Left TFT display - park sensors "stop and go" | FerrariChat
Discussion in '458 Italia/488/F8' started by jipettersen, Aug 11, 2013.
  1. jipettersen
    jipettersen Karting
    Jul 4, 2013
    90
    Oslo, Norway
    I was playing with the left TFT menu. In the menu "settings" and "car settings" / park sensors "stop and" i changed the input.
    Now the parksensors are visible on the screen when i go under 10 km/h. So far so good.
    But now i cannot activate the MENU button anymore when I'm standstill !!!!!
    Just the parksensor aid is visible in the TFT. Then i push the menu to try to change settings again and nothing happens in the TFT (still park sensor window).
    When I'm driving the TFT changes and i can use the menu button, but then i only have the "speed limit input" option.
    I page 107 this is described.
    My guess is my dealer dont have a clue.
    I´m stucked.
  2. dr.sb
    dr.sb Formula Junior
    Aug 19, 2011
    789
    Sunny B
    Tried putting the car at standstill in neutral and then changing menu?
    Sunny
  3. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    turn the parking sensors OFF using the switch in the overhead console. it will revert the display.
  4. oedipol
    oedipol Karting
    Apr 7, 2012
    150
    HKG
    #4 oedipol, Aug 11, 2013
    when the sensor is active at speed lower than 10km/h, u only get the sensor display and cannot change anything , that is normal. if you want, u can either disable the sensor temporarily as described above or permanently via settings.
    However, once u get going and all you get is speed limiter, then you have a problem ! I have had the same problem before but it has been fixed now after 4 weeks at the dealer.
    checkout here:
    http://www.ferrarichat.com/forum/458-italia/415630-software-glitch.html
  5. not4one
    not4one Formula Junior
    May 23, 2010
    887
    CT, FL
    +1...I experienced exactly the same frustration 10 months ago and my salesman at Miller fixed it in 5 seconds doing just this.
  6. jipettersen
    jipettersen Karting
    Jul 4, 2013
    90
    Oslo, Norway
    Thanks !!
    I feel stupid !!!!
    This is only my second day with the car
    Ballie64 likes this.
  7. Ltfor3
    Ltfor3 Karting
    Oct 14, 2013
    171
    FL
    L.T.
    +1. I just had the same issue here. Had the car about 2 weeks now. I read the manual section on this 5 times to no avail. Did a quick search here and found this in 2 minutes with the exact answer. This forum should be paid for entirely by Ferrari because it saves their dealers and customers so many headaches. Thanks Entropy- easy fix, but not int he manual.
    Ucla2525 likes this.
  8. CH_348
    CH_348 Karting
    Nov 10, 2016
    66
    Zurich, Switzerland
    Chris Steinacker
    6 years later, same mistake, just as thankful to you guys for providing me with the simple solution! Worked by just switching parking sensors off on the roof-console even though I also had only the speed limiter available during cruising. So no biggie at all. Thanks Fchatters!
    Gesendet von iPhone mit Tapatalk
  9. malcolmb
    malcolmb Formula 3
    1,214
    San diego
    Malcolm Barksdale
    I was frustrated by this "feature" also, dealer told me about the button....BUT-what is the point of programming it this way?
  10. 997_T_u_r_b_o
    997_T_u_r_b_o Rookie
    Nov 14, 2020
    35
    Steve S.
    This saved me a from several headaches today. Thank god we have forums like this to fix these simple issues.
  11. TMcD
    TMcD Rookie
    Dec 25, 2015
    1
    Just tried to reset my TPS code only to find out that the Left TFT Would only show front sensors screen until Driving the car, didn’t want to attempt resetting TPS while driving the car, not really sure if you can anyway. Every time I came to a stop the sensor screen showed back up. I also tried to read the manual multiple times without any success. I am also glad I found this thread otherwise I would’ve been up all night wondering why I can’t get my head on straight about understanding what I was doing wrong. If I turn off the sensors on the overhead counsel will it happen again when I turn it back on or does it automatically reset itself on once you turn the car off and then back on. I apologize if I’m not wording this correctly as I’m a little bit confused about all of it.
  12. RayJohns
    RayJohns F1 Veteran
    7,952
    West Coast
    Ray
    Once you turn it off using the overhead button, that should be the end of it. Totally moronic setup by Ferrari.
    Ray
    TMcD likes this.
  13. xBox
    xBox Formula Junior
    Aug 16, 2018
    515
    The Emerald Isle
    Don't, the User Interface is quite unfriendly and horrid :rolleyes:
    jm2 likes this.
  14. 3POINT8
    3POINT8 F1 Veteran
    5,480
    I had this same thing happen to me it was like being trapped in purgatory. I found an old thread on here that said hit the overhead button and it worked.
  15. schmidtg1
    schmidtg1 Rookie
    Sep 10, 2021
    2
    Moseley, VA
    Eric Schmidt
    Thank you, this is no where in the owners manual and I've been scratching my head for days on this. Much appreciated.
  16. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    958
    Europa
    Bob
    Man! I was going nuts in my new to me Cali T. Found this thread and “bingo” problem solved. Nine years later and you’re still helping people! Thank you so much!!!
    Rexcat458 likes this.
  17. 05F430F1
    05F430F1 F1 Rookie
    3,599
    Fort Lauderdale, Florida
    Todd
    Ok so I have same problem in my F8– annoying AF— however, I do t think I have an option on overhears panel to turn off… there is a button there that I guess could be it (one on the right of three)- but it doesn’t turn it off… just keep f’ing beeping like a madman….. I tried clicking it. I tried holding it— and still beeping away and left TFT still stuck on that stupid sensors graphic…. Help?
  18. 05F430F1
    05F430F1 F1 Rookie
    3,599
    Todd
  19. 05F430F1
    05F430F1 F1 Rookie
    3,599
    Todd
    I got it… on the F8, it’s no longer on overhead panel, it’s on the dash next to the lifter
    rob5819 likes this.
  20. dweintra
    dweintra Karting
    Aug 16, 2012
    130
    Seattle, WA and Miami, FL
    Don Weintraub
    Same issue for me on my new 488. I should have never played with the menu! Glad I found this thread:)
  21. fganonimo
    fganonimo Rookie
    Dec 23, 2022
    20
    Thank you!
