Lifts | FerrariChat
Lifts
Discussion in 'Technical Q&A' started by Huskymaniac, Dec 10, 2020.
  1. Huskymaniac
    Huskymaniac Formula Junior
    Jul 9, 2020
    271
    Finger Lakes, NY
    Tony
    I am looking at lifts. Unfortunately my garage is only 8'6" so that eliminates all 2 post lifts that I have been able to find. My fall back is to cut into the ceiling. I have been looking at one post lifts, four post lifts and even scissor lifts. I like the 4 post lifts but I am thinking it would be impossible to drop the engine out of the 348 with that type of lift. Any advice?
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,561
    Central NJ
    Dominick
    Bendpak md-6xp
    Search the forum for that key word and other threads will come up that give you all the options
    Sent from my moto g(7) using Tapatalk
  3. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    no with some ingenuity you can drop the 348 engine with a 4 post. There are some pics somewhere here of a 355 doing it.
  4. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
  5. Huskymaniac
    Jul 9, 2020
    271
    Finger Lakes, NY
    Tony
    That has a minimum height of 4.75" and the 348 has 4.5" clearance. No problems?
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,561
    Central NJ
    Dominick
    The way you get around that is you build runways from 2x10 doubled wide and 2 thick on each side ..8 all together .. the lift will fit direct in between and then you drive up onto the wood .. you can layer 1x10 (three of them each side ) in front to make driving onto the wood easier
    Or you can always cut concrete and recess it ..
    I did the first option
    Huskymaniac likes this.
  7. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Did you look into the portable maxjacks just for service work?
  8. dennis_maine
    dennis_maine Karting
    Sep 11, 2007
    196
    ME
    Dennis Haines
    I bought this one: https://www.gregsmithequipment.com/Atlas-9KBP-Baseplate-9-000-lbs.-Capacity-2-Post-Lift?gclid=Cj0KCQiAzsz-BRCCARIsANotFgNjkGRQ8CU9kk3CEjltnHzcRnYyYEq03UTJU2hkiH5VVbHhklLkBtgaAuZ8EALw_wcB about 6 - 8 years ago, at Gregg Smith Equipment in New Hampshire. I picked it up with a 1/2 ton pickup, and as there is no sales tax in NH, the advertised price was the total price. I installed it myself, too. Pretty easy. It is 9' 3 1/2" tall, but since it is a baseplate lift the tops of the posts can just stick through the ceiling, if your garage has a finished ceiling. The garage where I have the lift has an open ceiling, so it made it that much easier. Its an incredible price, and the lift has been trouble-free. The welds and hardware are first-rate.
  9. Ray Smith
    Ray Smith Formula Junior
    851
    Costa Mesa, CA
    Raymond Smith
    I bought and use the Quick Jack lifts. They work great. Raises the car far enough so I can use my creeper.
    View attachment 3052437 View attachment 3052437
  10. fatbillybob
    Aug 10, 2002
    26,292
    socal
    My 2 post fits in 8ft ceiling but no longer made. Try mohawk A7. I think it is 8ft twin.
  11. tantumaude
    tantumaude Formula Junior
    929
    Burlington, Canada
    Mat
    I've very little lateral room, and I need to be able to park two cars in winter. My ceiling is reasonably high, so I went with a scissor lift. Works well and has a small footprint.
    I can do pretty much anything on it (driveshaft swap being the only thing I would likely struggle with as the structure would be in the way).
  12. Huskymaniac
    Jul 9, 2020
    271
    Finger Lakes, NY
    Tony
    That works! Pricey but it works.
  13. Huskymaniac
    Jul 9, 2020
    271
    Finger Lakes, NY
    Tony
    No but I just did and that works too!
  14. fatbillybob
    Aug 10, 2002
    26,292
    socal
    Yes but there is no finer lift. It is asymmetric so you can open the doors. That is a huge +. The Mo will outlast any car you will ever own
  15. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,264
    MA
    Have the Bendpak MD-6XP. Excellent tool. Limited ceiling compounded by the Central Air Duct taking another 12" directly over Ferrari.
    Have done majors on my prior 348, 2X F355 and service my current 360. No problems removing drivetrain on both the 348 and 355. Rear bumper off, comes right out. Image Unavailable, Please Login
    lm2504me and Manda racing like this.
  16. Huskymaniac
    Jul 9, 2020
    271
    Finger Lakes, NY
    Tony
    I was not able to get a lift in before the car went into hibernation so I am coming back to this. I read something about scissor lifts in that they have a hard time getting started due to the small angle between the hydraulic cylinder and the lift arm. Your stack of 2x10s will get the car up 3". It starts out at about 4.5". So it is 7.5" total and the lift starts at 4.75". That means it will lift only 2.75" before it reaches the car. You have found this to be sufficient for the lift to have no problems initially getting the car off the ground? No noticeable struggles?
  17. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,561
    Central NJ
    Dominick
    My bendpaK handles the 512tr well (no struggles) with mine setup
  18. siegrisd
    siegrisd Rookie
    Nov 22, 2006
    32
    Castle Pines, CO
    Dan Siegrist
    I'm going to be installing a Triumph C-7000 which is a plate-less, "portable" lift. I have portable in quotes because it doesn't have wheels on the uprights and does need to be unbolted/rebolted every time it's moved in and out of storage. It does have the advantage of operating like a regular 2-post lift with nearly 6 feet of clearance under it. The posts are 8 feet tall, so, it would fit within your ceiling without having to redo any of your existing ceiling framing. You could also go with the Danmar MaxJax which are pretty similar, but, only lift about 54 inches. The MaxJax bolt to the floor in a similar way to the Triumph but are a little less unwieldy to move around.
    Let us know what you come up with!
  19. Jdubbya
    Jdubbya The $10 Trillion Man
    37,253
    PNW
    That might just work in my garage. And that's a killer deal.
  20. Scott Holliday
    Aug 28, 2020
    29
    Houston, TX
    Scott Holliday
  21. Eds458
    Eds458 Karting
    Jan 24, 2020
    59
    Northern California
    Edward Lagunte
  22. Scott Holliday
    Aug 28, 2020
    29
    Houston, TX
    Scott Holliday
    I'll put together the information for you tonight.
  23. 85MondialQV
    85MondialQV Karting
    Feb 20, 2021
    98
    Matt Drake
    I’m curious myself. Let me know the ceiling height. Thanks!!
  24. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,792
    Henderson, NV
    Roberto Bellezza
    85MondialQV likes this.
  25. 85MondialQV
    85MondialQV Karting
    Feb 20, 2021
    98
    Matt Drake
