Low compression & spark | FerrariChat
Discussion in 'Technical Q&A' started by MAD308, Jul 2, 2008.
  1. MAD308
    MAD308 Karting
    Feb 19, 2005
    116
    Montréal, Canada
    Marc-André Desrosier
    Hello y'all
    Is there a definite link between a low compression cylinder (75 PSI) - number 1 on bank number 1 - and the spark from the plug.
    I'm getting no spark at all, checked by simple removing the lead from the plug while the engine is running. There is no change in the engine noise, like on any other cylinder with a higher compression (130 PSI) on the same bank.
  2. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,745
    Atlanta
    John!
    75 sounds dangerously low, and 130 even sounds too low. Numbers like that would definitely contribute to a poor running engine.
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    75 psi is pretty low but it could still run. Did you remove the spark plug and look at it? It might be oil fouled.
  4. MAD308
    MAD308 Karting
    Feb 19, 2005
    116
    Montréal, Canada
    I've check for some spark outside the engine, and the plug is sparking. That's what seems very strange. ???
  5. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    There is no correlation between no spark and low compression. They are 2 seperate and distinct problems.
    Low compression is a sign of leaking valves, leaking or broken piston rings or a blown head gasket.
    Either way it requires the cylinder head to be removed and a possible engine or head rebuild.
    Compression of 75 Ibs on one cylinder and 130 Ibs on the others is another sign of a need for a rebuild. Normally you look for a variance of about 10 % between cylinders and remember , normal compression should be upwards of 190 Ibs across the board.
    Your motor is in serious need of a repair.
    Sorry for the bad news.
  6. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    We assume that there was a compresson check to identify the 75psi cylinder. So what did the plug look like. Was it gas or oil fouled. If so it or if you installed a new plug then it can be fouled again and will not fire. 75 psi is a problem with either leaking valves or rings. Check the plug again and see what you get. You may want t run the engine until it is warm and then put in a new plug. It should run good for a while after it is installed. Buy the way does the engine smoke from that cyl bank.
  7. swilliams
    swilliams Formula 3
    Jun 14, 2006
    1,407
    Bowling Green, KY
    Scott
    #7 swilliams, Jul 2, 2008
    most likely a valve problem unless the car is smoking bad.. could be burnt valve, or bad cam lobe/lifter. A Bent valve would produce 0 compression.
    If its smoking then it could be ring problem or head gasket blown or head cracked/warped (steel/aluminum).
    Good luck only way to fix it is to pull the head off. Have fun!!
  8. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I don't think pulling the plug lead tells you much. My 308 motor idled fairly nicely with four cylinders not firing at all when I had an ignition issue. Except for the total lack of acceleration, you wouldn't even really know a whole bank was dead. I think you need more evidence of that cyl not firing.
  9. Modeler
    Modeler F1 Veteran
    May 19, 2008
    7,330
    State of confusion
    a.n.other
    QFA
    All you need to know is in those compression readings.
    Big question is what are you going to do?
    My guess is you're up for a top end rebuild at least.
    You could compression test with some oil injected down the plug holes to rule the rings in or out or 'scope that worst cylinder, before committing to the expense.
  10. FERRARI TECH 24
    Feb 15, 2007
    9
    Mt Airy N,C
    casey johnson
    there is a chance that by that cylinder not firing, the un burnt fuel could have washed the cylinder of all of its oil causing low compression, i would pour a small amount of oil in it and let it sit over night and then whith you properly working injection and ignition system start it up, let it warm up and check compression once again! if that doesn't make a difference then start getting nervous!
  11. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    low compression could be due to cam timing also, or valves out of adjustment. i would check these
  12. MAD308
    MAD308 Karting
    Feb 19, 2005
    116
    Montréal, Canada
    Thanks for all the insight
    Before converting my serial number into a bill, I'll go the simpliest way for now...
    How small an amount of oil should I be pouring in the cylinder ?
    Also, is it possible to check the electrical impulse on a spark lead (wire), in order to rule out the wiring.
  13. kingsdare
    kingsdare Karting
    Oct 24, 2006
    132
    California
    David King
    An engine with very low compression on one cylinder like yours would "feel" like it has a bad spark plug or wire. So pulling the wire and not hearing a change in RPM/noise is not surprising. In fact, it helps verify that you have a problem with the number one cylinder (as long as you have verified the spark plug IS firing).
    A leakdown test should determine if its the bottom end (rings, pistons, cylinders) or the top end (valves, camshafts, rocker arms) that needs repair.
  14. desire308
    desire308 Formula 3
    Oct 19, 2007
    1,433
    Florida
    Peter W
    #14 desire308, Jul 7, 2008
    Not much...about a tablespoon, just enough to get around the rings and create a "temporary" seal. If you see no change it points to the valves.
    The electrical impulse can be checked with a timing light...I believe ;)
  15. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I wouldnt just pour in the oil and screw the plug back in. After you pour in some oil, crank the motor over a few flips to blow any excess oil out. Your just trying to wet the rings, but any excess oil in the cylinder will dramatically increase compression ratio, and consequently increase your pressure readings and could give you a false positive.
    And while 75 psi isnt good, its not low enough not to run. If ALL cylinders on one bank are reading 75 psi I would suspect the valve timing jumped.
