Liqui Moly engine additives | FerrariChat
Discussion in '348/355' started by gpiro, Apr 29, 2024.
  1. gpiro
    gpiro Formula Junior
    254
    NJ
    Has anyone used Liqui Moly anti friction engine treatment or motor oil saver in their 355. If so was it beneficial.
  2. JoeCab
    JoeCab Formula Junior
    364
    Colorado
    Joe C
    Liqui Moly is one of the better companies when it comes to chemical additives actually working, but I would question what problem you are trying to solve with an additive? We would sort of need that information to start with.
    Without starting a huge debate about which oil is best, I personally prefer to just find an oil with the correct spec. for an application and not worry about additives.
    The only additive I've ever used is Redline Engine Break-In Additive - when I was breaking in a freshly rebuilt engine.
  3. Targatime
    Targatime Formula 3
    1,434
    Los Angeles
    I don't know how anyone would be able to know if an oil additive was beneficial. You'd have to have a meaningful sample size of engines, test and control groups, and engines run under identical conditions for identical mileage. Some guy posting on the internet "I add a bottle at every oil change, it works great!!!" is utterly meaningless.
    ChoonHound, Extreme1 and Rifledriver like this.
  4. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,727
    Central NJ
    Eric
  5. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,633
    NJ
    Peter
    People get confused between gas an oil additives being "snake oil" products. Quality gas additives are almost universally beneficial (virtually never snake oil), because they provide some degree of cleaning and they don't have any meaningful downsides.
    The effectiveness of oil additives is highly variable and probably pretty random. Whether an oil additive works at all, or even whether it is a positive or a negative -- will depend on which specific oil you happen to be running. Quality oil manufacturers spend a lot of time getting their oil formulations exactly correct based upon their own testing. Quality oils are already optimized as perfectly as they can be -- adding anything to that already optimized oil can through off the balance and easily make it worse, even if the additive contains "good" ingredients. It's just impossible to make an additive that will be beneficial to any oil you happen to be using. To me, it's much better to choose a quality oil and forget oil additives.
    The only exception is if you are looking to "fix" something. Supposedly, this Cummins Restore oil (https://www.theautopian.com/cummins-has-a-super-fancy-oil-meant-to-kick-engine-rebuilds-down-the-road-heres-how-it-works/) can help an engine with stuck rings by dissolving carbon deposits. I know nothing about this stuff, but somebody I respect says that under the right conditions it can help with an engine that has very heavy carbon deposits.
    Something to clean up deposits a hundred before an oil change maybe could help. As far as additives to make oil work "better" over the entire oil cycle -- I don't think that works just because you'd have to know the exact composition of an oil to improve it (something the manufacturer can't know when they make the additive). I don't think a "one size fits all" additive can improve things for the reasons stated.
    Rifledriver and PaulK like this.
  6. Rifledriver
    36,745
    Ferrari engines almost never reach end of life because of wear of the lubricated parts.
    Rings and ring lands are not dependent on lubrication. Cylinder wear from rings is not lubrication related. Valve stem and guide wear are not lubrication related.
    Those are why the engines are rebuilt.
    What are you hoping to achieve with oil additives? Bearing wear? Cam wear? Piston skirts? Those are typically still functioning perfectly when engines get rebuilt.
  7. KevZep
    KevZep Formula Junior
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    I use a Lucas Oils additive which has full Zinc, a lot of the oils these days do not have Zinc which is incredibly bad for engines such as our Ferrari's ...
  8. Ferrarium
    Jul 28, 2018
    5,727
    Central NJ
    Eric
    #8 Ferrarium, May 2, 2024
    90% of Lucas products are snake oil, its a marketing organization. Lots of tests on BITIG going back since late 90s where their oil additives render the oil useless, a foaming mess. I stay clear of all Lucas products.
    https://bobistheoilguy.com/forums/threads/lucas-oil-stabilizer.128365/
    Amsoil z-rod and premium have ZDDP elemental averages Phosphorus - 1350ppm, Zinc -1425ppm, and Sulfur - 3800ppm.
  9. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,817
    Richmond
    Pete
    I use mobil 1 euro blend oil as it has higher zinc content, but there are probably others out there. I know valvoline vr1 also has higher zinc content. I'd think it's better to use an oil specifically formulated with that in mind than a different oil and an additive, but I'm not an expert.
  10. JLF
    JLF Formula 3
    1,703
    Man I was quoted $180 for a case of Amsoil last night. It was 150 last year.
  11. bamaman
    bamaman Formula Junior
    Nov 27, 2015
    895
    Mobile Alabama
    William M (B.J.) Lyon, Jr.
    So...Bidenomics has now reached Amsoil? Never underestimate Brandon's ability to F--- something up.
  12. Rifledriver
    36,745
    I have not even read why you say that but I completely agree.
  13. Rifledriver
    36,745
    God only knows why you say that but its proof positive that advertising trumps knowledge every time.
  14. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,633
    NJ
    Peter
    #14 peterp, May 2, 2024
    Sounds like it's safer to stick with Lucas electrical components :)
  15. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,633
    NJ
    Peter
    #15 peterp, May 2, 2024
    I've had 3 bottles of ZDDPlus sitting on the shelf for a long time. I think it's fairly highly regraded to raise ZDDP levels for flat tappet engines since most modern oils have reduced ZDDP content.
    I've heard that ZDDP levels were required to be reduced because it is not good for catalytic converters, so maybe ZDDPlus is not good to add to a modern engine. But for vintage cars, it's probably good to use if you are running a modern oil that has reduced ZDDP content (e.g. <1200).
    I've been running Shell Rotella in the 330GT, which I think still has sufficient ZDDP, so I haven't added the ZDDPlus.
  16. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,633
    NJ
    Peter
    Oil prices are pretty crazy. I've been using Driven DT40, which is highly recommended for my 996, but it's $190 a case. Now Driven DI40 seems to be they superseding recommendation for the 996 (even though the 996 doesn't have direct injection) and the DI40 is around $220 a case.
  17. Targatime
    Targatime Formula 3
    1,434
    Los Angeles
  18. KevZep
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    I have not found this to be the case at all, no foam in any of my vehicles with the Lucas products....I've been using Lucas products for decades and never has anything but good results.
  19. KevZep
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    Obviously I'm an idiot and have no idea what I'm talking about...
  20. Rifledriver
    36,745
    Well you still believe Ferraris need more ZDDP.
    I rest my case.
  21. KevZep
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    Thank you.
