348 - Leak between motor/trans | FerrariChat
348 Leak between motor/trans
Discussion in '348/355' started by Aceofspades, May 3, 2021.
  1. Aceofspades
    Aceofspades Karting
    Apr 24, 2019
    62
    Chicago
    Kevin K
  2. Ferrarium
    Ferrarium F1 Veteran
    5,631
    Central NJ
    Eric
    Looks like rear main seal is wet? The top red circle is that is.
    brogenville likes this.
  3. Aceofspades
    Aceofspades Karting
    Apr 24, 2019
    62
    Chicago
    Kevin K
    Well that is true, but it also sits inside the trans.
  4. Ferrarium
    5,631
    Central NJ
    Eric
    On the gear box side there is an o-ring part number 131736 also according to the parts diagram. one or 2 others, but not in that area. I suspect it is the rear main seal. http://www.my348.com/348.html#rearmainseal. Not may things there. Seal on one side and o-ring on the other. Replace them both? They are pretty cheap. I think there are some posts out here on that, I know Ernie did his.
  5. Rupp3r
    Rupp3r Karting
    Aug 26, 2016
    182
    France
    Hello
    I think I had the same leak.
    I replaced the main seal but I think the leak came from the crank/cover assembly.
  6. Aceofspades
    Aceofspades Karting
    Apr 24, 2019
    62
    Chicago
    Kevin K
    Yea I think the cover is leaking
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    When you are in that deep, you change the RMS, the seal for the RMS carrier, the gearbox O-rings.
  8. Aceofspades
    Aceofspades Karting
    Apr 24, 2019
    62
    Chicago
    Kevin K
    Indeed I did every thing back in 2019 but who knows maybe some thing slipped on install
