Jaguar E Type Series III, 1972
Discussion in 'British' started by stevenwk, Sep 1, 2012.
  1. stevenwk
    stevenwk F1 Veteran
    Apr 12, 2007
    5,503
    Metro Detroit/Encino
    Steve
    Ok, got it. Thanks.
  2. stevenwk
    stevenwk F1 Veteran
    Apr 12, 2007
    5,503
    Steve
    #27 stevenwk, Oct 19, 2012
  3. jnk
    jnk Formula Junior
    Nov 12, 2010
    343
    Your car is beautiful. I have a number of vintage Ferraris and Maseratis and a v-12 etype OTS. It is a joy to drive.
    There were 2 different compression ratio cars. The European was 9:1 and the USA 7.8:1.
    If you look at the engine number on the ID plate at the front fire wall ( drivers side ).it will end with either LA(LB) or SA(SB). The LA is the 7.8:1 and the SA is the 9:1 engine.
    There is quite a horsepower difference between them. The USA cars had 291 and the Euro version 335.
    Enjoy your car, I have had mine since 1983 and it has been trouble free.
  4. stevenwk
    stevenwk F1 Veteran
    Apr 12, 2007
    5,503
    Steve
    Thank you for the information and your kind comments.
    I thought that the USA cars had 272 hp, but nice to know it is more.
    Unfortunately, I will be selling the car as I am only the custodian for that period of time until sold.
    Steve
  5. msdesignltd
    msdesignltd Two Time F1 World Champ
    20,078
    NYC. / E. Hampton
    Michael
    EHHH!
    only the 71 with the higher Comp ratio, had an upward HP..
    I believe the american version 72 and above was even less than 272..
    actually the series 2 6 cyl had a little more than the 12..
    just my memory serving me
  6. chewitt
    chewitt Rookie
    Dec 10, 2009
    6
    These Jags have the most legroom. Much more comfortable than earlier years if you are over six feet and have long legs.
  7. miurasv
    miurasv F1 World Champ
    Nov 19, 2008
    10,570
    Cardiff, UK
    Steven Robertson
    First I've heard of this. Euro V12 in the E Type made between 265 and 276 BHP from memory and nowhere near 335BHP.
  8. Edward 96GTS
    Edward 96GTS F1 World Champ
    10,860
    google e-type brochures. 315 hp per manufacturer brochure. that was gross hp. then there was a rating change re how hp was determined. that resulted in misinformation.
    ed
  9. stevenwk
    stevenwk F1 Veteran
    Apr 12, 2007
    5,503
    Steve
    Interesting horsepower discrepancies, but if someone wants, what I believe, a no nonsense perfect 1972 series III, 4 spd, roadster you won't find one better than this example.
  10. Red Head Seeker
    Red Head Seeker Formula 3
    2,443
    San Francisco Area
    Mark
    Your memory is serving you "Bad Information"....series II 6 cylinder engines were "around" 250hp....1972 Series III 12 cylinder were around "300".....those are facts!!!....not memory!!!.....Mark
  11. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    In the end, Jaguar themselves admitted that the most powerful version of the XK-engine was the EFI installed in the Euro- Series III XJ's: It had the biggest valves and best profiled cams.
    Any version of the 12 had more power.
    After all the BS HP-numbers that were put in print in the sixties, the early seventies saw at least European manufacturers adhering to the DIN (Deutsche Industrie Norm), and real figures became the norm.
  12. msdesignltd
    20,078
    NYC. / E. Hampton
    Michael
    #37 msdesignltd, Nov 2, 2012
    I challenge you on this..
    My " Bad information " is your poor Knowledge of the Marque, Those are not the facts
    The American V 12Cars had a few less HP than the 3 carb 6 cylinders series 2 / 1.5 or 1
    Only the late 71 V 12's came with a higher comp. ratio, hence a little more HP..and a little more Torque.
