Kevlar timing belt? | FerrariChat
Kevlar timing belt?
Discussion in 'Technical Q&A' started by F-car, Oct 12, 2012.
  1. F-car
    F-car Karting
    Feb 25, 2009
    198
    Ipoh, Malaysia
    CK
    I found Gates kevlar racing timing belt for my P 944.. going to order one..
    wonder anyone use kevlar tb for ferrari. any good?
    thanks for sharing..
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Nothing but latigo leather for me. ;)
  3. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    #3 cheesey, Oct 13, 2012
    Kevlar ( brand name for arimid fibers ) is an interesting fiber, it has a high modulus (low stretch), low weight and high strength... all desirable characteristics for a timing belt.
    If there is an area of caution, it would be in long term use. Kevlar fibers do NOT like to be flexed. Flexing causes the fibers to weaken and break ( much like the way a paper clip can be flexed until it breaks ). Gates lists it as a "racing" timing belt. Long term service is not implied when the term "racing" is used. Need to look at the specs with respect to long term service and length of estimated service vs a standard construction timing belt. Also need to compare costs vs length of recommended service life.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,381
    San Carlos, CA
    Mitchell Le
    The 355 timing belts are kevlar, and that is why it is $125 each.
  5. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,054
    Dumpster Fire #31
    SMG
    having worked with the Gates engineers when I designed the timing pulley redux for the 3x8's the bulk of their belts are an arimid fiber blend. And yes there is a 'service life' on these, and shelf life too. a belt sitting on the shelf for 3-4yrs is just as liable to fail as one that's been in service.
    interestingly the line of 'industrial' belts is of better construction and will outlast the automotive belts by a wide margin, however they will never make the automotive belts the same way. industrial timing runs more critical tolerances then an engine, and down time is HUGE $$$$ lost.
    I tried but could not get a cross reference to an industrial belt for the automotive sizes, it's intentional to avoid the use of an industrial belt in an engine. the only go around is to re-design the pulley system, not cheap.
    Gates racing belts are tad better then the std ones but still not where they could be.
    all the above aside, the biggest reason why the life is short on the ferrari belts is due to the tiny drive pulley, it's dia is right at the critical bend radius for the belts construction. NEVER BEND the belt smaller than 2" in dia, it starts to break and shear the cords. folding the belt will cause even more damage, they should be in a loop form when they ship.
  6. Scott98
    Scott98 F1 Rookie
    Nov 3, 2004
    2,893
    Weston, FL
    Scott
    Very interesting information. Thanks for posting.
    Scott
  7. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,054
    Dumpster Fire #31
    SMG
    #7 smg2, Oct 13, 2012
  8. F-car
    F-car Karting
    Feb 25, 2009
    198
    Ipoh, Malaysia
    CK
    interesting.. what's this?
  9. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Early ECU!
  10. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    it's a valve... it says it's made in GB
  11. 335s
    335s Formula Junior
    Jan 17, 2007
    870
    SF Bay Area
    T. Monma
    "valve"...now theres a bit of electronics nomenclature not heard in practical application in over 40 years....it was an engineer and prototype designer from an old stereo guy in cambridge, M A
    he was with "AR"{acoustic research} the original latent holder for "acouistic suspension" speakers and encloseures...
    despite the impending total shift from "tubes" to "chips"...the old guys called them "valves" and not tiubes(tubes are what the tissue in the loo comes wrapped abbout"...
    it is really odd.......especially since this engineer succumbed to Luekemia yesterday evenin g...how weird.....
