458 - Looking for input on battery/tender options | FerrariChat
458 Looking for input on battery/tender options
Discussion in '458 Italia/488/F8' started by Dragster, Jul 10, 2021.
  1. Dragster
    Dragster Formula Junior
    Jun 8, 2007
    501
    Charlotte, NC
    Hey everyone! I recently took delivery of a 458, and saw that Ferrari recommends the car be put on a battery tender if it won't be driven for about a week. Unfortunately my car didn't come with the battery tender (though it did have the car cover and books/tools/etc.) so I likely need to either buy one or invest in a different battery. I currently have two weekend toys in my garage, but due to garage space, one has to be on the top of a lift, so that car may sit for up to 2-3 weeks or so without being started. This hasn't really been an issue before, but it sounds like it'll definitely be an issue for the 458 if it sits on the top of the lift for two or three weeks.
    I have used battery tenders before, so there's no problem there, however, because the tender for the 458 routes out the passenger door, it could present an issue because there's little space on that side of the garage. I likely won't be able to open and close the door to get the tender in and out. I could always route it out the driver's window, but I'd prefer not to leave the window cracked. I couldn't find the model number of the official 458 batter tender, but the one for the F430 is about $350, give or take. I'm not sure if they're interchangeable, but I figure I'm looking at spending at least that much for the battery tender (I'd like to get the official Ferrari one just to make the car more "complete").
    The cost of the battery tender has me thinking that I might be better off by getting a new battery that won't drain as quickly and would hopefully not require a tender if it sits for 2-3 weeks. The problem here is that I don't really know a whole lot about choosing automotive batteries. I've seen some lithium ion batteries that are supposed to hold a charge for a long time, but are there any downsides? How do I know how to choose the CCA, Ah, etc.? All I'm looking for is a battery that will be 100% compatible with the car and hopefully keep a charge for 2 or three weeks without a tender. If this isn't possible, then I'll just save my money and buy the Ferrari battery tender and move on. If I can get a new battery that will last without needing to be placed on a tender, what are some good options? Also, what tender would I need to use for that battery and can it be plugged directly into the port underneath the glove box?
    Thanks for any input!
  2. rob5819
    rob5819 Formula Junior
    Dec 12, 2017
    932
    San Diego
    Rob Barry
    From the battery tender perspective, a CTEK 7002 and a 458 adapter: https://www.amazon.com/CTEK-56-353-12-Volt-Battery-Charger/dp/B000FRLO9Y and https://www.ebay.com/itm/183641012432. This is what I use. The 458 tender that came with my car was the equivalent of a CTEK 4.3 and is pretty much worthless.
    From a battery replacement perspective, please read any of Ray John's discussions on the Braille battery (Braille i48CS) or other discussions of an Antigravity battery, much less need for the battery tender.
    Dragster likes this.
  3. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,619
    South East
    Jimmie
    My sense is this is a pretty regular thread so you could try looking for others' previous experience
    docf likes this.
  4. Dragster
    Jun 8, 2007
    501
    Charlotte, NC
    I did find some results when I searched, but I couldn't find any answers as to whether the 458 tender was the same as the 430 one, nor could I find anything about how to choose a battery.
  5. rob5819
    Dec 12, 2017
    932
    San Diego
    Rob Barry
    if you want to use a battery tender you do NOT want the 458 or 430 OEM products. You want a CTEK 7002 or MXS5 with the comfort connect 458 adapter. They 430/458 tenders are re-branded CTEK 4.3 tenders and they simply do not work as well as the 7002 or MXS5. The 7002 and MXS5 will show you all the tests that the tender runs and get the battery back up to full much, much faster:
    STEP 1 DESULPHATION
    Detects sulphated batteries. Pulsing current and voltage, removes sulphate from the lead plates of the battery restoring the battery capacity.
    STEP 2 SOFT START
    Tests if the battery can accept charge. This step prevents that charging proceeds with a defect battery.
    STEP 3 BULK
    Charging with maximum current until approximately 80% battery capacity.
    STEP 4 ABSORPTION
    Charging with declining current to maximize up to 100% battery capacity.
    STEP 5 ANALYSE
    Tests if the battery can hold charge. Batteries that can not hold charge may need to be replaced.
    STEP 6 RECOND
    Choose the Recond program to add the Recond step to the charging process. During the Recond step voltage increases to create controlled gassing in the battery. Gasing mixes the battery acid and gives back energy to the battery.
