Launch 431 pro mini clutch life | FerrariChat
Discussion in '360/430' started by 78bonanza, May 9, 2020.
  1. 78bonanza
    78bonanza Formula Junior
    Apr 1, 2018
    350
    Jim Cear
    Can the Launch 431 Mini read clutch used/remaining on an F1 transmission ?
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,092
    Central NJ
    Dominick
    What year / make car
    The mini pro can read the closed clutch position and new closed position and a wear percent can be calculated
    The wear percent field does work but not always on all models
    So yes you can determine the wear using the mini pro for f430 and a 360 with a CS tcu
    I cannot speak to earlier 360 ..I believe there were issues reading the tcu on those ..
    Sent from my moto g(7) using Tapatalk
    kes7u likes this.
  3. kes7u
    kes7u Formula 3
    Oct 18, 2017
    1,230
    Shorewood, MN
    Kevin
    That is correct, Dominick. The mini pro did not work with my 2000 Modena, but works perfectly now with the CS TCU.
    For some reason, many people (NOT impugning the OP) seem really bothered by the fact that they can't simply look at the unit to get percent wear. It really is a simple calculation based on easily available values.
    Kevin
    flash32 likes this.
  4. AandSC
    AandSC Formula Junior
    996
    Jax, FL
    Allen
    The X431 does give you clutch life remaining, but not where you would think. I took my 08 430 to a local shop where they used the Autel and I got a reading of 48.84 percent. I came home and found the reading of 48.92 on the 431. It was under Clutch Configuration.
    I think we need a 431 thread to help each other with info available, or not.
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,092
    Central NJ
    Dominick
    As previously mentioned .. some do work ..and since you have the newest tcu being a 08 for a f430 it makes sense ..some older f430 you would need to use the clutch close position
    Actually a favor .. please give us a print of closed clutch position ..and new clutch closed position and let's see if the calculation works as well
    Thanks in advance
    kes7u likes this.
  6. AandSC
    996
    Jax, FL
    Allen
    I tried the calculation and it didn’t work, or I was doing it wrong. My measurements were 1.78 inches and 1.93 inches. Applying the conversion to MM and calculation results in a much higher number.
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,092
    Central NJ
    Dominick
    Calculation of clutch wear percentage for Ferrari 360/430:
    Autocalibrated closed clutch position - NEW closed clutch position / Clutch thickness (8.5mm for 360, 5.6mm for 430) *100 = % wear on clutch
    I cut and paste this from another thread ..easier to cut and paste vs type
    This was courtesy of kes7u
    kes7u likes this.
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,092
    Central NJ
    Dominick
    I haven't seen it work for a 2000 Modena unless it has the CS tcu ..so not sure why you feel it works .. let us know your thoughts
    kes7u likes this.
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,092
    Central NJ
    Dominick
  10. AandSC
    996
    Jax, FL
    Allen
    Note that it doesn’t work with the X431 Pro Mini and an 08 430.
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,092
    Central NJ
    Dominick
    I have to disagree ..please show printouts of the calculated clutch position ...and new clutch closed position in mm .. we can determine percent
    Remember that the percent of wear figure can be changed so don't out too much into it
    Also make sure you select the right selection for tcu
  12. AandSC
    996
    Jax, FL
    Allen
  13. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,092
    Central NJ
    Dominick
    kes7u likes this.
  14. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,092
    Central NJ
    Dominick
    An just for the record ..please understand just trying to make it work for you .. others have done it and it works fine
    So if you don't want us to help see if it does work or what the issue is ...by all means I have nothing to gain here
  15. AandSC
    996
    Jax, FL
    Allen
    The X431 doesn’t give that reading in MM and the readings in TCU301 were similar. Happy to see if others with this reader have a different readout or can show a different result.
  16. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,092
    Central NJ
    Dominick
    Here is an example ..values in the forties usually represent the wrong software version used .. just going based in prior experience .. Image Unavailable, Please Login
  17. AandSC
    996
    Jax, FL
    Allen
    How would you explain the Autel (most recent version) providing the exact same reading?
  18. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,092
    Central NJ
    Dominick
    I know the wear figure is rewritable whereas the clutch position is calculated unless the person who changed clutch didn't put back the original value in new clutch position .. sometimes that happens
    That all being said ..if the 3.01 says the same thing as the 2.** Version on x431 then I have no answer other than the right values were not inputted during a clutch change or the wear percent was changed or the new version of the software 10.85 has a bug ..which I believe some have tested but not sure .. was the clutch changed ever since new ?
    Both tools are look at the same values in the tcu so it proves that at least the x431 and autel are reading the same location in memory of tcu
    Btw the only true way to get a close to accurate is to have someone look at the actual clutch thru the inspection window and see physical wear ...
    AandSC likes this.
  19. AandSC
    996
    Jax, FL
    Allen
    I’ll be doing my annual fluid changes next weekend, so I’ll look at the clutch then. Can’t say if the clutch was ever changed as there’s no record. I’ll look for signs it was changed next weekend also.
  20. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,092
    Central NJ
    Dominick
    I spent a little time researching my memory .. and found that when f131e was selected instead of f430 f131 ev08 the numbers appeared like yours ..almost exactly
    When you can check try the ev08 selection with both versions of the tcu 2.* And 3.* .. I am pretty sure you will get the right numbers ...
    I hope that will be the silver bullet ..
    This also happens on the autel when you select the wrong f430 model ..
    Give it shot .. I am also curious
    AandSC likes this.
  21. jag-oo-r
    jag-oo-r Formula Junior
    424
  22. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,092
    Central NJ
    Dominick
    #23 flash32, May 9, 2020
    The answer should be yes ..but to guarantee you I cannot since I have seen it tested in 07 08 and scuderia and a 360 CS TCU
    If you are only looking for a lite tool with limited bidirectional capabilities ..look into ap200 autel ..it will provide you with the data stream and perform some function ....nothing like setting values etc like pis etc but for dtc , and data streams for one car brand ..you can't beat it for 70 dollars
  23. AandSC
    996
    Jax, FL
    Allen
    That’s the one I have, and it does give you clutch wear, settings, and you can set PIS. You can get it from eBay for about $635.
  24. jag-oo-r
    424
    Great suggestion! I'll probably start there.
    Other than setting PIS, what other settings might I want to access?
    (and is chasing the PIS recommended? My car that i just bought from Dan "whatheheck" has a MASE tune in it, if that matters)
    Sent from my SM-G970U using Tapatalk
