Just Purchased My First Ferrari (2005 F430) Need Advice | FerrariChat
Discussion in '360/430' started by Rody1992, Aug 21, 2016.
  1. Rody1992
    Rody1992 Rookie
    Aug 20, 2016
    12
    Las Vegas
    Hello Everyone,
    My name is Rody, I am 24 years old and Reside in Las Vegas .
    I just purchased my first Ferrari. She is a 2005 F430 Berlinetta with an F1 transmission and 21k miles . I traded in a Flying Spur and need some questions answered as well as some advice so that way I do not go through a clutch every few thousand miles .
    1. Should I ever down shift the vehicle or should I let the vehicle do it itself ?
    2. When coming to a complete stop should I put the vehicle in Nuetral?
    3. What life expectancy does the average clutch have ? ( the original clutch was replaced at 15k miles , the vehicle was owned my a older gentleman who was a former NASA Astronaut )
    4. Is it ever ok to drive in auto mode or is this a clutch killer and complete no no?
    5. Are there any videos or tutorials on how to properly upshift?
    6. When backing car out of my garage (downhill driveway) should I let car roll back in Nuetral after initially putting it in reverse or just reverse out? (Hear reverse is a clutch killer )
    7. Any other tips or suggestions ?
    I understand these cars are pricey to maintain , prior to my Flying Spur I had a Quattoporte and built a good relationship with my F dealer out here. I just want to enjoy the car without causing unnecessary headaches and damage to it .
    Thank you all so much in advance for your help.
    I am glad to be apart of this amazing community now !
  2. Rody1992
    Rody1992 Rookie
    Aug 20, 2016
    12
    Las Vegas
    #2 Rody1992, Aug 21, 2016
  3. lamborarri
    lamborarri Formula Junior
    Nov 15, 2015
    452
    1. oh, whenever you are making a pass or feel like wanna enjoy hearing the engine, downshift it by yourself. When coming to a complete stop, if you aren't trying to impress anyone or yourself, I would say leave it alone.
    2. I have seen other ppl on the forum do, but honestly I don't give a damn. It's too much effort to put in N and put to drive again.
    3. Your car's former owner can be donald trump or hillary clinton, but that doesnt do any justice to the overall condition. They could take care of it like a baby or treat it like a hoe. You just need to check out the CURRENT condition of everything.
    For the clutch life span, everyone drives different so it's different. One of my clutch last 25k miles, and one of mine last 20k miles.
    4. In 2005 may be fine to drive it in auto, fancy F1 gearbox with auto function. Not in 2016, hell no. You try it and you will know what's saying. Unless in heavy traffic which doing no more than 15mph.
    5. Hmm, if you know how to drive a manual car, you should be able to get used to it very soon. If you never drive manual before, then you have to learn it.
    6. I would do reverse just for the safety. My house has a long downhill driveway as well, I would never put in N.
    7. It seems like you are way too much worrying about the clutch and running cost of it, if that's the case, make the car super clean, park it very hard, make sure always have the battery tender connected. Do not drive it! Because the car runs on the clutch.
    OR, you can do it like many of us here, just enjoy it. When the time comes to pay for a new clutch, shop around, get a new clutch, and enjoy it more.
    Hope it helps and congrats on your purchase.
  4. BladeMD
    BladeMD Formula 3
    1,140
    Sarasota, FL
    Hannibal
    Congrats on your 430!!!
    I got a obd2 wifi reader off Amazon for around $20-30 and use the "Eobd-facile" iPhone app. Seems to be the consensus best app/option for iPhones. I paid for the upgrade of $15 and it's great.
  5. Alcav5
    Alcav5 F1 Rookie
    4,067
    Scarsdale, NY
    Al
    My opinions:
    1. By all means, do down shift when the opportunity presents it's self, obviously without aggression .
    2. Not necessary, esp. if you plan on a short stops. Longer stops sure.
    3. I do not think there is a clear rule of thumb , I have heard as low as 5,000 all the way up to 25,000 miles. I only owned my 430 for 6 months and 1k miles , it had 12k miles , the clutch was still good.
