Is there a way to TEST a Fuel Pressure Regulator?? | FerrariChat
Discussion in '348/355' started by goyal99, Oct 22, 2006.
  1. goyal99
    goyal99 Karting
    Mar 5, 2002
    185
    Upstate NY - USA
    V K
    One of the FPR on the 348 (bank 5-8) might be bad.....I pulled the small vacuum hose that attaches to the regulator and found a small amount of fuel in it. There shouldn't be any fuel on the vacuum side.
    Also I noticed recently that my spark plugs on bank 5-8 are carbon fouled (rich fuel mixture) so I'm suspecting the FPR is part of the problem....The regulator on the other bank (1-4) does not leak any fuel in the vacuum line.
    What's the best way to test the regulator??
    Also I read in this forum that other Bosch regulators might work in the 348...I certainly don't want to pay a premium price if I can find a cheaper one....Has anyone used a replacement part for the regulator with success??
    Is there a Shroeder Valve on the fuel rail to attach a fuel gauge??
    What is the fuel pressure reading (PSI) supposed to be when ignition is on (car not started) and when the car is running??
    Regards - VK
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  3. goyal99
    goyal99 Karting
    Mar 5, 2002
    185
    Upstate NY - USA
    V K
    Thanks....but that's NOT what I'm looking for....I know how to remove/replace the fuel pressure regulator...It's been been disconnected already!
    I'm looking for a way to TEST the regulator to find out if it performs according to Ferrari specs or if it needs replacing.....I understand that one way to do this is to perform a pressure test with a fuel gauge....However I don't know the 348 specs to test!
    BTW, my regulator is BOSCH part# 280 160 738 on my car. The 348 Parts interchange List indicates a different Bosch number for the same part (280 160 731)....Also on the write-up link posted above you can clearly see yet another Bosch part # 280 160 715 stamped on the regulator!
    So which Bosch part # is the CORRECT one for a 348 Fuel pressure regulator??
    VK
  4. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    Do a pressure test to the vacuum connector. There should be no leak to the fuel lines. If you put pressure on it it must hold the pressure because in working condition the part is sealed. If it lets air to the fuel or fuel to the vacuum line. The part is damaged and needs to be replaced.
  5. goyal99
    goyal99 Karting
    Mar 5, 2002
    185
    Upstate NY - USA
    V K
    Thanks for your answer....it makes sense to test the vacuum side...
    Regards - VK
  6. tamf328
    tamf328 Formula Junior
    Mar 9, 2005
    477
    normally you test them in the car,
    with a fuel pressure gauge and a vacuum pump.....
    but I suppose you could test them on the bench.
    if its leaking you throw it away.
  7. goyal99
    goyal99 Karting
    Mar 5, 2002
    185
    Upstate NY - USA
    V K
    I took BOTH regulators out of the car for vacuum testing as suggested by Samy.
    True to form the regulator on Bank 5-8 does not hold vacuum! The other regulator is fine....Ordered a new one from Autozone for $56...I will install it tomorrow and continue the troubleshooting the rich condition/fouled plugs and exhaust smoke....I'm hoping the new regulator will correct some of the symptoms.
    VK
  8. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,611
    The Brickyard
    The Bad Guy
    SUWEET! What's the part number?
