Low Battery/Startup/Reset ECU Procedure | FerrariChat
Discussion in '360/430' started by Gumart1, Dec 6, 2013.
  1. Gumart1
    Gumart1 Karting
    Dec 22, 2010
    117
    Highland Park, IL
    Marty
    I inadvertently left the key in the ignition in the "on" position which drained the battery.
    I did have a battery tender plugged in but apparently it could not keep up with the drain.
    I let the battery charge until 100% full.
    I searched the forum and found the procedure for resetting the ECU upon startup.
    I put the ignition on (farthest forward turn before starting) for 10 sec. then started the
    car. I let it idle for 15 min and it seemed like the idle became faster.
    Within the first minute of driving, the engine stumbled and revved and nearly died.
    Am I stuck flat-bedding the car to the Dealer to re-program the throttle body, as the Dealer
    has informed me, or is there anything else I can try?
  2. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    no, you are stuck driving the thing...get it out and drive it. It will be fine and reprogram itself.
    This is assuming nothing was wrong when you last drove it and parked that you did not mention.
  3. Gumart1
    Gumart1 Karting
    Dec 22, 2010
    117
    Highland Park, IL
    Marty
    No, nothing wrong anytime before this...but it sputtered along so slowly it would be difficult to take it on any road at the moment. Seemed ready to die at any moment.
  4. tazandjan
    39,007
    To make that reset procedure work, you must disconnect the battery using the battery disconnect switch and leave it that way for 30 minutes or so. Turn off the A/C and radio, turn ignition switch to on for 30 seconds, turn it off for 30 seconds, back to on, wait for check OK, start and let idle for 10 minutes with no input whatsoever. Turn on A/C, radio (insert code if necessary), and drive for 15-20 minutes gently. Should be OK after that.
    Alternatively, turn off battery disconnect switch for 30 minutes, turn on, start normally and drive several times as the system relearns. May take several times on/off to get A/C and other accessories to work.
    There is also a complicated drive cycle test that does the same thing, but the 1st procedure works just as well.
  5. DrDon
    DrDon F1 Rookie
    3,627
    Infractionville
    Armando Decredenza
    #5 DrDon, Dec 6, 2013
  6. tazandjan
    39,007
    #6 tazandjan, Dec 6, 2013
  7. DrDon
    DrDon F1 Rookie
    3,627
    Infractionville
    Armando Decredenza
    Nice to have it laid out as to what each step does - thank you.
  8. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,322
    Honolulu
    Kevin
    So this is what I need to do if I replace the battery? I fear that my battery is getting weaker. If I leave it off the charger for a week the car sort of stumbles to a start for about 5 seconds and then fires normally on all cylinders. If I have driven it recently or just taken it off the charger she starts as normal. Battery?
  9. Skidkid
    Skidkid F1 Veteran
    9,478
    Campbell, CA
    John Zornes
    Done that. Darn embarrassing isn't it. Power off then do a power on start following the procedure, it should all be ok.
  10. Gumart1
    Gumart1 Karting
    Dec 22, 2010
    117
    Highland Park, IL
    Marty
    Grateful for the tips and courtesy on this forum! Where is the battery disconnect switch located? Pic?
  11. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    #11 English Rebel, Dec 7, 2013
    It's in the front luggage compartment on the left had side above the flat area where the CD changer would go -- rotate counter clockwise to turn off. Terry will correct me if I'm wrong but I don't think there is a need for the elaborate procedure he mentioned unless you are going to have an emissions test soon. I have disconnected my battery quite a few times and the ignition on with no AC or radio then let idle for ten minutes was all that was required.
    Alan
  12. okiedude
    okiedude Formula 3
    Jul 11, 2011
    1,013
    Remulak
    Blake
    Has anyone used a Clore Memory Saver Cord Memory Saver Cord - ESA30 | Call us at 1-800-328-2921 | Clore Automotive when changing their battery? I've used it in other cars, just plug it into a jump box (with lighter receptacle) then into the OBDII port and the ECU and other electronics remained powered while you disconnect the actual battery. It's a pretty cool little tool, especially for around $12.
  13. Araantonak
    Araantonak Rookie
    Jan 3, 2014
    16
    Europe
    Lauritz
    is it normal that the check engine light is blinking after the reset? I had changed the battery and am working through the re-learning procedure but the check engine worries me
  14. metaldriver
    metaldriver Formula Junior
    Apr 6, 2015
    631
    Houston, Texas
    Andy Vecsey
    Several months ago when I had radio work performed, I mentioned to the shop about turning off the master battery switch beforehand, then letting the car idle for ten minutes afterwards. For liability purposes, they did not drive the car in the manner described in the Ferrari procedure because of Houston traffic. I would not be comfortable doing so either, unless it was early Sunday morning. I would still have to drive the car home during normal business hours, not following the instructions either, so what’s the point?
    The car’s two engine ECUs re-learned all the parameters just fine while idling for the ten minutes at the radio shop. No CELs, no hesitation, no nothing as if the master switch was never turned off.
    I am pondering re-flashing those ECUs and am wondering if not following that procedure to the letter simply takes the ECUs longer to re-learn those particular driving conditions, or if I am setting myself up for aggravation. So what if I don’t drive at XXX speed for YYY minutes in ZZZ gear, right away? I will eventually drive at those conditions and the ECU will eventually capture the corresponding inputs. As long as the ECU is satisfied before the next annual inspection where they plug into the OBD-2 connection, right?
  15. mello
    mello F1 Veteran
    5,432
    CA Bay Area
    Steve
    To recalibrate the throttle body.
    . turn ignition on (engine off) and wait for CHECK OK message.
    . step on throttle pedal all the way and hold for about three seconds.
    . release pedal and wait for three seconds.
    . repeat above two steps three more times.
