Loud Ticking while idling | FerrariChat
Discussion in '360/430' started by Chadly, Feb 4, 2012.
  1. Chadly
    Chadly Formula Junior
    Mar 21, 2010
    294
    Bothell, WA
    Chad
    My 360 has a noticeable tick while idling ever since I have gotten it back from the belt service. I don't recall the noise before. Is this something that is normal?
  2. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,317
    Gibraltar
    360trev
    While there are many factors which can cause this (you'd need to elaborate further) often on the 360 the ticking is caused from an air leak, either from the air intake gaskets or from the exhaust header gaskets.
  3. jim94-348
    jim94-348 Formula Junior
    Aug 19, 2010
    981
    Greenville, NC
    Jim
    It could also be a crack in the header. If you have a stethoscope or similar device put it up to the header on each side and see if it is coming from there. If you don't have a stethoscope you can get a cheap one or even borrow one at many car parts places or buy one cheap at Harbor Freight Tools. I hope it is not that but instead something simple but I have an OEM set available that have been tested if you need them. Just PM me.
  4. ross
    ross Three Time F1 World Champ
    Mar 25, 2002
    37,776
    houston/geneva
    Ross
    the last tick i had in the cs turned out to be the water pump. fwiw
  5. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Might also be the secondary butterfly valves. Does it sound a bit like tappets?
    With the engine off, explore under the plenum cover on either side (approx mid point front to back on the outer side) and see if you can find the valve actuators. Once you find them you'll notice you can operate them manually. Once you're familiar with operating them re-start the engine and operate the valves again. If all goes quiet when you do this then you have your issue, if not, it's something else! :)
  6. OceanSide760
    OceanSide760 Karting
    Jul 8, 2009
    185
    If it's not too loud, it's normal. lifters.
  7. since-15
    since-15 Formula 3
    Nov 26, 2008
    1,142
    It's a bomb! Quick, drive it to my house and leave it with me for a few months while I difuse it.
  8. tazandjan
    39,007
    Lifter tick usually goes away after the lifters pump up and is not something I would expect to happen suddenly, unless only one has gone bad.
  9. rmani
    rmani F1 Veteran
    Nov 1, 2003
    7,328
    NJ
    RMani
    could also be you're low on oil. When I would autox my old m3 by the end of the day the car was ticking loudly while idling. After the cruise home at 70mph no tick at all. Take the car out for a nice 30 mile cruise on the highway and see if it's still ticking.
  10. tazandjan
    39,007
    With a dry sump system, the oil in the tank has to be pretty low before it would start affecting anything that would make noise. Probably at least 3 liters or so.
  11. rmani
    rmani F1 Veteran
    Nov 1, 2003
    7,328
    NJ
    RMani
    what's the difference between dry sump and whatever is in normal cars? I didn't realize ferrari's had a different pump. I'm assuming it's more performance oriented?
  12. FTA
    FTA Formula Junior
    Aug 26, 2011
    390
    Phila., PA
    Frank T
    wikipedia has an excellent description of dry sump lubrication. just copy and paste and it will be explained there. essentially it's typically only found in race car engines as it moves the sump off to the side (instead of underneath) thereby allowing the engine to have a lower center of gravity. the problem is it requires more complex piping, more oil, and can cause difficulty just getting a reliable reading on the dipstick (engine has to be running and oil at a particular temp to really get an accurate reading, unlike most cars where you just check the dipstick cold)
  13. tazandjan
    39,007
    RMani- The main difference between a dry sump and a wet sump is that the oil being pumped into the engine comes from a separate dry sump oil tank, and not the sump under the engine. A scavenge pump (or pumps) returns the oil in the sump to the dry sump tank. Because of this separate tank, the oil is usually less aereated and lower oil levels are also better tolerated. Capacity in dry sump systems is usually higher than for wet sump systems. In automotive applications capacities vary from something like 8 liters in early 911s to 16 liters in a Ferrari Daytona. Most modern Ferraris have a capacity of 10-12 liters. A typical wet sump system would have a 4-6 liter capacity.
    Like FTA said, they are more expensive, but do allow a much shallower sump for lowering the engine and CG.
  14. greyhair
    greyhair Formula Junior
    Jan 1, 2011
    477
    Central Valley Ca
    I asked that same question back when I had the 430 before the scud, to the dealer. They stated that the small ticking sound that I was hearing was from the fuel injectors. But that was more of a ticking sound rather than a tapping sound that you get from a sticky lifter. Just thought I would add to your list of noises :)
  15. rmani
    rmani F1 Veteran
    Nov 1, 2003
    7,328
    NJ
    RMani
    thanks for the explanation taz and fta! More cool stuff I never knew about Ferraris!
