and was wondering if anyone has experience with Lucas products. I recall using their fuel additive in a high-mileage car—it did a great job cleaning up the top end and noticeably improved smoothness, starting, and power.
    The Lucas oil is full synthetic and carries an API SN rating (an automotive spec) despite being marketed as great for off-road vehicles. It contains some ZDDP, but the SN rating means it's within certain limits. Early synthetics had some teething issues, but this oil has been around for a while.
    One concern I always have with oil is corrosion protection and detergent properties—any thoughts or experiences with this stuff?
    Also, I'm curious about Porsche Classic 10W-50 motor oil—anyone have feedback on that?
    BTW, pricing for these oils seems in line with other major brands.
    Thanks for the input!
    Hg007 likes this.
  2. Rifledriver
    36,760
    I strongly suggest against using synthetic. BBs burn it so fast you cant keep it in the engine. 10-50 is a good choice.
    My rule for decades is dinosaur oil for 2 valve engines and synthetic oil for 4 valve and later.
    boxerman, bjunc and ago car nut like this.
  3. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    2,954
    Awesome info - thanks!
    Having trouble finding a brand that offers 10W-50. That's why I listed the Porsche classic and Lucas product. And it took a while to find those.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,672
    Central NJ
    Dominick
    Have you considered / looked at VR-1 Conv oil or Castrol GTX Conv 20w-50 ? I am advising just a thought .. maybe Brian has some thoughts on it
    boxerman likes this.
  5. lagunacc
    lagunacc F1 Rookie
    4,015
    Total, Eni but they're difficult to get in the US.
    Motul is easier. They have a Classic line also.
    You can also get 10w60 - https://www.amazon.com/Motul-106144-74-x-Power-10w60/dp/B018EO46CQ/
  6. Rifledriver
    36,760
  7. Rifledriver
    36,760
    VR1 is what I have used for years.
    TTR likes this.
  8. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,026
    Agree with Brian, another vote for 20/50 VR1.
    TTR likes this.
  9. TTR
    TTR F1 Veteran
    5,758
    Riverside, CA
    Timo
    While experience timelines of both Brian and Dyke exceeds mine and I don’t have any directly related to Boxers, I’ve been using conventional/non-synthetic 20W-50 oil successfully in hundreds of 1925 - 1980 (or so) vintage cars/engines for 1/2M+ miles in past 45 years, VR1 for last 20 or so.
  10. TTR
    TTR F1 Veteran
    5,758
    Riverside, CA
    Timo
    P.S. I haven't done any in-depth research, but wonder if any brand offers a non-synthetic 10W-50.
  11. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    2,954
    How about ANY 10W-50 products? Seems like an odd duck. Just Lucas and Porsche Classic is the only 10W-50 I can find regardless of base stock used.
  12. TTR
    TTR F1 Veteran
    5,758
    Riverside, CA
    Timo
    I have no idea or need for such oil.
  13. lagunacc
    lagunacc F1 Rookie
    4,015
    Motul 5100 10w50 for bikes is semi-synthetic
  14. Edward 96GTS
    Edward 96GTS F1 World Champ
    10,837
    Thoughts on Swepco 20-50 motor oil?
  15. Rifledriver
    36,760
    As I have been told by others more knowledgeable on the subject than I there is a limit on how wide was viscosity spread that can be achieved and it is wider with synthetic than dinosaur oils. I suspect 10-50 is beyond that ability.
  16. Rifledriver
    36,760
    I think its a very good product. Not a fan of their gear oil but the motor oil is good.
    Edward 96GTS likes this.
  17. TTR
    TTR F1 Veteran
    5,758
    Riverside, CA
    Timo
    #18 TTR, Apr 4, 2025
    That mirrors what I was told long ago by a friend who had a degree in chemistry and had worked in petroleum research industry, but perhaps there’s been advances in that chemistry & technology.
    OTOH, I am and have been happy with 20W-50 in vintage cars/engines for decades and see no reason to try something else.
    In my daily drivers, i.e. modern cars I just stick with fluids/oils recommended by manufacturers, which for as long as I’ve driven late model/ modern cars (about 20+ years) has worked fine.
  18. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    2,954
    Thank you all,
    Page 19 of the owner’s manual for the Ferrari BB512i specifies “Agip SINT 2000 SAE 10W-50,” so that’s what I’ve been aiming to match—though I’m open to using a comparable brand that meets the spec.
    For what it’s worth, I studied mechanical engineering largely out of a passion for subjects like this—especially as they relate to Ferrari. In one of our machine design courses, we got into journal bearing analysis, which considers a number of factors* that really showed how involved this topic is. It also gave me an appreciation for just how much engineering goes into oil selection, and how computational tools now simplify what was once a very manual, iterative process.
    Having spent much time around engine rebuilding and design, I’ve noticed how manufacturers often carry forward bearing dimensions across engine families—because they’ve been proven to work. And Ferrari, in particular, is no stranger to understanding how their cars will be driven and what conditions they’ll see. I trust that their oil specs are the result of deep experience and development.
    Over the years, I’ve made some of my own observations regarding oil performance, which have guided me to explore alternatives when necessary—but always with a healthy respect for the original engineering intent.
    That’s why, when it comes to viscosity, I prefer to stick with what the factory recommended.
    * Viscosity (and how it varies with temperature), heat from oil shear, steady-state temps, bearing geometry (diameter, width, clearance), rpm, load, lubrication type, contamination factors, etc.
    turbo-joe likes this.
  19. lagunacc
    lagunacc F1 Rookie
    4,015
    2dinos likes this.
  20. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    2,954
    I used to use Agip exclusively for the Ferrari on the track. it was tricky to buy. I had a bunch of race buddies w Ferrari's so we'd go in as a group and buy 300 gallons at a shot. This lasted a while, but we did use it all and it made the purchase reasonable.
    What I loved about the Agip, is at 7,700 rev's, the oil temp and pressure stayed right in the center. At idle, the pressure still showed good even when hot. Volatility was excellent! For petro-oil, I have much confidence with Brad-Pen (The 'Old Kendall). With many of the hi perf oils, I do want to not destroy the cats.
  21. Rifledriver
    36,760
    There is some validity to that but in the near 50 years since the BB came out odd as it seems there have been some changes in motor oils. What was true 50 years ago is not in every case true today.
