Leaking wheel rims?? | FerrariChat
Discussion in '348/355' started by hjp, Oct 14, 2016.
  1. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    I have stock 355 OEM Speedline wheels. One of the fronts and one of the rears has significant leaks where the tire bead seals to the rim. This occurs on the inside rim of both wheels. The 2 others are fine. The leaks take about 10 days to loose 10 pounds.
    I found the problem by filling the tires to 50# and lying the wheels flat on shims under the tire sidewalls to prevent scuffing the spokes, backside up and putting soap solution all around the rim. Almost immediately tiny bubbles started to form practically all around one of the rims and part way around the other. Obviously there is something wrong with the rim seal.
    I plan to dismount the tires and make sure the rim surface is smooth with no irregularities. I also have thought about spraying a urethane clear sealer all around the inside of the rim to make it even smoother before remounting the tires. I also will ask the tire guy to use the bead sealer when he mounts them this time.
    Anyone else experience this? Any other ideas to fix it?
  2. plugzit
    plugzit F1 Veteran
    7,744
    Redondo Beach, CA
    Bruce Bogart
    Let some air out. With the wheel upright, hit the tire sidewall with a 4lb hammer. Obviously, don't hit the wheel. Sometimes sand or pebbles will lodge in the bead and cause leaks.
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,004
    Indio Ca/ Alberta
    Grant
    I have had ni problems with either set and I run tpms and they dont loose 1 lb per year.
    One interesting point is that I believe it is the right rear tire tends to get hotter and increase in pressure consistently over the other rear.
    I suspect power is delivered more to my right rear than left. About 1 to 2psi and 8 degrees on spirited drives around town.
    Any theories from the racers?
  4. phrogs
    phrogs F1 Veteran
    7,312
    Michigan
    If they are leaking the bead is compromised, you'll have to figure out why.
    Most of the time when I encounter a slow leak its the valve stem, change the needle and its fixed.
    Have fun
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,905
    Isle of man- uk
    This happened to 1 of my mondial wheels, it was fine until we fitted a new tyre and it was flat the next day.
    It looks like the rim was corroded and the final failure occured removing the old tyre. To look at it you would not think there was a problem but we had to get a new rim as it was going to cost more to repair it.
    I think the mondial rims are a mag alloy so not the easiet to repair.
  6. JoeAsheville
    JoeAsheville Rookie
    Jun 15, 2014
    45
    Your local tire service professional has easy solutions for this. It's simple for them to do and only costs a few bucks. Just carry the problem assemblies down to a local shop you trust and see what they have to say.
  7. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    +1....probably just some oxidation on the inside of the rim.....easily corrected.
  8. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Agreed, *if* he has a tire & wheel _professional_ local to him. They're getting more and more difficult to find. Lots of semi-trained high schoolers around but not always easy to find an experienced pro, which is what is needed in this case, especially with mag wheels.
  9. JoeAsheville
    JoeAsheville Rookie
    Jun 15, 2014
    45
    I certainly agree.
    Hence the use of the title "professional" ;)
    At some point in the past, I trusted no one in a 150 mile radius. Getting loose tires mounted on wheels amounted to a day trip.
    I would certainly hope that a city the size of KCMO had someone at the level required for a competent job...
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,905
    Isle of man- uk
    It is ok getting it bead blasted and then putting filler on the leaking area but you dont know how deep the corrosion is on these mags. The filler is not going to stop a piece of the rim failing. The cost of repairing a rim for these cars is more than a new one, plus you know that a new rim is not going to let you down
  11. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    Thanks everyone for your help and suggestions. I'll try to find a "professional" in my area and go from there. There's a place called KC trends that specialize in exotics that might be the right place to take them to.
    I should tell you that Braden refinished all 4 of my wheels just before I mounted the new Michelin Pilot Super Sport tires. I don't believe the rims are in any danger of failing. I'm pretty sure a good seal against the leaking rims should fix my problem.
  12. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,632
    When I had my 355 rims "redone" last year, 2 of them ended up having to be replaced due to cracks in the grain structure--both of these wheels would hold air for months at a time.
    By the way, they look great in Battleship grey with gold metal flake.
  13. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,905
    Isle of man- uk
    We tried removing the raised letters on the bead but no difference, it still leaked when the assembly was put in a trough of water. Like mitch says the fault is in the metal structure, the magnesium seems to turn to powder. A new wheel in uk is about £200
  14. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    The leak is clearly between the tire bead and the wheel rim. There is no sign of a leak anywhere else, especially through the metal rim itself. I believe making sure the rim is both smooth and well sealed should do the trick....at least I hope so.
  15. blue90
    blue90 Formula Junior
    Dec 15, 2013
    339
    NJ
    Dave
    For the last 8 months I have been filling the front drivers tire with air as it leaked halfway every week. Within 2 weeks it was almost flat. Using soap and water obvious to find the the bead leaked. Because the wheels were powder coated after having installed brand new tires some of the overhanging powder coat material was caught on the bead.
    Easy enough to fix at a local shop, they basically stretched the bead, cleaned it with air and scrubber while adding a paste to seal it. No leaks in a month now so annoyance is gone.
  16. redzone
    redzone Formula 3
    Mar 31, 2007
    1,218
    Beach
    I had the same problem and each of the rears were cracked causing the leak. This was found under close scrutiny. Since they are magnesium and the quality of a repair might not be up to par so I replaced them. The old ones are now décor.
  17. Alden
    Alden F1 Rookie
    3,365
    Central Florida
    Which aftermarket TPMS system did you install?
    Alden
  18. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    would make great coffee tables with some creativity and some glass
  19. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,905
    Isle of man- uk
    Wise man as not worth the risk as the magnesium goes like a powder with the corrosion, i saw on the tv where they tried to repair a mag casting by welding, looked a bit tatty and fell apart when they tried to recut the thread in it with a hand tap.
  20. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    Update: I took the leaking rims to a local expert. They discovered the leaks were due to excessive paint runs on the inside of the rims. They sanded the runs off and applied a bead sealer as insurance. Now they are fine. Word to the wise, if you have your wheels refinished, check this before mounting the tires. Anyone can make a mistake.
  21. redwedge
    redwedge Formula Junior
    Sep 30, 2012
    436
    London
    Steve C
    From where, please?
  22. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Glad you got it sorted!
    Another area of concern after refinishing wheels is the lug seats and the hub faces. Good refinishers know to avoid painting/coating the these areas but some paint everything. The soft paint/coating does not allow the lugs to maintain torque so any paint on the lug seats & hub faces should be removed prior to installing the wheels. And don't forget to recheck the wheel torque a couple of times after reinstalling your wheels, especially if they've been refinished.
  23. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,004
    Indio Ca/ Alberta
    Grant
    Would love to see some pics Mitch if they are handy.
  24. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,004
    Indio Ca/ Alberta
    Grant
    Mike just a thought but have you tried nitrogen inthe problem tires. If its a very small leak nitrogen will work.
  25. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Only if you consider osmosis a leak. ;)