    STEP 7 FLOAT
    Maintaining the battery voltage at maximum level by providing a constant voltage charge.
    STEP 8 PULSE
    Maintaining the battery at 95–100% capacity. The charger monitors the battery voltage and gives a pulse when necessary to keep the battery fully charged
    https://www.ctek.com/storage/28170E5A4DF8DDE255F2544A55F5C421179A3398C557729443D3E9C908F0382E/d4c71f1fcf354b37bdfb3841d00adafd/pdf/media/01d8e64db81c4259bda89213323dad93/MXS_5.0-manual-low-UK-EN.pdf
    If you do not want to use a tender and are ok spending $2-3K, then the Braille i48CS sounds like a great choice (https://www.ferrarichat.com/forum/threads/braille-lithium-ion-battery-i48cs-group-48-size-just-18-lbs-great-standby-time.590678/). For less money, but still time off from the tender, https://www.ferrarichat.com/forum/threads/antigravity-battery-on-458.623367/.
    turbokraft and Dragster like this.
  6. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,721
    Just East of Weird
    Bob
    Rule of thumb. If the battery is 4 or more years old, it’s time to replace it, regardless of whether it “seems” ok as it will fail soon.
    You can go the expensive battery route or replace it with an Interstate AGM battery. The tenders mentioned above will work.
    The tenders mentioned above, I believe, will not work on a lithium battery so make sure you know what battery you are buying and which tender is appropriate.
    Drive the car once a week and you won’t have to worry about a tender, otherwise, definitely keep a tender on the battery or you will go out to a car with a dead battery.
    Sent from my iPad using Tapatalk Pro
  7. docf
    docf Formula 3
    Sep 14, 2008
    1,404
    Florida
    Gary
    I have had my 7002 Cytec for about 3 yrs now after using the Factory model for approx 1,5 yrs. The 7002model has had no problems nor battery issues. My car a 15 Italia & driven approx 25 to 50 miles once a week with little or no red lights or stop & go traffic. The current battery other than when initially put on the factory unit had hestency to start on the weekly use routine. This problem was totally rectified with the chge to the 7002 unit. The Interstate AGM battery has had no problems since the chge to the 7002 unit. The Interstate AGM nearing the 4 yr mark will be replaced this fall as a safety precaution,not a neccessity priority. Incidently shop the 7002 & the adaption to fit the 458 as it is no where near the 350.00 you quoted as a repacement for the lousy stock unit. It like the factory unit can be wall mounted. Since I installed garage shelfing I can no longer use passenger access to unit plug in so now run it via drivers side to passnger battery receptacle.
    rob5819 likes this.
  8. Tito1969
    Tito1969 Karting
    May 19, 2019
    58
    Tito Kabir
    Ctek mxs 5 and an adaptor from eBay. Works really well. The oem unit is substandard.
    rob5819 likes this.
  9. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    In your case I'd look for a solution which negates the tender completely.
    Get an AntiGravity battery. It has a built in shut down feature which never lets it drain completely. If it shuts down, you just hit the button of the included keyfob and you are good to go.
    The battery for the 458 is the H6 Group 48 size. Just get the 60 ah version. It can sit for a few weeks without even going into shut down mode.
    turbokraft, V8date and Dragster like this.
  10. versamil
    versamil Formula 3
    1,215
    Gaston, Oregon
    Brian Healy
    I have a 2013 458 Spider with the original battery and use the original "subpar" factory tenders. I've had a couple of problems starting in the last couple of years, but I have a feeling it's more me NOT letting the computers talk to each other, after a fairly long no start period- like two months. Since the last time I had a weird start, I purposely delay starting the car for at least ten seconds after turning on the key. I've noticed if I drive the car regularly, there's no issues, but it doesn't like two month breaks between uses.
    There is the SAME slot in the drivers side door to run the charger cable through as the passenger side, so one doesn't need to worry about only sticking the cable out the passenger side. It's just a small round dimple in the door for the wire to route through- a pain to find since you have to look under the door to see it.
    Yesterday I just spent $114.00 on a new Interstate battery for the 458 while I was picking up another battery for my 328GTB. I don't think I'm going to install it until my original just doesn't work anymore. It's gone eight years at this point. I had a battery last 18 years on my freightliner truck! I always leave my car on a tender, and with eight years history, I can't complain.
    docf and Dragster like this.