    4. Auto mode or non-auto mode I do not think one will burn up the clutch more over the other
    5. Probably videos, obv. do a search. But there was not a video with the car's documentation.
    6. I would not intentionally roll in neutral for either reverse or forward. I think I read that aggressive throttle or challenging hills in reverse are a clutch eater.
    7. Search through the 430 section here in F-Chat, you will learn a ton about your car.
    If you have driven a manual transmission before then you will have an idea as to what the F1 tranny is doing and understand it's strong and weak points. If you have not, then be patient initially.
    Keep the music down and listen for all the sounds your cars makes so to be prepared when one sound is off or if a new noise is present. It may save you a ton of money.
    Good luck with you purchase, enjoy.
  6. bellwilliam
    bellwilliam Formula Junior
    Oct 25, 2014
    399
    What a dumb comment. Wasting clutch has nothing to do with driving enjoyment. It doesn't make it go any faster by burning up clutch. In fact, slipping clutch (=wear) can only leads to heat build up.
  7. bellwilliam
    Oct 25, 2014
    399
    Why ? It is either bad for clutch, you should shift into N. Or it doesn't matter, you don't need to shift into N. How does time duration has to do with it ? I've heard this a few times on FC, and don't quite understand it
  8. lamborarri
    Nov 15, 2015
    452
    At what point did I tell the op to waste clutch? Or what point you see I tell him to burn the clutch? Why you feel so offensive about it? LOL, you are one of the dumb **** to buy a car but can't enjoy it fully because worrying about the clutch the whole time during driving, isn't it? I'm just saying that op should enjoy the car.
  9. MVDESQ
    MVDESQ Formula 3
    Nov 25, 2010
    1,581
    Greenwich, CT
    Matthew & Kristen V.
    OBD Fusion works well with elm327.
  10. MVDESQ
    MVDESQ Formula 3
    Nov 25, 2010
    1,581
    Greenwich, CT
    Don't drive in stop and go traffic. Never get the car in a situation where you have to back up a hill. If hill is steeper it just won't go and eat the clutch. I drive in race mode as I've heard it is easier on clutch and the exhaust sounds better.
  11. Cigarzman
    Cigarzman F1 Veteran
    This ! FWIW , I never used auto mode. Enjoy and keep an eye on the tach and change gears at your desire. Oh and post pics.
  12. Rody1992
    Rody1992 Rookie
    Aug 20, 2016
    12
    Las Vegas
    Thank you so much for your feedback ! I fully intend on driving her and enjoying her just don't want to be uniformed and end up looking like an idiot by driving incorrectly !
    I spoke to Rich in Las Vegas at Ferrari here and he also gave me a lot of advice !
    Glad this forum exists so I can be educated on my new purchase !
    Thanks again!
  13. Rody1992
    Rody1992 Rookie
    Aug 20, 2016
    12
    Las Vegas
    Great thank you !
  14. Rody1992
    Rody1992 Rookie
    Aug 20, 2016
    12
    Las Vegas
    Thank you !
  15. Rody1992
    Rody1992 Rookie
    Aug 20, 2016
    12
    Las Vegas
    Great info thank you so much !
  16. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,721
    Just East of Weird
    Bob
    Rody,Rody, Rody,
    +1 on all the great advice but...
    We need more pictures, you can't ask questions about your new Ferrari without posting obligatory pics! It's one of our rules...
    Just kidding of course, mostly.,more pics will be most appreciated.
    And as the others have said, just enjoy her.
    Sent from my iPad using Tapatalk HD
  17. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    I believe is the equivalent of having the clutch pressed all the way when you are waiting on a stop light in a manual car, if it is a short stop it might not be a problem but a longer wait is different.
    I do not know about the 430 but the 360 will go to neutral after a long wait standing in first with the brake engaged.
    If the computer does it is because waiting too long is not good I guess
  18. Rody1992
    Rody1992 Rookie
    Aug 20, 2016
    12
    Las Vegas
    #18 Rody1992, Aug 21, 2016
    I've been trying to post pictures but it's been giving me a hard time to do more than 1!
