Lobro parts source? | FerrariChat
Lobro parts source?
Discussion in 'Technical Q&A' started by finnerty, Nov 29, 2007.
  1. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    Does anyone know of any NON-FERRARI sources for Lobro cv joint / driveshaft parts here in the US?
    Thanks.
  2. jwise
    jwise Formula Junior
    Apr 2, 2003
    781
    Portland Maine
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Did Ferrari really use the *same* Lobro 108MM CV Joint for all DINO/308/328/348/365/BB and TR's?!
  4. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Yes!
  5. fatbillybob
    Aug 10, 2002
    28,545
    socal
    Got part numbers? This site needs yr make model or PN
  6. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Porsche 93033203400
    BMW 33 21 1 205 840
    Lobro C.153.15.87.002
    Regards,
    David
  7. fatbillybob
    Aug 10, 2002
    28,545
    socal
    David,
    NICE! Do you have the CV boot part number too?
    we need to stick these #'s in the 348 part interchange thread
  8. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    If...you have the OE flange on your above listed CV joint, then the Porsche 90133229312 boot will do the trick. If the flange has been change in the past, you may be on your own. I've used this boot for 20+ years now, with only an occassional fitment problem.
    If I recall correctly, Ferrari used Porsche flanges for their CV joints...hence the above listed boot will work. However, some (Mickey Mouse) shops had replaced the (needlessly damaged) flange with a BMW 6 type....and the boots were different. (The CV joint listed above fits most 911, 930 and some of the early 5 or 6 series BMWs.)
    And...for the racer types, there is also a "light-weight" version of the Lobro joint, though I do not have the part number at my fingertips.
    Regards,
    David
  9. fatbillybob
    Aug 10, 2002
    28,545
    socal
    excellent!
    Thanks David
  10. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,446
    Will Tomkins
    GKN Driveline sell these in UK & Europe, but they're not very easy to deal with.
    365GT 2+2, GT4 2+2, GTB, GTC, 400, 412 also use the same
  11. miked
    miked Formula Junior
    Feb 7, 2001
    891
    Cincinnati, Ohio
    246tasman, you are correct. GKN is a big international corp. that probably doesn't want to deal with orders less that 1000 (or maybe 10.000) units.
    Some of the machinery that we use at work is made in Germany and uses a lobro CV joint on a drive shaft. Our manager thought it was exotic hardware and judging by the replacement cost from the equipment manufacturer, it was. I identified it as a typical Audi/VW CV joint and got a cheap replacement locally. They are widely used in the industrial field as well. A look in in the GKN catalog shows all the different sizes (diameter, thickness, bolt pattern, boot style, etc.) available. Each car manufacturer uses the combination that meets their application requirements.
    Ferrari CV joints are not exotic or special, available at most good foreign car parts houses by cross reference to Porsche or at a industrial powertrain supply house by dimensions.
  12. staatsof
    95,282
    Fuggetaboutitland
    Bob
    Yup. I use that one on my Bora and also with some slight changes on my Espada as well. BMW 5&6 series boot kits from the early to mid 80's fit just fine it it's the standard flange.
    The Bora and Espada use 4 bolts and 2 roll pins to secure things but this one works either way.
    Bob S.
  13. jratcliff
    jratcliff Formula 3
    Sep 7, 2004
    1,024
    Texas
  14. jratcliff
    jratcliff Formula 3
    Sep 7, 2004
    1,024
    Texas
    Well anyone know?
  15. jratcliff
    jratcliff Formula 3
    Sep 7, 2004
    1,024
    Texas
    Still looking for an answer?
  16. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    John,
    The answer is more than likely, yes. As you may know, Ferrai does not list the CV as a replacement part. Ferrari only offers the complete axle assembly, which, as expected, is very expensive. Hence, it's not a simple parts look-up.
    However, in the the TR and the BB use the same differential output flange...and these CV joints have been used since the 246 Dino, so the likelyhood of it being different are very slim.
    Regards,
    David
