keys stuck in ignition! | FerrariChat
Discussion in '308/328' started by Drew_4RE, Nov 8, 2008.
  1. Drew_4RE
    Drew_4RE Formula 3
    Dec 19, 2005
    2,292
    FL
    Drew
    sat down for dinner, manager came up and said valet can't get the keys out of my car! I went down and the key won't budge, can't even start the car.
    Any ideas or tricks? I'm not going to be able to get the car out of here without towing it
  2. Modeler
    Modeler F1 Veteran
    May 19, 2008
    7,330
    State of confusion
    a.n.other
    Any steering weight on the lock?
    Try relieving the force on the steering lock by slightly rotating the steering wheel. If its that you'll feel the force in one direction at the wheel and no possibility of movement in the other direction of rotation. Just turn the wheel slightly feeling it against the load and the key should come loose as the force comes off the steering lock.
    Otherwise I hope someone else has a better idea or experience.
    Einsteiger likes this.
  3. Drew_4RE
    Drew_4RE Formula 3
    Dec 19, 2005
    2,292
    FL
    Drew
    Thank you for the reply,
    There is no tension on the wheel at all...
    It's the weirdest thing, never experienced anything like this
  4. David_S
    David_S F1 World Champ
    11,260
    Mountains of WNC...
    David S.
    Keys stuck in the ignition? I think the root cause is that you should have inserted just one. Cram two or three in there & they're bound to bind up!
    Forgive me - just one of those days...
  5. Modeler
    Modeler F1 Veteran
    May 19, 2008
    7,330
    State of confusion
    a.n.other
    Only other thought is a locksmith. It is after all just a key and tumbler set up.
    Otherwise its the flatbed truck.
    In my country only the manufacturers dealers can fit a replacement lock. Govt regs as part of a car theft crack down.
  6. Scaledetails
    Scaledetails F1 Rookie
    Nov 19, 2003
    4,211
    Daytona Beach, FL
    Stephane
    It happened to me on one of my Mondial 8's, I had to fight it for a while (45 minutes one time), and it eventually turned, but be prepared for it to happen again, the whole assembly needs replacing. Not too expensive if I remember correctly. Spray some WD40 in there with the key in, it may help it out.
  7. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,761
    Cerritos, CA.
    I have strange feelings about that valet guy, Hmm!
  8. Rifledriver
    36,756
    #8 Rifledriver, Nov 9, 2008
    In 308/328 it is usually (but not always) the electrical switch in the back of the ignition lock. It is a bit of a hassle but it can be removed with a smallish straight blade screwdriver. Once out if the key can then turn the wheel can be unlocked and the appropriate wires jumped together to hot wire the car.
    If it turns out to be the switch be careful who you buy a replacement from. One of the major US suppliers of Ferrari parts is selling Chi Com knock offs that are absolute trash.
    He burned me with one of those pieces of crap.
    It is not a dealer part.
  9. Drew_4RE
    Drew_4RE Formula 3
    Dec 19, 2005
    2,292
    FL
    Drew
    thank you all for the help!
    I'm going to go down and try the ignition lock rifledriver suggested. Poor baby is still sitting in the parking lot at the restaurant.
  10. Dr Tommy Cosgrove
    36,228
    Birmingham, AL
    Tommy
    It's not a unique problem. This is the fifth or sixth time I have seen this happen. Good luck. Everybody I know got theirs out eventually and without it being much of a big deal.
  11. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    It's a BMW part <>$100USD.
    Buy only the SWF brand, made in Germany. Buy two, because you will do this again, and they are becomming rarer with time. I hope that this of some value.
  12. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Do you have a part# or car model and year?
  13. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    David &all.....is this one of those slowly-vanishing parts that should be stocked in my garage for a rainy day?
  14. jacques
    May 23, 2006
    877
    Los Angeles/Florida
    Of course..Here it is :SWF(Manufacturer) model# 800-040..BMW#61-31-2682-120..Used in '70's model 2002and many others.Ferrari #7000707. Try The Parts Bin .com...(They call it ignition lock assembly). Also available at large german car parts houses on-line. Remember, listen to Rifle Driver..don't get the Chinese part..SWF only.. I hope that this is of some use to someone. Thank you. Jacques.
  15. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    Thanks, all.
  16. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Thank you!
  17. billg
    billg Formula Junior
    Jun 7, 2006
    307
    New Orleans
    Bill Grady
    That's a pointless, hostile reply to a guy in a jam
  18. jaisharma
    jaisharma Karting
    Aug 4, 2011
    213
    South east, UK
    Jai Sharma
    Just to highlight the usefulness of all this info - had the exact same problem and that is now fixed thanks to this thread. Not easy on my car as the roll cage and fire extinguisher plumbing also was in the way.
    For those changing the switch, note the slit is a bit bigger on one side than the other, to avoid mis installation,
    Now I think I have made a wiring error because when the key is turned and the starter engaged, the engine just churns. However, when you allow the key to spring back the car starts! One other thing I noticed is that when you turn the key the fuel gauge goes down and then back up when the car starts.
    Any ideas?
  19. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    Totally agree.
    Andrew McCrae and Jakuzzi like this.
  20. Rifledriver
    36,756
    Terminals on the back of the switch are numbered. If you have a 308 compare to the wiring diagram in the back of the owners manual. If you have a 328 look on line at the wiring diagram.
  21. Jakuzzi
    Jakuzzi Formula 3
    Mar 26, 2005
    2,124
    PR, TX, GV
    Jaime
    7 years late ;)
  22. Saabguy
    Saabguy Formula 3
    1,784
    Shreveport, LA
    Better late than never?? And I read it as a bit of humor. And therein lies the problem with writing and emotion.
    Jakuzzi and Back'n'Black like this.
  23. jaisharma
    jaisharma Karting
    Aug 4, 2011
    213
    South east, UK
    Jai Sharma
    Many thanks indeed.
    Jakuzzi likes this.
  24. Jakuzzi
    Jakuzzi Formula 3
    Mar 26, 2005
    2,124
    PR, TX, GV
    Jaime
    So true. Had this been on the classified section the poster would have been banned! ;)
    Andrew McCrae likes this.
  25. BigTex
    79,321
    Houston, Texas
    Bubba
    Good info......switch jams, and I have had "key trouble" against lock wear and the whole lock rod/cylinder had to be pulled...