  19. Rody1992
    Rody1992 Rookie
    Aug 20, 2016
    12
    Las Vegas
    #19 Rody1992, Aug 21, 2016
  20. tazandjan
    39,007
    A few things on your F430. First, reverse is much lower in the F430 than it is in the 360 or 575M, so using reverse is not as big a deal. Reversing up hills, though, usually gets you the smell of burned clutch lining because reverse is still pretty high compared to 1st. Not close to 2nd like the 360, but still pretty high. Out of your garage, which you say is slightly downhill, just use reverse like any other car. Will not hurt her.
    Best advice for using her is to drive her exactly the same way you do a three pedal car, assuming you have done that. If you are a coast to a stop in neutral guy with three pedals, like I am, do that. If you downshift all the way down in a manual gearbox, do that. I never let my F1 system auto shift to 1st, or any gear, when coming to a stop. Do it yourself if you want to do that so she is not almost lugging when she downshifts. All those downshifts are extra cycles on the clutch and throw-out bearing. Remember that when you are stopped, even in neutral, the clutch is always open with F1, so there is no saving the throw-out bearing when stopped by using neutral, but I do it anyway. Our pros estimate the throw-out bearing sees three times as many cycles as a three pedal T/O bearing. Make sure you keep your foot on the brake in neutral, or she will not shift into gear. Most owners learn that the hard way.
    Auto mode uses exactly the same algorithms as manual mode for shifting, so if you drive exactly the same way auto does in manual, no difference in clutch or T/O bearing wear. However, if you coast to a stop in neutral, you do reduce the number of clutch and T/O bearing cycles.
    If you coast to a stop in neutral and the light changes, you can use either paddle to select a gear to continue. Either gives you the same gear. Very easy and simple to do. Guaranteed it will be too high a gear, so use the downshift paddle instead of the upshift paddle and be ready to instantly downshift again to get a usable gear for acceleration. Not exactly rocket science, and I should know.
    Drive her like a three pedal and you will love her, drive her like an automatic and not so much.
    So I disagree with much of what was written above, but have been driving F1 for 8 years as a daily driver, so have bit of experience. Projected life on my clutch is 62,000 miles in mixed city and freeway driving, and your F430 twin disc clutch is actually tougher than my single disc clutch.
    Lots of old wives' tales about F1 out there, so it pays to know how it works and then drive her any way you want that you enjoy. Takes a while to learn to drive smoothly with F1, but a great pleasure once you get good at it.
  21. yangstein
    yangstein Formula Junior
    Mar 23, 2015
    571
    Orange County, CA
    Brian
    +1, +1
    You purchased the car to drive. No? All cars break down, have issues and will give you headaches... Ferraris might cost a little bit more. You already had a Maser and Flying Spur so you know what it takes to get them properly maintained.
    Cars are meant to be driven. Ferrari is not an exception although there are lots of garage queens out there. Most of us here love driving the car, fixing the car and share new information with each other. I've learned so much about my car through F-Chat more than anything.
  22. Wisky
    Wisky Formula Junior
    Nov 13, 2006
    272
    Fort Lee NJ
    David
  23. Rody1992
    Rody1992 Rookie
    Aug 20, 2016
    12
    Las Vegas
    Great advice thank you so much . I hope I get 60 k out of the clutch ! If I do great , if not, oh well. I'm gonna enjoy her as much as I can while I have her ! Not gonna drive her daily but still gonna enjoy and learn as much as I can about the car !
  24. tazandjan
    39,007
    One last thing. Most F1 problems are caused by lack of maintenance. Ferrari's last F1 recommendation, for the 599, calls for changing the F1 fluid (requires bleeding the system and a self check) every 3 years. If I had just bought an F1 F430, I would have that done immediately because it may not have been done at all during the last 11 years. Ferrari neglected to recommend changing the F1 fluid in earlier F1 Ferraris, just like they neglected to do the same for coolant changes.
