Leaky front crankshaft oil seal | FerrariChat
Discussion in '348/355' started by pnicholasen, Feb 9, 2012.
  1. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Finished my engine out "major", so the final "part VIII" of the video saga is now on Youtube. Everything ran perfect except for a slow oil drip from the front crank shaft oil seal, which drove me crazy, so I replaced it (yeah, that was real easy.....). It's now drip free. I made several changes in the instalation proceedure for the second seal go-around. Anyone replacing the seal on their car, check out the video and maybe you'll get it drip free the first time out:
    [ame]http://www.youtube.com/watch?v=iah5o5YxQXE[/ame]
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,611
    The Brickyard
    The Bad Guy
    Well done.
    Your videos will be great help for the 348 Brotherhood.
  3. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    Congratulations!
    It must feel so good to hear her come to life after you've had her in pieces.
  4. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    Awesome video !
  5. 50hdmc
    50hdmc Formula 3
    Oct 10, 2006
    1,211
    Michigan
    mark s
    GREAT job.....brings back memories of just a few years ago myself.
  6. PAP 348
    Dec 10, 2005
    100,199
    Mount Isa, Australia
    Pap
    Cool video! Well done. :)
  7. AceMaster
    Feb 6, 2009
    34,749
    Ontario, Canada
  8. White Knight
    White Knight Formula 3
    Aug 22, 2011
    1,531
    Ogden, UT
    Todd S.
    Very nice video!
    A picture's worth 1000 words.
  9. vjlax18
    vjlax18 Formula Junior
    686
    Nottingham, MD
    Old thread, but I used the search feature...
    When the crank seal was done the second time, was the front cover pulled again or is it possible to replace it without pulling the cover?
  10. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    I pulled the front cover off again. Yeah, lot's 'o fun!
  11. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    You did this with the engine in the car?
  12. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Nope, gotta drop it.
  13. yelcab
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    Did not see how without dropping it. Gutsy man.
  14. vjlax18
    686
    Nottingham, MD
    I was wondering if there was any super secret magical way to use the Force to pull the seal without pulling the cover, but I guess not.
  15. ghardt
    ghardt Formula 3
    Apr 18, 2004
    1,260
    Texas
    Jerry
    How is the crankshaft seal holding up after 3 years? dry?
  16. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,677
    Lake Villa IL
    On some cars you can sometimes carefully drill a small hole in the seal, thread a screw into the hole and then remove the seal with a pair of angled needle nose pliers.
    If that is possible on this engine I am not sure.
  17. vjlax18
    686
    Nottingham, MD
    Yeah, I wasn't looking to pull the front cover when I change my belts in the next few weeks, but the seal is leaking and I think I'll just pull it and everything else that needs to come off to do it.
  18. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,677
    Lake Villa IL
    Probably the best option.
  19. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Yep, dry as a bone...
  20. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    A PITA, but it does allow you to check the condition of those ridiculous plastic rubbing blocks. Pulling the front cover off wouldn't be quite so bad if it didn't involve removing the oil pan too, which requires removing the shift linkage parts, etc., etc, etc. Like a damn puzzle!
  21. albagtp
    albagtp Karting
    57
    Beach City
    Bryan
    Thanks for another in your series of great videos.
    I have used clear packing tape over the edge that the seal needs to go over in the past to prevent damage to the lip. A drop of oil on the tape push the seal over and remove the tape once the seal is seated. It doesn't take much to scratch the lip.
    I also always put a little sealant around the outside of the seal. I have seen too many weap a little around the edge.
