It will not do most activations like f1 bleeding , clutch bkeeding gearbox relearn etc I believe it will do brake bleed though It is definitely a good little tool .. If you do a search on here or other forums you can see people using it Sent from my moto g(7) using Tapatalk
Flash32, thanks for the help pointing me in the right direction. Using CFC301 my readings were clutch position closed 0.73 inches and clutch position closed from new 0.67 inches. So that translates to: 18.542MM-17.018MM= 1.524/5.6*100 =27.2%. This makes much more sense given the readings over the last four years and 7K miles (18%, 24%, 25%, 27% which was 1300 miles ago). The clutch doesn’t appear to have been changed previously either.
I can give you upto v10.80 but the latest is v10.85 , hopefully a ferrari chatter is willing to share it
I don't think it is as easy to copy files from one user to another ..there are safeguards /locked to each serial number I believe .. have you tried this ? Sent from my moto g(7) using Tapatalk
i am not too sure flash , i have copied my own files from my tablet onto my pc then copied them onto my android phone. im not sure if its locked with serial , i just copy the V i want and it loads up. If someone can send me the V10.85 files/folder i am willing to test it
I believe flash is correct. They are locked to each serial number. It's a cheap upgrade. .. I think I paid $60 to upgrade to v10.85
I think the license libstd dpu and adp files I believe guessing are serial dependent Sent from my moto g(7) using Tapatalk
An Fchatter was kind enough to send me v10.85. I cannot get it to work. I believe the software is serialized as mentioned above. Marin JT......pm me and I can send you the zip file if you still need it.
Did you copy the four files from an older version you had to the new foider ..if not try it Sent from my moto g(7) using Tapatalk
i did manage to get my hands on the v10.85 and tried copying over the 4 files you stated and as jgvioo stated it is locked to serial , i tried to locate read /edit where the serial is stored with no luck .such a shame we cant share with the ferrari chatters !
I kinda figured that as stated originally but wanted to see if a long shot would work .. they have put more safe guards in the past few years . I believe originally was just the license needed to be copied Thanks Sent from my moto g(7) using Tapatalk
