Keyless entry disabled
Discussion in '296' started by aalterkait, Jan 9, 2024.
  1. aalterkait
    aalterkait Karting
    Sep 4, 2010
    60
    Kuwait
    Abdulrahman AlTerkait
    I have a question about the 296. When I took it to the dealership for pre-track check-up, the keyless entry feature and auto lock when leaving the car stopped working. Is it possible that the Ferrari factory removed this feature? I noticed that in the car settings (in the doors settings), there is no indication of keyless car entry or auto door locking. Have anyone heard from the dealers that Ferrari removed this feature from their cars?
  2. WLF046
    WLF046 Rookie
    Jan 7, 2017
    6
    There has been an update for all 296 and SF90. You can now select whether you want to have this feature activated or not. Default is set to deactivated.
  3. AliPaPa
    AliPaPa Karting
    Aug 16, 2011
    92
    I also noticed this "problem" after visiting the dealership recently
    aalterkait likes this.
  4. aalterkait
    aalterkait Karting
    Sep 4, 2010
    60
    Kuwait
    I took a pic of the doors menu before please see the photo below. All options are enabled in my car.
  5. mhh
    mhh F1 Veteran
    Feb 16, 2004
    5,894
    Australia
    Mark
    The same thing happened to me yesterday. The dealer did a software update (unrequested) and now auto lock doesn’t work - despite me checking that box in settings. The dealer is investigating…
  6. AliPaPa
    AliPaPa Karting
    Aug 16, 2011
    92
    I just found out it came back to life after i turned off long park mode.
    jo_ker likes this.
  7. mhh
    mhh F1 Veteran
    Feb 16, 2004
    5,894
    Australia
    Mark
    Mine is now sorted and operating as usual.
  8. TiFuze
    TiFuze Rookie
    Jan 29, 2024
    6
    Cam
    I was having this problem on my SF90 after update / recall 499.
    My tech informed me that if the passive / keyless entry isn't working just lock the car via the fob. Then press lock on the fob two more times and it will active keyless lock / unlock mode (i.e. walk away mode).
    JHNurse likes this.
  9. 488gtbmasergt
    488gtbmasergt Karting
    Oct 18, 2016
    169
    I am quite annoyed with my car locking itself up really quick even if I am still standing right next to it. And I mean right next to it.
    If this bothers you as well and you are not able to disable this passive self locking mode via the settings, here is a useful tip.
    As you just shut the door close, and you have the key fob in your hand, quickly (and I mean quickly) double press the lock button. This will not lock your car up. It will leave it open. It will not let it self close.
    This is not a permanent change in the set up unfortunately. But at least it works when you know you do not want the car to lock up immediately.
    milanojess and PieGre like this.
  10. JesseRohr
    JesseRohr Karting
    234
    Austin Texas
    Jesse Rohr
    I find my car automatically resets with every key cycle to "long park mode" which is wildly frustrating.
  11. Kmaaq
    Kmaaq Formula Junior
    Jul 26, 2019
    607
    Qatar
    Khalid Mohammed ALQattan
    What does it do?
  12. PieGre
    PieGre Karting
    Jan 9, 2019
    127
    Luxembourg
    PG
    There has been a recall compaign in order to disable this passive self locking mode.
  13. milanojess
    milanojess Karting
    Nov 26, 2007
    191
    sf bay area
    Does this mean that there’s no way to change this setting today? Thanks
  14. JesseRohr
    JesseRohr Karting
    234
    Austin Texas
    Jesse Rohr
    Can confirm pressing the lock button twice from the key fob does enable/disable the keyless entry.
    jo_ker and BigJay2050 like this.
  15. fadlouni
    fadlouni Rookie
    Dec 4, 2020
    10
    Fadi Adlouni
    Thanks for posting the answer. I got my 296 gtb back from the complementary checkup ( 200 kms). Then noticed keyless entry stopped working!, searching for this issue lead me to this article and indeed doubleclicking the lock on the key fob while the car is locked re-enabled keyless entry. I’m surprised this change of behaviour was not announced. Any one knows what other changes the software update does?. Thank you.
    jm2 likes this.
  16. mtaha
    mtaha Rookie
    Apr 10, 2024
    4
    Mhdy Taha
    My car after update suddenly now honks the horn 3-times every time I turn the car off. With the key so de the car and I’m still seated. Really annoying and not sure how to disable that. Seems as it has something to do with key fob.