    300HP was never a post 1971 USA smog regulated car
    http://www.carfolio.com/specifications/models/car/?car=57937
    http://www.scorpiocars.net/cars/Jaguar/1974_E-Type-V12_10312
    http://nelsonsoares.hubpages.com/hub/Jaguar-E-Type-Series-1-2-and-3-Specifications
    http://www.automobile-catalog.com/make/jaguar/e-type_3/e-type_3_otc/1974.html
    http://www.rmauctions.com/FeatureCars.cfm?SaleCode=SJ12&CarID=r164&fc=0
  13. Edward 96GTS
    10,860
    61-67 etypes had 265 hp(triple su carbs)
    68-71 etypes 245 hp(twin strombergs)
    Ed
  14. Red Head Seeker
    2,443
    San Francisco Area
    Mark
    #39 Red Head Seeker, Nov 3, 2012
    Hello Micheal; I very familiar with the marque as I have owned a pristine 1969 XKE Series II FHC for quite some time, I also own a few other cars & I believe I have a fairly firm grasp on the "feel of horsepower". It has been quite well documented that horsepower ratings of Bristish cars were quite embelished in the 60's. I bet NO Series "I", "I-1/2", "II" Jaguar EVER left the factory with 265hp, a DYNO makes a "liar" out of most Bristish car manufactors in the 60's. According to my link, it states 314 HP for the Series III.....Mark
    add topic
    In Detail
    tags
    etype, xke
    submitted by
    Richard Owen
    type
    Production Car
    built at
    Coventry, England
    price $
    $ $7 599
    engine
    60º V12
    position
    Front Longitudinal
    aspiration
    Natural
    valvetrain
    SOHC
    fuel feed
    4 Zenith Stromberg 175 CD2SE
    displacement
    5343 cc / 326.0 in³
    bore
    90 mm / 3.543 in
    stroke
    70 mm / 2.756 in
    compression
    9.0:1
    power
    234.1 kw / 314 bhp @ 6200 rpm
    specific output
    58.77 bhp per litre
    bhp/weight
    204.83 bhp per tonne
    torque
    473.2 nm / 349 ft lbs @ 3800 rpm
    Read more at http://www.**************/cars/845.html#t9mxW5vmX810akwX.99
    The E-type's engine was the same 3,781 cc (231 cu. in.) six introduced on the final XK150s, with three S.U. HS8 carburetors and a rather optimistic 265 hp (198 kW) gross rating. (Various sources suggest net ratings between 180 and 228 hp (134 and 167 kW), a point obfuscated by the fact that many of the cars Jaguar released to the press had noticeably more power than the standard tune.) To this engine was linked, sadly, the XK's familiar and cumbersome Moss four-speed gearbox, still lacking a synchronized low gear and no more pleasant to use than it had been on earlier Jaguars.
  15. msdesignltd
    20,078
    NYC. / E. Hampton
    Michael
    In the past 20 years I have owned 7 E types as well..
    I never stopped following the Marque.
    314 is surely a mis quote..
    if there were 4 webers Then Yes, but I too have had the pleasure of seat of the pants feel driving all series.
    I believe a series one 4.2 would take every engine performance award away from the series 3, as the response time and HP were certainly greater.
    I believe....according to Victory by design...they went to a 12 to just stay abreast of the decresing HP that the series 2 was experiencing...
    Either way...maybe someone more Knowledgeable than us could answer the HP question..
    Any DYNO VIDEOS out there.
  16. Edward 96GTS
    10,860
    Michael,
    Jaguars own brochure for USA v12 etypes states 314 hp.
    Google " jaguar etype brochures". A lot of info there.
    Ed
  17. f1_nix
    f1_nix Formula 3
    2,146
    Ft. Worth, TX
    http://www.jag-lovers.org/brochures/xke3/s3_3-71_rear_l.jpg
    This brochure states 314 BHP Gross @ 6200 rpm and 272 bhp DIN @ 5850
    Denis Jenkinson's "Jaguar E-Type" book states 314 bhp (SAE) @ 6200 rpm on page 128
    Paul Skilleter's "The Jaguar E-Type" states 272bhp @ 5850 rpm on page 119.
