Lost all gear oil today, 1991 Testarossa | Page 37 | FerrariChat
Discussion in 'Boxers/TR/M' started by PA32Pilot, May 9, 2020.
  1. PA32Pilot
    PA32Pilot Formula 3
    1,812
    Glendora, CA
    Jamie Kirk
  2. PA32Pilot
    PA32Pilot Formula 3
    1,812
    Glendora, CA
    Jamie Kirk
  3. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,929
    romano schwabel
    so it looks much much better jamie
    please test: when you put the spacers on and then the intermediate plate tighten this plate with a lot of spacers ( thread is not long enough ) and 3 8 mm nuts. then the front disc has to rotate. remove the back disc to see better if not rotating then you need more spacers or thicker spacer. as I have written already here it is a question of 1/10 mm
    but glad that it is like I thaught ;)
  4. PA32Pilot
    PA32Pilot Formula 3
    1,812
    Glendora, CA
    Jamie Kirk
    Like this?
  5. turbo-joe
    Apr 6, 2008
    8,929
    romano schwabel
    you may measuse the distance between the intermediate ring when fixed with the spacers but without the front disk an dthe flywheel. then you measure the thickness of the clutch disc. the clutch disc should be about 2-3/10 thinner than the space between the intermediate plate and the flywheel
    if you use too thick spacres then the rear disc will get blocked when you pust the clutch pedal
  6. PA32Pilot
    PA32Pilot Formula 3
    1,812
    Glendora, CA
    Jamie Kirk
    Or like this
  7. turbo-joe
    Apr 6, 2008
    8,929
    romano schwabel
    looks good, but as I see it turns really easy.
    so please measure as I have written and see that you get those 2-3 /10 mm
  8. turbo-joe
    Apr 6, 2008
    8,929
    romano schwabel
    too easy to turn
    check how much play the disc has. so if you could move the disc front and rear between the indermediate ring and the flywheel then you have too much play. that is why I told you to measure
    where the 3 small clips are press those as much as you can to the flywheel and test again rotating
  9. turbo-joe
    Apr 6, 2008
    8,929
    romano schwabel
    OH !
    you are sure you put the front disc right direction - so flywheel side to the flywheel?
    in thread 901 and 903 the rear disc is the right direction but as I remember both disc are equal and so look also in the same direction. but not sure just now. only remember at my sintermetal clutch in my competition how I installed it there
  10. PA32Pilot
    PA32Pilot Formula 3
    1,812
    Glendora, CA
    Jamie Kirk
  11. PA32Pilot
    PA32Pilot Formula 3
    1,812
    Glendora, CA
    Jamie Kirk
    Yes. Disc says flywheel side.
  12. turbo-joe
    Apr 6, 2008
    8,929
    romano schwabel
    that looks now very good;)
    put all together again but check the clutch to flywheel direction again please. only to be on the safe side
    all ok then
    happy working ;)
  13. PA32Pilot
    PA32Pilot Formula 3
    1,812
    Glendora, CA
    Jamie Kirk
    Reassembling now.
    Service manual says clutch bolts are 2.46kgm. That’s 18ftlbs. Doesn’t seem very tight.
  14. turbo-joe
    Apr 6, 2008
    8,929
    romano schwabel
    those bolts are only 8 mm and not need much torque
  15. PA32Pilot
    PA32Pilot Formula 3
    1,812
    Glendora, CA
    Jamie Kirk
    JoeTSI likes this.
  16. PA32Pilot
    PA32Pilot Formula 3
    1,812
    Glendora, CA
    Jamie Kirk
    BAM! Shifts into 1st! Not 2nd but the oil is cold and with it being midnight I don’t want my neighbors to hate me with me warming up a straight pipe Testarossa. THANK YOU TURBO JOE!!!
  17. turbo-joe
    Apr 6, 2008
    8,929
    romano schwabel
    great ! ! !
    2nd? you tried to shift into 3rd
    so now you may sleep much better I think
    have a good night and good testdrive tomorrow :)
  18. PineChris
    PineChris Formula 3
    Apr 17, 2013
    1,082
    California
    Chris
    Anyone who would believe that an 80k mile Testarossa was actually in Concours condition because it won an award at a local car show would need their head examined.
    The idea of a lawsuit is laughable though.
    BOKE likes this.
  19. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    Agreed- Shamile is a great sales man for sure;)
    Now that is fixed Jamie has now the A/C to fix ! Jamie u are a rockstar!
  20. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    Hopefully it's not the evaporator leaking. That will require the dash come out.
  21. PA32Pilot
    PA32Pilot Formula 3
    1,812
    Glendora, CA
    Jamie Kirk
    Test drive went well, I can certainly tell the difference especially when turning. Drove very smooth, with straight pipes I couldn’t hear any whining.
    JoeTSI, m5shiv, turbo-joe and 2 others like this.
  22. PA32Pilot
    PA32Pilot Formula 3
    1,812
    Glendora, CA
    Jamie Kirk
    Wife wanted to rev the car. I let her have some fun.
    TestaDDS, EZORED, xplodee and 2 others like this.
  23. Alcav5
    Alcav5 F1 Rookie
    3,972
    Scarsdale, NY
    Al
    Did i miss that you took care of 2nd & 3rd gear ? Was it the cold oil?
    Was a great thread, best of luck to you ...
  24. PA32Pilot
    PA32Pilot Formula 3
    1,812
    Glendora, CA
    Jamie Kirk
    Cold oil. Shifted into 2nd smooth. 1st was a little hard to get back into but I am going to adjust the clutch.
  25. turbo-joe
    Apr 6, 2008
    8,929
    romano schwabel
    what do you want to adjust at the clutch? there is nothing to adjust. except the pedal play at the master cylinder
    G R E A T to hear that with the diff all is well now ;)
    Natkingcolebasket69 likes this.