    Chris Harvey's "E-Type: End of an Era" states 272bhp (NET) @ 5850 rpm for the SIII V12 and 272bhp (DIN) @ 5850 rpm for the SIII V-12 2+2 on page 218.
    Philip Porter's "Jaguar: History of a Classic Marque" lists max power as 272bhp on page 168. No mention of gross or net, SAE or DIN, or rpm.
    It's probably fair to say that all of them are optimistic.
  18. Red Head Seeker
    2,443
    San Francisco Area
    Mark
    Hello f1_nix; Your various HP stats would PROVE my claim that the Series I-II 6 cylinder NEVER had more HP than the V-12....I rest my case.....Mark
  19. f1_nix
    f1_nix Formula 3
    2,146
    Ft. Worth, TX
    From most of the same sources the SI had 265bhp and the SII had 171bhp as published. Not sure of the calculation methods. What the SI and II cars had over the SIII cars was less weight and better balance.
  20. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Jack Verschuur
    The 4.2 with the twin Strombergs was a bit of a joke; Euro-versions still emplyed the triple SU's and were a lot faster.
    Even with the extra weight, the 12 was a great car, especially with a manual box. With some handywork, the Strombergs can be replaced by SU's, which makes it more responsive.
  21. msdesignltd
    20,078
    NYC. / E. Hampton
    Michael
    #46 msdesignltd, Nov 5, 2012
    5.3 Litre
    The 5.3-litre (5,343 cc) version had an oversquare 90 mm (3.5 in) bore and 70 mm (2.8 in) stroke. It produced 210 kW (282 hp), (242 hp (180 kW) to 295 hp (220 kW) depending on emission controls and compression ratio) and 400 N·m (300 lbf·ft) in fuel-injected form. Right from the start of production in 1971 for the Series 3 E-Type, the V12 engine had Lucas OPUS electronic ignition. This system was used until 1982 when the Lucas CEI system was introduced. Initially the OPUS ignition amplifier unit was secured directly to the engine between the cylinder heads and had problems due to overheating. Later cars had the ignition amplifier moved away from the engine where it could get air flow for cooling. Originally the V12 was supposed to get an advanced Fuel Injection system under development by AE Brico but this plan was cancelled at a late stage, possibly due to concerns that the design was too similar to Bosch products. The V12 as used in the Series 3 E-Types, Series 1 XJ12 and early Series 2 XJ12s (1973-April 1975) had four Zenith-Stromberg side draft carburettors. After April 1975, the V12 engine used in the S2 XJ12 and the new XJ-S had a Lucas fuel injection system which was based around the Bosch D-Jetronic system
    If you rest your case now...you've lost..
    We Were always talking about the American post 72 cars here!
    242 is the # I recollect, Thats 20 less than the series 1..Heres my confirmation
    Wikipedia has it right for American equipped Smog Cars
    Case Closed.
    http://en.wikipedia.org/wiki/Jaguar_V12_engine
  22. f1_nix
    f1_nix Formula 3
    2,146
    Ft. Worth, TX
    I have no dog in this fight. I was simply passing on information from published sources other than Jaguar Cars Ltd. (B-L) literature, none of which make any reference to US market, home market, compression ratios, emission controls, etc. Makes no difference to me which version has more horsepower; I'm perfectly happy with my SI FHC.
  23. stevenwk
    stevenwk F1 Veteran
    Apr 12, 2007
    5,503
    Steve
    Ok so it looks like I have interest from a buyer from Japan.
    Does anyone have experience shipping to Asia?
    I hear, however, that xke's are tough to get into Japan. Can anyone confirm this too?
    Thanks.
